WTF was Dell smoking with this 280?
  • hardwareguy
    • Jun 2006
    • 405
    Just recapped a GX280....all Rubycon and Panasonic except for three Nichicon HNs near the memory slots.
    They must have know something was up with Nichicon or else it wouldn't be filled with Rubycon and Panasonic...so why leave three HNs? Could they not bear to toss them out of the supply bins at the mobo factory?
    Anyway, the three 820uF 6.3V HNs have been replaced with the fixed (2009 dated) version.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: WTF was Dell smoking with this 280?
    i have seen that too.wondered the same thing.iirc both boards i had looked to have been recapped.lazy?
    replacing these fixed the instability and memtest errors.
    • 370forlife
      Large Marge
      • Aug 2008
      • 3112
      I have a GX280 like that too. Panasonics and Rubycon everywhere but 3 HM's under the PCI slot.
      • Topcat
        The Boss Stooge
        • Oct 2003
        • 16958
        Seen a few of those myself. seen it on some gx270's as well, cpu filters were a mix of HN's and MCZ's.
        <--- Badcaps.net Founder
        Badcaps.net Services:
        Motherboard Repair Services
        http://folding.stanford.edu/
        Team : 49813
        Join in!!
        Team Stats
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Capacitors have feelings too you know
          • hardwareguy
            • Jun 2006
            • 405
            Beancounters have feelings too you know
            There; I fixed it for you.
            • kaniki
              • 514
              picking on beans now.. hey, i like beans.. they make me go puff puff...
              • c_hegge
                • Sep 2009
                • 5219
                What's even worse is when manufacturers use a mix of Rubycon and GSC/Sacon.
                • Scenic
                  o.O
                  • Sep 2007
                  • 2642
                  or on hot-running (passive cooled) thinclients: a mix of Sanyo WG and GSC
                  guess which ones caused instabilities?
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • Akhlz001
                    by Akhlz001
                    09-20-2025, 07:15 PM
                  • master3112
                    by master3112
                    07-29-2025, 01:55 PM
                    Dell Thunderbolt Firmware
                    by SMDFlea
                    Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                    Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                    The SKU is in brackets (****)
                    EDIT: NVM65...
                    01-26-2025, 06:22 AM
                  • F R 2568
                    Dell Latitude 5420 does not start (no post) need help to find the reason why
                    by F R 2568
                    Hello all,
                    this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                    I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                    If the laptop is only connected to the AC adapter (battery removed):
                    When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                    The power/battery...
                    01-08-2025, 05:45 AM
