rx480 unknown issue
  • curl-os
    • Jun 2021
    • uk
    rx480 unknown issue
    HAVE TWO RX480 ASUS 8GB CARDS, ONE WORKS ONE DOES NOT oops caps, sorry
    doesn't appear to be a short anywhere that i can tell and when powered up voltages get to the ram chips, giving the same values on each testing point on the pcb (around those chips)
    booted into my hive machine to see what it makes of it and it shows no memory size, just memory type (probably pulled from bios chip)
    have plugged it in as secondary in main pc and it boots without drivers but crashes BSOD if drivers are attempted to be used, if drivers are installed then after booting + showing post screen it displays a black screen (on my 1080ti as main [no onboard gpuchip] from then on. have snipped the gpu-z info.
    will upload images in reply, it corrupted when it bsod so I must reboot again
    Any help would be greatly appreciated as I am rather stumped on this one.
  • curl-os
    • Jun 2021
    • uk
    Re: rx480 unknown issue
    post update
    after much poking around, green is bad card (dot means same measurement)
    the up1540p is reading very high on pin 1
    and this would explain the lack of memory showing up anywhere but there being power to it
    I have ordered a cut off a reel from china and will update when it arrives and is installed
    • taxxin
      • Mar 2021
      • 133
      • thailand
      you can go ahead and cancel your order, because i can tell you now that it wont solve your problem.
      I picked up a rx460 that is essentially the same with less cores, memory and power delivery. I got it for aboiut 10 Euros and it had the exact same problem as yours. unrecognised and installing drivers would make it go black screen.
      easy fix i thought, corrupted Bios was my initial guess, so when i received it the first thing i did was desolder the BIOS chip and read its contents, it was all entirely scrambled. so i found the latest overclock version of the sapphire 2gb variety, the trick is to make sure that the bios supports the same brand of memory and ddr class, because there are slight timing differences between brands.
      flashed it in and resoldered the chip and boom, GPUZ shows full details and info, Furmarked it for a few hours and it only got up to about 54deg Cso i used the radeon software and cranked up the power limit and overclock to max and retested it, went up to about 78Deg, i was pretty happy it did great on GTA5 with no lags at all at 1080P.
      So go buy yourself a chip flasher and a hot air station you have your work cut out for you. you can share some of the mining profits with me if you found this helpful
      Successfully completed Repairs:
      Current repairs:
      • dicky96
        Sun Seeker
        • Mar 2017
        • 1825
        • Spain
        HI Taxxin, I am sure someone here is going to get shirty about this comment mate. I imagine you were joking or at least was a very much tongue-in-cheek coment but I bet someone won't have a sense of humour
        It's best not to make comments about payment around here IMHO.
        Follow me on YouTube
        Learn Electronics Repair
        • taxxin
          • Mar 2021
          • 133
          • thailand
          Very fair, thank you for the heads up, everyone in this group has been so giving with the knowledge and expertise. Its only fair that i do the same with others
          Current repairs:
          • bensatrio8
            • Jun 2021
            • 10
            • Indonesia
            Hello, I have similar issue with my powercolor rx580 mining card as the previous owner said that he had no display after flashing bios.
            But when I tried to flash the bios back to stock (from techpowerup) it still showing the same 0mhz like OP.
            I flashed the card both via amdvbflasher and usb eeprom flasher clip, still showing same result. undetected as primary display, error 43 when put to secondary and 0mhz core.
            Is there any possibility for short here?
            Thank you
            • dicky96
              Sun Seeker
              • Mar 2017
              • 1825
              • Spain
              This generally does not work as the external Eprom programmer needs to power up the entire voltage rail that the BIOS chip is on - and it can't
              I would recommend desoldering the BIOS and programming it that way
              Also you could try reading the contents of the BIOS and comparing wit ha known good file (for the same model, same VRAM) but again I think you would have to desolder it first
              • bensatrio8
                • Jun 2021
                • 10
                • Indonesia
                I have 2 cards showing 0mhz,
                powercolor mining rx580 4G:
                I already desolder it and it still gave me same result, will try with another bios files as there's only one in techpowerup.
                this card is not detected when used as primary display.
                Sapphire Nitro rx570 4G:
                gave an error but solved with reinstalling AMD latest driver in win10, datected as primary display.
                It also showing amd error "AMD failed to load driver", restart it and now it showing normal.
                edit: now it back to error43 with no loaded driver, I assume this is related to bad bios chip (unstable).
                Last edited by bensatrio8; 06-14-2021, 02:12 AM. Reason: card back to error 43 again
                • YOUCEF4787
                  Installation Issue with AMD Radeon 520 Graphics Drivers on Dell inspiron 15 3576
                  by YOUCEF4787
                  I am writing to seek assistance regarding a problem I encountered while attempting to install the AMD Radeon 520 graphics drivers on my Dell Inspiron 15 3576 laptop running Windows 10.
                  Upon installing the graphics drivers, my system freezes, and I am left with a black screen. Unfortunately, this issue has prevented me from utilizing the full capabilities of my AMD Radeon 520 graphics card.
                  Laptop Model: Dell Inspiron 15 3576
                  Operating System: Windows 10
                  Graphics Card: AMD Radeon 520
                  Steps I have taken:
                  Downloaded the latest AMD...
                  07-08-2023, 05:23 AM
                • kuba2102
                  Alienware m15 R4 CPU or CPU drivers issue
                  by kuba2102
                  Hi. I had a problem with this laptop that under a load it would crash the system, meaning the screen would go black and unresponsive. I have noticed that CPU drivers surrounding area of PCB has changed colour due to high temperature. I have tried to reball the Drivers, but after it laptop wouldn't turn on at all and it would trigger over current protection in the PSU. I ordered and replaced 3 of of 5 Drivers (3 CPU, 2 IGPU?), and it started producing 1.2V again but just for a second. I get led flashing out the CPU failure code. Now I'm not sure whether there is still a problem with the drivers...
                  01-04-2023, 09:05 AM
                • rounin
                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                  by rounin
                  I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
                  🛠 Original Issue
                  The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                  04-19-2025, 01:18 AM
                • ugamazing
                  Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
                  by ugamazing
                  I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
                  We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
                  12-17-2024, 07:05 PM
                • shahnld
                  Lenovo legion 5 pro startup issue
                  by shahnld
                  Good day Experts
                  I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                  A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                  And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                  08-24-2025, 12:31 PM
