A7N8X-X Ver 2.0 -A02
  • Stray-Dog
    Cap challenged
    • Nov 2009
    • 12
    Re: A7N8X-X Ver 2.0 -A02
    I can get these from this site;
    Rubycon - 1000uF 6.3v MBZ 8mm 12mm
    But I'm not sure about the others.
    I read the recapping your own motherbaord page and noticed the mention of voltages and how those can and cannot be substituted, but do the dimentions of a capacitor make a difference? or can I substitute a larger size?
    • ratdude747
      Black Sheep
      • Nov 2008
      • 17136
      you can fudge diameters... be aware if the lead spacing is different, you will have to elevate the cap and bend the leads... it will be a bit ugly but is perfectly safe... bare metal is fine as long as nothing shorts it. if bare metal freaks you out (as it does for some), just strip some wire to the lengths you need and use the stripped insulation.
      sigpic
      (Insert witty quote here)
      • c_hegge
        • Sep 2009
        • 5219
        I do it all the time (change diameters). I often have to do it for Fuhjyyu PSU caps as no other brand makes the same capacitance/voltage in the same size. It works just fine.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          They are right.
          As long as the specs are good and it will physically fit the diameter doesn't matter.
          There is a slight concern when they are crammed in too tight somewhere [packed in with other caps or with loads of wires] about no air flow and over heating them.
          Like I said it's a small issue, but if they are packed tight I much prefer waiting until I find/get the right caps to using bigger caps just to done with it.
          Mann-Made Global Warming.
          - Dr Seuss
          • Stray-Dog
            Cap challenged
            • Nov 2009
            • 12
            ok, thanks guys
            • RJARRRPCGP
              • Jul 2004
              • 6304
              I see that the middle RAM slot is being used.
              At least with my A7N8X-X, I cannot, or it will be unstable! I think that caused a bug check, because it rebooted before Windows completed the boot.
              When I had RAM in the middle slot, it was no more stable than Charles Manson.
              ASRock B550 PG Velocita
              Ryzen 9 "Vermeer" 5900X
              Arc A770 16 GB
              eVGA Supernova G3 750W
              Alienware AW3423DWF OLED
              • howardc64
                by howardc64
                07-24-2025, 05:17 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • Hakuu
                by Hakuu
                Hi There,
                More Details
                TV Model - LG OLED77G1PUA
                07-12-2023, 02:37 PM
              • Rayblaster
                HP RP7 RP7800 from 2012/2013 worst fault - has "character"
                by Rayblaster
                Hello friends, I've got a nice toy to play with - it is an HP RP7800 All-in-one POS system. I got it for free and it has one problem - it turns on very rarely, and just for a few seconds. After that it dies and doesn't come on if I don't leave it unplugged for at least 2 hours. I've repaired motherboards before, this is not my first one, but problem with these types of faults is that everything you check on the board will usually be fine. This is the case for me here.
                I dissassembled it completely, and got my hands on the motherboard. Model No. is PIQ67H/Higgins 11047-I 48.3GD02.011....
                12-30-2024, 06:28 PM
