i need some help with diagnosing an australian "DD" imac power supply (Part number to follow when i find it's case)
Pic
I have replaced all the caps indicated, all of them had visibly failed, but the iMac still has the same problem it started with-
When plugged in to the midplane, the 5VSB is fine, but the 2nd led flickers and goes out when power button is pushed. (Single flash ~50msec duration) This is accompanied by a small high frequency squeak from the PSU.
I bench tested the PSU, i get +5VSB and +23V, but the power supply keeps turning on and off every second or so, giving a single squeak each time.
The rails all get power, the multimeter reading indicates that there is voltage on 3.3, 5 and 12 but due to the PSU turning off so quickly the readings never stabilise on the meter.
Is there a protection circuit that is kicking in? a bad diode to check? i would really appreciate a hand with this one.
i had a look at other threads but the only thing that is mentioned is ZD4, mine is fine.
thanks guys.
Matt
Pic
thanks guys.
Matt
