Dangerous chinese power strip kills motherboard, is it fixable?
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Hello.
    Some time ago, we had an issue at the company that I work for.
    Someone tried to move his stuff to a nearby desk and upon reconnecting power strip to mains there was a loud noise and some sparks.
    Then the power breaker tripped.
    Upon investigation, found that the ground wire was cut inside the power strip, so all the devices were running non grounded all this time and then, when the employee tried to move his computer, the floating ground wire came in contact with Live.
    The following parts were dead after this:
    1x Dell 24" Full HD monitor (that's where the flames came from)
    1x expensive mechanical keyboard
    and the motherboard of the computer got a hole on its HDMI IC.
    The motherboard is Gigabyte GA-B85M-HD3 Rev 1.1
    https://www.badcaps.net/forum/attach...1&d=1601940425
    The HDMI IC with the hole in the center is PTN3360DBS.
    The IC has been succesfully removed but motherboard still not working.
    When connecting psu to mains, fan tries to spin then stops then retries then stops again, then gives up.
    I checked with multimeter and found that it appears that 3.3V is shorted to ground and same goes for 12V.
    On the contrary, checked 5V, 5Vsb and -12V and they seem to be ok.
    My experience in troubleshooting mbs at this level is limited.
    Do you think mobo is a goner?
    Should I try to remove other components that might be shorted, hoping that at some point the mb wont appear shorted anymore and then I will have been able to spot what causes the short?
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: Dangerous chinese power strip kills motherboard, is it fixable?
    Additional info:
    Psu survived (Corsair VS450 CWT version)
    SSD survived (Samsung EVO Sata)
    RAM tested on different computer and working
    CPU tested on different mb and working
    Also, would like to mention that the measurements I took with multimeter and found 3.3V and 12V rails shorted to ground, were done with CPU removed.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8703
      uh no.
      Unless it passed a surge or the power supply was garbage to begin with, a power strip won't kill computers.
      The former, the surge/lightning was ultimately responsible, and the latter, the power supply is responsible.
      • 6BW6
        • Jan 2015
        • 55
        I had a computer that kept crashing.... nope, not virus nor malware nor the computer but a BT phone charger - made in China, this did fool me, you go fearing and looking for the obvious.
        This only came to light when I noted the racket on a portable FM radio. I sawed the charger open, mains AC in to a fuse into a bridge rectifier, out came 340V DC appx. (ac input voltage x 1.414 = dc out), this went to a 4.7uF 500V capacitor a tiny RF choke, about the size of a 0.125 W resistor.... 2 or 3mm diam. would they be? Then into a 2.2uF 500V capacitor - that's it all the filtering there was, all hell broke loose when one leg of the 4.7uF capacitor became a dry joint with cracked soldering - cold joint in the trade.
        The time I wasted.... the computer never crashed after I 'pulled' it. Thanks BT for making such crap under YOUR license. These things supposed to have standard of quality - damned BT what a cheap skate company.
        Dave.
        • edugimeno
          Finding the wrong part at a loooong led strip, part works fine, part flickers, all parallel...
          by edugimeno
          Hi There!
          I'm trying to help my friend who owns a restaurant be just bought.
          He has a very long LED strip running along all the walls and columns. The strip is attached facing down 2in above the floor, using a wall panel that ends in a metal rail that finishes the panel underneath
          It's stuck using, I guess, the 2 sided tape that comes with the strip
          The issue is that like 1/2 of the full length, including 1/2 one wall, another entire wall, and one column, flickers after 4 or 5 minutes ON. Particularly it flashes staying OFF most of the time and flashing ON for 1 tenth...
          09-05-2024, 09:34 AM
        • adelage
          220v Led strip flickering
          by adelage
          Hi, I am installing a long led strip and I noticed that it frequently flickers slightly, it is not a strong nor regular thing, but it is noticeable and annoying. I have measured the voltage of the mains and it shows some fluctuations, it normally stays at around 226v, but often (every few seconds) drops down to 218/219v), and the flickering happens exactly at the same time. I have measured this at the counter and with every appliance off, so it's not related to the house electrical system, but that's how it comes from the supplier.
          I know that the best solution would be to get a voltage...
          11-03-2024, 09:49 AM
        • benareeno
          Adjustable dc power supply and tcl led strip
          by benareeno
          I wonder if i shorted the whole strip...where to put pos and neg to just light up a single diode...or the entire strip. The strip lit for a second...so maybe i fried it? What say you?
          I have an adjustable dc power supply and was trying around 9 volts.
          I have a pic of a single diode...where to put pos and neg terminals to light it up?
          Pic of middle of strip..is this where i light the entire strip?
          And pic of end...or does this light the entire strip?
          Where to put pos and neg for single diode..multiple diodes and the entire...
          07-11-2021, 02:31 PM
        • mikey5791
          Need help replacing led strip on Iiyama Prolite XUB2390HS monitor
          by mikey5791
          Got this working ips led monitor by the brand of
          Iiyama Prolite XUB2390HS presumably a 23 inch type given to me with suspected bad led backlight. To test it, i unplugged the bad flat ribbon type connector and plugged it a good flat ribbon led connector scrapped from a HP Pavillion 27cw (led strip with 60 led). Good news is the HP led strip lights up but not fully, in between there are about 15 unlit leds.(as picture attached shows).
          Fyi, i had not opened and removed the old bad led strip. My question is whether is it possible to cut some of the extra leds(say...
          09-04-2023, 03:50 AM
        • valente222
          help SG2701B01-7 panel chinese, would this integrated circuit be equivalent? Chinese IC CS601C regulator.
          by valente222
          Hi, I'm repairing this Chinese SG2701B01-7 panel. There isn't much information about it. The original part for the panel is a CSOT CS601C regulator. I can't find anything commercial on Aliexpress; there's only the CS601 without the final 'C'. They claim it's a variant. But will it be compatible? Well, my diagnosis on this screen is a video problem; the image is practically black, although there is HDMI communication. The LED light is on (backlight), but there is no VGL, no 3.3V, and no VSS. It seems that this IC is the one controlling these voltages. The monitor worked correctly for a moment and...
          05-12-2025, 03:42 PM
