Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
Pioneer LX5090 - 2x Red blink after auto-shutdown
  • janos666
    • Mar 2023
    • Hungary
    I was trying to reset the Pulse Meter and re-adjust the Panel-1/2 settings in the SM on an exceptionally old Pioneer LX5090 (51k power-on hours according to it's SM). I did this many times on much less aged specimens (with 10-20k hours) without issues. After following the usual workflow, I noticed the darkest gray shade showed up black with bright sparkles. I tried to adjust some other parameters but it didn't disappear. Then I went on and restored the old values of the parameters I don't usually touch (although I did this from memory, so I might have made an error). After that, I started going through all the built-in test patterns (masks) in various drive modes (60/72Hz) until I found one that made the TV turn off. After that, a blue light blinked when I tried to turn it back on with the remote (I didn't count the number of flashes). I unplugged the 230V power cord and tried to turn it on again. Now it briefly turns on but due to how the SM works on these devices, it immediately tries to display the same mask which causes an emergency shutdown.
    I tried rapidly sending the FAY command immediately after powering it on (which should reset the mask setting and greet me with the SM's main page on black background instead) but I am not that lucky because the TV doesn't react but tries to light the screen up regardless (it becomes bright for a very brief moment before it shuts itself down).
    I see two possible solutions here:
    1: Some workaround to prevent the mask from activating on boot. This could either be like disconnecting some other board from the main board and entering the SM blindly (if that's possible) which should reset the mask, or
    2: Figure out which board sends the emergency message and try to renew it (by replacing old capacitors, etc) or replace that board with another used part in a hope that the TV will be able to handle that test pattern without shutting down (at least long enough to process the FAY command and reset the mask setting).
    Can I achieve #1 with something like reflashing the EEPROM? (Is a "clean" dump available somewhere?) Or is there some even easier solution, like some "pins to short on some board to power the screen up in some 'reduced' mode" (or any service mode which resets the mask settings)?
    In case #1 is not viable, then how should I narrow the problem down to a boarad/IC?
    But the #2 solution won't work in case I misadjusted some values and thus an emergency signal is bound to happen with every board/IC in perfect condition.) And #1 won't work if something got fried. Also, trying #2 could also fry something new yet again...
    3: I also thought about replacing the entire main board but that's not cheap and this set is way too aged with 51k hours. And I am not sure if something else is "fried" anyway. (It's just my wishful thinking that the TV would still work with normal loads if the mask was removed, simply because the screen light up for a brief moment.)
  • pixelcap
    Pioneer Kuro Pro 111FD 8 red blink error
    by pixelcap
    Pioneer Kuro Pro 111FD 8 blink red LED.
    I have been trying to solve the power-down 8-blink red LED problem with my Pioneer.
    So far I have replaced the power supply board, and the digital assembly board, I have reconnected the ribbons to all boards, ensuring the connections are good. Even though the problem is the 8 red light error and not the more common 8 blue light error code, I had Kcrownie,
    based in North Carolina replace the chips that cause the 8 blue LED problem (the main board and audio board) the plasma is still powering...
    10-06-2024, 11:26 PM
  • cloo
    Panasonic ZT60 plasma tv with strange behavior and 8 blink code
    by cloo
    I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
    It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
    So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
    After doing a factory reset this problem was gone and the picture was back to...
    01-06-2025, 06:02 AM
  • EazyBone
    Un50cu7000 2 blink oddity *partially solved
    by EazyBone
    I write this to maybe help another with this TV.
    So I aquired this TV a 2023 model. It started the 2 blink reboot problem which indicates bad panel. It was still under warranty and the repair man came by.
    The Samsung repairman brought a brand new panel and switched my original boards to the new panel. The new panel then had the 2 blink error code. The repair guy said he has seen this and the MAIN board on this model will cause the 2 blink. He then replaced the main/power board (they are both connected) and put it back onto my original panel. Voila it worked.
    03-18-2024, 10:24 PM
  • Bjs
    Vizio TV M70-C3 blink codes
    by Bjs
    I was given this TV with little info. Was told that it didn't have a picture. Upon powering it up it displayed the Vizio logo and the menu was able to be displayed. I connected an antenna (OTA), did a channel scan which completed and the picture has been fine for days. The only issue is it has an initial blink code of 23 upon power off, followed by a 19 about 75 seconds later which then repeats the 19 code four more times. I haven't been able to find the process for entering the service menu nor do I have the service manual for this model (I do have the E60-C3 and E70-C3 service manuals but they...
    12-16-2025, 04:31 PM
  • ReeceyBurger123
    Pioneer Kuro PDP-428XD 8 Blue Blink Repair Video
    by ReeceyBurger123
    I'm back again bodging things
    Video covers the repair and diagnoses of my own Pioneer Kuro 428XD which went faulty with 8 blue blinks. Do not attempt anything seen in the video at home haha
    https://youtu.be/O0BS5kg3tNo
    02-21-2022, 12:12 PM
