Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Gigabyte Aorus 1080ti - card not initialising
  • mo5t_want3d
    • Oct 2022
    Re: Gigabyte Aorus 1080ti - card not initialising
    Originally posted by benwaterson
    More up to date info regarding testing of these https://youtu.be/IBW5alE6K0w?t=345
    Hi Ben, how did you go with this? Did you manage to find a solution?
    • WhyINeedAccount123
      • Feb 2021
      • 19
      • Poland
      #102
      Originally posted by DynaxSC
      Hi Benwaterson
      Thank you very much for this video, just repaired a MSI GTX Aero Mini ITX thanks to this video. It had also read errors on all ram chips, worked sometimes, but stopped under load. Exchanged the Bios from MX.. to Winbond, and now it's working perfectly !
      Hi i have gtx 1070 with the same problem, can you tell me with windbond chip did you used?
      • nick122
        • Jul 2016
        • 110
        • Slovenia
        #103
        For anyone wondering, I had a very similar issue on my Zotac 1080 Ti amp. It was a bad core in my case. Some visual cues were a very dark brown, almost burnt looking underfill around the die. Seems to be fairly common on Pascal cards
        • myth77
          UV solder mask - high temp resistent, recomendation?
          by myth77
          Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
          Is there any solder mask...
          03-28-2022, 04:04 AM
        • janos666
          Pioneer LX5090 - 2x Red blink after auto-shutdown
          by janos666
          I was trying to reset the Pulse Meter and re-adjust the Panel-1/2 settings in the SM on an exceptionally old Pioneer LX5090 (51k power-on hours according to it's SM). I did this many times on much less aged specimens (with 10-20k hours) without issues. After following the usual workflow, I noticed the darkest gray shade showed up black with bright sparkles. I tried to adjust some other parameters but it didn't disappear. Then I went on and restored the old values of the parameters I don't usually touch (although I did this from memory, so I might have made an error). After that, I started going...
          03-26-2023, 11:20 AM
        • Boardview and Schematic Bot
          NVIDIA GeForce GTX 1080 1080Ti Schematic & Board View
          The GeForce GTX 1080 was a high-end graphics card by NVIDIA, launched on May 27th, 2016. Built on the 16 nm process, and based on the GP104 graphics processor, in its GP104-400-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 1080. The GP104 graphics processor is a large chip with a die area of 314 mm² and 7,200 million transistors. It features 2560 shading units, 160 texture mapping units, and 64 ROPs. NVIDIA has paired 8 GB GDDR5X memory with the GeForce GTX 1080, which...
          10-02-2024, 07:37 AM
        • DynaxSC
          Gigabyte GeForce GTX 1080Ti - PCIe issue after mouse visit
          by DynaxSC
          I have got for repair a Gigabyte GTX 1080Ti which has been exposed to mouse piss, I mean a real living mouse, that declared the PC case for her home. Unfortunately she was not behaving civilized, and pissed on the card making some minor electrolysis demage only to the very surface of some soldering points and leaving some dirt on the card. It was not a big deal, only minor visible effects, only on the bottom pcb side, after cleaning it is almost not visible. The card even started to work, however there are issues with the pcie bus, so the card works only in pcie x4, or x2 mode,...
          01-25-2026, 04:01 PM
        • foshland
          MSI B550m DS3H Resets Bios parameters when I power off from PSU, coin Battery is OK
          by foshland
          Hi to all, I have a B550M DS3H from MSI, it works ok, but when I turn off PSU, It loses the bios saved parameters, changed the 3V battery and measured Vbat line and its ok, 3.2V, so its not the battery. I have the diagram and boardview, updated the bios to latest version, and still no go. I uploaded the 3 files in case someone needs them.
          I have traced the line Vbatt to the EC and the RTC and it keeps ok when I remove PSU power, it meassures 3.some volts.
          Any ideas? thanks a lot...
          12-01-2025, 05:50 PM
