help ID Soyo P4VTE MOSFET and cap?
  • macgyver
    • Nov 2009
    • 7
    This is a Soyo (SY-)P4VTE motherboard that got screwed over by a bad video card. The card was inserted and had a short, which burnt out a MOSFET and blew a small capacitor near the AGP slot. The board powers up fine, but of course doesn't post or power up video.
    The MOSFET in question is a Niko Semiconductor P3055LD, basically an N-channel 25V/12A model in To-252 packaging. The datasheet is at http://datasheets.ru/datasheets/3932...a-P3055LD.html. I've been unable to find it (or an equivalent) at Mouser Electronics, DigiKey, or Jameco. I e-mailed all to get either no response or simply "can't help you". I've also got a message in to Niko Semiconductor (http://english.niko-sem.com/in/front...CompanyProfile) at all the contacts they've listed as they don't list a technical contact and don't appear to deal with the US directly. Incidentally, Niko appears to make a P3057LD with the same specs.
    The blown cap, marked CB26 on this board, is unidentified and long gone. I *do* have another of these boards, but it's simply a brown surface-mount cap with no markings on it. How can I (non-destructively) measure capacitance to ID it? Can I make measurements while connected on the working, good board?
    I'd appreciate any help identifying these components and equivalent substitutes I can get in the US.
    Thanks in advance!
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: help ID Soyo P4VTE MOSFET and cap?
    http://cgi.ebay.com/ws/eBayISAPI.dll...m=330369964185
    For the cap, if you don't want to pull it to measure.
    Trace the circuit.
    If nothing is in parallel you can measure it where it is.
    Mann-Made Global Warming.
    - Dr Seuss
    • richr69
      • Jul 2010
      • 58
      The alldatasheet website is your friend See http://www.alldatasheet.com/view.jsp?Searchword=P3055LD.
      • richr69
        • Jul 2010
        • 58
        Sorry about that, you already have the data sheet on the MOSFET. The website is still a good resource.
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          All bypass caps in digital systems are 100nF. Since this cap you are talking about is near the power MOSFET so it's in a power supply, it's a no-brainer. It is 100nF no doubt about it.
          A working TV? How boring!
          • tofik
            MOSFET equivalent K8A60DA
            by tofik
            Hello guys,
            I have a shorted MOSFET K8A60DA with the following characteristics:
            Type Designator: TK8A60DA
            Marking Code: K8A60DA
            Type of Transistor: MOSFET
            Type of Control Channel: N -Channel
            Maximum Power Dissipation (Pd): 45 W
            Maximum Drain-Source Voltage |Vds|: 600 V
            Maximum Gate-Source Voltage |Vgs|: 30 V
            Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
            Maximum Drain Current |Id|: 7.5 A
            Maximum Junction Temperature (Tj): 150 °C
            Total Gate Charge (Qg): 20 nC
            Rise Time (tr): 25 nS
            Drain-Source
            07-19-2023, 05:18 AM
          • dreico33
            AON7403 Mosfet Equivalent
            by dreico33
            Hellow guys,
            I am trying to replace an AON7403 Mosfet but i dot not have in my stock the same. So i wonder if there is any equivalent to this Mosfet.
            Thank you very much.
            11-16-2024, 09:28 AM
          • Jane
            How do you test MOSFET in laptops ?
            by Jane
            I tried to use this method:
            Testing an N-channel MOSFET:
            Step 1: Discharge the Gate (turn off the MOSFET)
            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
            Step 2: Charge the Gate (turn on the MOSFET)
            Now, place the red probe on the Gate (G) and the black probe on the
            09-27-2024, 03:31 AM
          • mohamed mm
            looking for equivalent mosfet for (IR3598MTRPBF)
            by mohamed mm
            I'm looking for an equivalent dule mosfet for (IR3598MTRPBF - Dual MOSFET Driver, High Side, and Low Side, 4.0V to 13.2V Drive voltage, 20 ns delay, QFN-16)
            it's for motherboard ram voltage.
            I hope someone can help me.
            Thank you.
            11-01-2023, 07:28 AM
          • jackx
            equivalent MOSFET 4C09B
            by jackx
            hello brother
            i need equivalent MOSFET 4C09B
            05-27-2024, 03:41 PM
