component identification
  • torla
    • 76
    what is this component
    SJA 6 pins.
    https://ibb.co/5F1xqhX
    https://ibb.co/H2p4zJk
    https://ibb.co/zm7M3fj
    https://ibb.co/Xxhbv3F
    thx
    • 31246
    Re: component identification
    RP152L009B
    maybe
    • torla
      • 76
      mayybe this
      LP38690SD-5.0/NOPB
      • R_J
        • Jun 2012
        • 9606
        Originally posted by torla
        mayybe this
        LP38690SD-5.0/NOPB
        They all look like the same ic, but some are fixed voltage out and some are adjustable, If you get it wrong you will damage whatever it supplies. This is not the TI product but might be a Richtek product with a custom number. or some other China manufacturer
        • Tomylee
          Identification of Component T5 on NEXIQ USB-Link 2 (damaged due to crushing)
          by Tomylee
          I'm currently repairing a NEXIQ USB-Link 2 that was physically damaged due to crushing. After a thorough inspection, it appears that only one component is visibly damaged: the T5 component, located right next to the Mini-USB port.
          It's a 4-pin SMD component, with one pin at each corner, aligned front-to-back along the USB port axis. Unfortunately, it is broken, and there are no visible markings left on the part to identify it.
          I'm looking for help with the following:
          The exact identification or part number of the T5 component
          05-28-2025, 12:42 PM
        • FZG
          Magicshine MJ-906B Bike Lamp - Faulty Component Identification
          by FZG
          Hi, my neighbor gave me a faulty bike headlamp (Magicshine MJ-906B) and asked if I could have a look at it. I opened it up and saw a blown-up component, likely some kind of transistor. The writing on the component looks like "AG5V" but I can´t seem to find any information on this component. Does anyone know what it could be? Also it seems that someone else had worked on the device before (the battery wire soldering looks bad) but since it worked until recently that´s probably unrelated... Any help would be appreciated....
          10-14-2025, 07:58 AM
        • rddube
          HP envy 13aq1001-ca 13.3 motherboard component identification
          by rddube
          Trying to identify what the component pointed by the arrow is for a HP Envy 13aq1001-ca motherboard for which I can't find the schematics nowhere. It is marked Q61010 on the silkscreen and the component is marked V74 14 01 X917.
          Anybody have an idea what this component is?
          It is shorted on a few of its legs....
          09-10-2025, 05:36 PM
        • Maniackk
          Reader PocketBook InkPad 3 – identification of a black component marked 'CT' on the microUSB line
          by Maniackk
          Device: PocketBook InkPad 3
          Mainboard: XRZ_E091_PB740-VTTOA-V1.1 / 2017-10-12
          I'm replacing the broken microUSB connector on this e-reader, and during inspection after desoldering, I noticed a loose black SMD component marked "CT". One of them was torn off along with the pad, while the other one (marked in the photo) is still in place.
          I would appreciate help identifying this component.
          Measuring the loose component with a multimeter gives 5.84 MΩ in both directions, while the one still on the board shows no measurable...
          05-16-2025, 08:53 AM
        • Shulgin
          Acer predator XB241YU Component identification
          by Shulgin
          I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
          After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
          In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
          I...
          05-11-2024, 11:06 AM
