Tape mask on samsung RU7100
  • nubinator
    • Jan 2012
    • 37
    I got boot looping 65RU7100 and did tape mask and got image back. I narrowed down the problem to 1 pin it was pin 16 on left side which is CKVB1 so I masked that pin as well as CKV1 cause I read should do them in pairs. Image is pretty good but I get horizontal scan lines on bad side of panel, any way to fix this? When I was experiementing with blocking CKV pins I noticed the more I blocked the more color loss I got on bad side of panel
  • nubinator
    • Jan 2012
    • 37
    oh I found theres a short between CKV1 & CKVB1 , I think that is internal panel issue so never going to fix that but I then saw "short killer" videos on youtube for this very issue haha https://www.youtube.com/watch?v=l5ti8vp9VUM
    • nomoresonys
      • 12333
      • U.S.
      Not sure if it applies here but I had those exact lines with an old tv that had a bad tcon board, in my case it had a stand alone tcon board.
      • nomoresonys
        • 12333
        • U.S.
        Interesting video, too bad about that line tho.
        • nubinator
          • Jan 2012
          • 37
          https://www.youtube.com/watch?v=eipbyzi_a3I
          I followed this vid and got my best result with no lines. Key is to to short all the clock lines together after masking them, no lines after doing that.
          I shorted them at the diode packs near where it enters panel.
          Have great image now just slight color fade on bad side since one side is doing all the work I guess.
          • Aliencomputres
            • Aug 2019
            • 220
            • România
            show us how/where you put the masking tape.
            • nubinator
              • Jan 2012
              • 37
              Well I taped 10 pins using the service manual for a similar model which also had the CN1300 & CN1301 connectors. My bad side was on the CN1300 so I taped pins 10 to 19 which are the clock lines and VGL,VGH
              • Aliencomputres
                • Aug 2019
                • 220
                • România
                thx
                  09-07-2024, 05:50 AM
                • howardc64
                  by howardc64
                  Problem
                  08-04-2024, 10:36 PM
                • valvashon
                  Samsung UN60JU6500, stripe on left side of screen
                  by valvashon
                  Friend sent me this picture of what their 60" Samsung from 2015 is doing. I didn't have any luck getting rid of a vertical stripe in another TV that developed one so I'm not too excited about trying to fix this one. It's mine for the asking; wish it had a dead power supply or bad backlights instead.
                  Is this most likely to be a connection at the circuit board or where the ribbon cable hits the screen itself?
                  Update: was just informed that this stripe comes and goes and has been doing this for a couple of months.
                  Thanks, Val
                  11-21-2025, 03:01 PM
                  09-06-2024, 11:40 PM
