Re: How can I desolder chock coil in PGA370 socket mainboard
I test all of my CPU and CMOS battery, pc100 RAM in other mainboard, confirmed that It surely works. So I installed these CPU,battery,PC100 RAM which I just have tested in other mainboard.
this mainboard(PYRAMID-5) doesn't have connector for PC speaker it only has led and power switch.(I only has PCB of front panel. I lost pin connector and currently I don't have it)
Frankly speaking this mainboard start to boot as soon as I connect PSU 20 pin connector to mainboard When I turn on PSU button.
But When I connect PSU 20 pin connector to mainboard as soon as I turn off PSU button, then I repeatedly turn on PSU button,It doesn't boot anymore.
From PCB of front panel I noticed that third row of solder joint is PSU switch, So I contact third row pin of mainboard connector with ground pin by screwdriver. But it doesn't boot at all..
I just realized that this mainboard is not for SAMSUNG MAGICSTATION of M5317 model but for MAGICSTATION M4325 model.
SAMSUNG MAGICSTATION typically doesn't have any mainboard manual, It only supports audio or graphic driver and booklet for drive installation.
I examined south and north bridge chipset and It is written that
intel R 810
FW82810DC100
F942TD07
SL3P6 intel MC 98
E9245476TA
942 KOREA
Intel FW82801AA
F947TC08
SL3MA
Intel MC98
KOREA
intel R 810
FW82810DC100
F942TD07
SL3P6 intel MC 98
E9245476TA
942 KOREA
Intel FW82801AA
F947TC08
SL3MA
Intel MC98
KOREA
not to mention, caps dont tolerate heat too well. the high heat from the soldering iron can damage the caps. therefore, dont heat up the caps for too long when soldering/desoldering.
so i wish u haeng un eul pibnida (good luck in korean for those who dont speak korean) in your endeavours and do let us know if there is anything else we can do to help u.
