MSI A320M-A PRO broken component
  • mc4ren
    • Jul 2019
    • 37
    • Basque Country
    I have a MSI A320M-A PRO board in which the Ethernet port is not working correctly. I have spotted these small components, with some of them being ripped off. I can read the number "40" on them but I can't identify them. A little help is appreciated. Thanks!
  • mon2
    • Dec 2019
    • 14256
    Re: MSI A320M-A PRO broken component
    Can you post a zoomed pic of the motherboard ? I believe to have the schematic in my database subscription.
    • mc4ren
      • Jul 2019
      • 37
      • Basque Country
      Do you mean like a zoom out?
      • mon2
        • Dec 2019
        • 14256
        Yes. Meant zoom out to review the surrounding components. On the posted pic - where are these damaged parts ?
        Looks like a SMD shottky 40V diode.
        Check with your meter in diode mode. Remove all power to the board.
        If it is a diode, the part will conduct in one direction and block in the other.
        • mc4ren
          • Jul 2019
          • 37
          • Basque Country
          Thanks mon2,
          I've uploaded an image marking the area of these components. I'll check the diode function of these components, I'm just away from home right now.
          Is this in line with the schematics?
          • mc4ren
            • Jul 2019
            • 37
            • Basque Country
            Originally posted by mc4ren
            Thanks mon2,
            Well, I finally measured the diode behavior of these components. Just one of these is working as a normal diode. They all have 0.256V in one direction, but the other direction varies from totally open to 0.8V and 1.2V.
            Could these be the diodes marked in the attached figure?
            • chth96
              Is it possible bridging tiny broken trace
              by chth96
              When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
              cutting tiny trace.
              This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
              Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
              But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
              12-03-2022, 11:32 PM
            • DynaxSC
              ASUS ROG STRIX B550-I GAMING - M.2_2 port not working correctly with SAMSUNG SSD980 1TB NVME SSD
              by DynaxSC
              I have an really very weired issue with ASUS ROG STRIX B550-I GAMING.
              Some NVME (PCIe) SSD's are not working correctly in the second M.2 socket. An example of it is the SAMSUNG SSD980 1TB NVME SSD.
              Some other NVME (I have only smaller ones) disk do work without any problem, also SAMSUNG disks, eg an MZVPV128HDGM-0000.
              The behaviour is also really very strange, i.e.:
              • The disk shows always up in BIOS - so it is recognized, so far so good
              • POST-ing with this disk with fresh Windows 24H2 installation (done in the M.2_1 socket) in the M.2_2 socket
              02-23-2025, 01:33 PM
            • corrize
              Resonator - quartz broken - how to find the same (same frequency) ?
              by corrize
              Hello, I have a Fujifilm hybrid camera with an issue : the time don't run. I set 12:00 and 3 min later, the same : 12:00
              I saw an obvious root cause : a broken quartz (resonator). But with the box broken, I can't read the marking code. Probably : 464… or A64…
              I found on the web a picture of the same camera board but with marking code very different. Probably : A7…5N
              I'm searching another one for compare…
              Do you have an idea or another way for find the frequency of this resonator please ?
              (I did not found the manufacturer of this component ? And I did not found the...
              03-27-2025, 09:20 PM
            • emeskay
              Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
              by emeskay
              We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
              08-06-2024, 07:13 AM
            • chth96
              How can I test coil whether it is really broken or not?
              by chth96
              I have old game console which have connected to 220v outlet by previous owner and It is not able to turn on.
              I checked continuity of fuse in PSU unit with a multimeter which is shown in the below picture with a orange circle around it, and It seems that fuse became open circuit.
              I also found that as well as bulging capacitor, there is unidentified coil which has residue all over its surface
              I want to replace this round black fuse and unidentified coil if it got broken.
              02-20-2024, 01:07 AM
