Burnt Hard Drive Board Seagte
  • storexxm
    • Oct 2012
    • 107
    • Vienna
    Hello Folks.
    I did a stupid mistake and switched power Cable between two different cable select power supplys-
    when turned on the pc smoke and bad small appeard.
    when dissambled board i saw the burnt area-
    can i just shortcut those open bridges?
    is there a chance to repair... or put it into trash?
    i have no idea what part where burnt ;/
    hope someone can help me out-
    greetings
  • BL4K3Y
    • Apr 2020
    • 27
    • England
    Re: Burnt Hard Drive Board Seagte
    Clean up the board and see how bad the damage is.
    You certainly need to replace some components and some trace rework might also be needed.
    If you don't have any soldering experience, an easier solution would be to just replace the PCB with a new one.
    • truclacicr
      • Apr 2019
      • 317
      • australia
      Check for shorted diodes nearby.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        or find donor board and swap loader eproms
        Im Back... sort of...
        • storexxm
          • Oct 2012
          • 107
          • Vienna
          I am just curios if it is possibe to repair...
          on the easiest way.. just to replace the burnt pieces
          and look what happens..
          does someone know whats these are.. ? diods ? resistors..?
          there are no values where i can look up
          • noppa
            • 41
            This may help
            http://www.hddoracle.com/viewtopic.php?f=100&t=86
            • federalhouse
              **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
              by federalhouse
              I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
              **Background:**
              I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
              **What I've Tried So Far:**
              1. I accessed
              08-01-2024, 07:03 PM
            • karto95
              Repairing a Seagate hard drive with damaged logic board
              by karto95
              I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
              I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
              If anyone has any suggestions or experience with this...
              03-21-2023, 04:05 AM
            • tmcw
              PC case - Hard drive rails
              by tmcw
              A friend gave me his old PC case (with MB, and PSU), but no hard drive rails, he said he only used the 2.5" SSD spot inside, and used an external hard drive for data. He said that he'd have a look for the supplied rails, but I doubt he'll find them.
              So I was wondering if case manufacturers used any type of standard 3.5" hard drive rail?
              I'm used to the various Dell hard drive caddies or rails (and HP and Lenovo to a lesser extent), or el cheapo cases where you screw through the frame to fix the drive.
              Now, the case is a CiT Gaming Case, and...
              05-22-2022, 12:04 PM
              External hard drive/cd rom enclosure-printer port interface recap power supply board
              by sam_sam_sam
              I going to modify the enclosure to except the new USB 3 interface
              The 3.5 enclosure do not have internal switching power supplies and use a small switching wall wart power supply really
              I need a cd rom drive for my new computer and do not want to use a 2.5 cd rom drives
              The switching power supply in the old enclosure has nice heat sinks and has a cooling fan in the enclosure that is the main reason why I want to repurpose for this project
              https://www.ebay.com/itm/231205428647
              I will post some pictures of it when I get the usb 3 to IDE...
              04-08-2023, 05:42 PM
