Club3D HD7950 (aka R9 280) 3GB strange issue
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    As the title says, I bought a HD7950/R9 280 (they're the same card) for cheap ($16) and it exhibits a strange issue:
    Plugging the card in ANY computer (I tried it with two good PSUs that had 2x6pin 12v connectors and it does POST) will yield no signal over HDMI or DVI. However, the card does POST fine as I can hear the BIOS beep once (which means everything's okay) on my GA-EP45T-DS3R, but neither HDMI nor DVI ports will output anything.
    The only difference I noticed over the two is that using a Samsung P2270HD LCD, the messages between HDMI and PC (which is VGA because I am using a DVI-I to VGA adapter) differ - I get "No Signal" on HDMI, while VGA will say "Check cable connection". If I unplug the HDMI, I get the same message as the VGA connection, so it looks like the card DOES send out something to the LCD.
    I even tried it on a UEFI based motherboard (ASUS H61M-A) without any luck, the same happens. (evidenced by the onboard HDMI/VGA/DVI-D combo being disabled altogether)
    What should I do? I tried various LCD monitors to no avail.
    Should I try a second reflow? The card does show signs of being reflowed once, though I fear that might make the card not POST anymore.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: Club3D HD7950 (aka R9 280) 3GB strange issue
    Dead GPU.
    • Dan81
      SNES-powered
      • Oct 2013
      • 1866
      Originally posted by piernov
      Dead GPU.
      Then how come it still POSTs and gets recognized by Windows just fine?
      Main rig:
      Gigabyte B75M-D3H
      16GB DDR3-1600
      Delux MG760 case
      • Uranium-235
        Comrade Glimmer
        • Aug 2007
        • 5042
        • US
        different part of the silicon is damaged likely. the PCI-E lanes for processing and motherboard communication are fine, but the other side for video output are damaged. Yes, they could be unballed. I'm not sure how the R9 handles output, if it's direct from the GPU or there is another chip handling switching monitor outputs. Could be different per card really
        • Dan81
          SNES-powered
          • Oct 2013
          • 1866
          Have reflowed it just today with new flux, still same thing.
          Maybe miniDP works? It's the only thing I haven't tested due to no adapter.
          Main rig:
          Gigabyte B75M-D3H
          16GB DDR3-1600
          Delux MG760 case
            master hoarder
            • May 2008
            • 12175
            It's dead [GPU chip], Jim.
            I have numerous cards that do the same thing: PC POSTs and some of the cards even wake up the monitor on analog and digital output, but display nothing.
            The HD7k and R9 cards are very failure-prone.
            Reflowing it with flux is pointless, because it's not the BGA that fails on these cards. It's the GPU die to GPU substrate connections/BGA. Just re-heating it to normal reflow temperature will accomplish the same task (and often that means accomplish nothing.) So don't waste your flux.
            I have a dying R9 290 that also needs a reflow (works OK in Windows without drivers, errors out as soon as drivers are installed), but I'm not very hopeful it will work. Most likely will just pull its fancy heatsink to install on another video card.
            • Dan81
              SNES-powered
              • Oct 2013
              • 1866
              Well, as a last resort, I might blast it with 550*C for more than 3 minutes (all caps are polys) and see if anything happens.
              Thing is, on my card, Windows does install drivers just fine.
              Main rig:
              Gigabyte B75M-D3H
              16GB DDR3-1600
              Delux MG760 case
                master hoarder
                • May 2008
                • 12175
                Is that with another card as the boot/main card?
                If not, and you're using the 7950 as the main card, and it boots and installs drivers OK without crashing, then try it on another PC to see if you get the same results. Also make sure you're using the "latest" drivers from ATI and maybe even try an older more "legacy" driver, just in case.
                Well, really do save that as a last resort.
                I just blasted a stubborn HD5750 that continued to artifact in a weird fashion, even after the first reflow. So the second time I upped the heat too much and popcorned the GPU chip. Result: GPU V_core, RAM Vdd, and GPU Vtt all shorted to ground. I didn't even bother to try powering it on, as I'm sure at best it won't work (and at worst, the GPU VRMs will obliterate themselves and fumigate my room with magic smoke - no thanks!) In fact, there was even a small ball of solder ball that had splatted from under the GPU chip die. Ooops! I really gave it too much heat, as I didn't want to see it artifacting a third time. Either it was going to be "showtime" or the morgue for this card... and unfortunately it was the latter. :\ Kind of a shame, as it would have been a good low-mid-range card for my needs with fairly low power consumption (only 86 Watts TDP, vs 105 for the HD5770.)
                • piernov
                  • Jan 2016
                  • 4437
                  • France
                  Hot air: 200°C max on the die, 2min
                  Oven: 200°C max, 8min, aluminum foil all around the card except GPU
                  Not a fix, dead is dead.
                  • aliougm
                    Marantz SR4003 AVR HDMI board issue, seeking for help
                    by aliougm
                    I have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
                    Connection as below:
                    Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
                    If I bypassed AVR then HDTV screen color be good.
                    I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
                    3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
                    I replaced all...
                    04-30-2022, 12:21 PM
                  • ratdude747
                    Intel HDMI Windows 10 issue
                    by ratdude747
                    Got my butt kicked by windows 10 and intel last week.
                    I have an HDMI switch and splitter setup for an AV rig (church) that I was trying to use the windows 10 half of my Lenovo T440s with. However, the audio will not work; HDMI (displayport) audio doesn't show in device manager and Intel's Control Center shows the external display as not supporting audio. Direct connect it to things and (if memory serves) it does work.
                    Compounding the issue is that I'm forced to use Lenovo's drivers... as the generic intel ones refuse to install as they detect it's a lenovo system...
                    12-04-2022, 07:34 AM
                  • sebulica
                    Asus FX705DT eDP and HDMI output issue
                    by sebulica
                    Hi
                    I have an Asus FX705DT that had waterdamage....a lot
                    I have managed to make the motherboard look like working but i stil have some issues and maybe someone can point me in the right direction.
                    The laptop has a destroyed keyboard and the display is dead but i have managed to make the board start up and work "normal"...i have no short,power rails are looking good,hdd/ssd activity and so on.
                    The problem is that there is no HDMI output,only sometimes makes the tv/monitor go black screen for a brief moment,and on the internal...
                    04-06-2023, 04:44 AM
                  • Ado02
                    Dell Latitude 5510 USB-c Hdmi Issue
                    by Ado02
                    I am working on a Dell Latitude 5510 - the USB-c port has not HDMI output. The port works for data transfer and charging but not for HDMI.
                    I check the USB-c port but can't see any damage.
                    Has anyone experienced this problem and found a solution?
                    04-05-2023, 02:55 AM
                  • japlytic
                    Certain DisplayPort-HDMI cables can disable HDMI CEC communication
                    by japlytic
                    With a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
                    An examination of the HDMI CEC wiring...
                    07-10-2022, 09:48 PM
