Chaintech GeForce4 Ti4200-8x 128meg
  • OldeCrow
    • May 2005
    • 18
    Here's some more show and tell
    I have some surpluss nvidia heatsinks so I already replaced the dead Chaintech HSF and i have a pair of these cards one serial number after the other both bad at the same two pair of caps.
  • bushytails
    Moderator
    • Dec 2004
    • 217
    Re: Chaintech GeForce4 Ti4200-8x 128meg
    Want to sell one of them? I could use a dual-head card... I'd prefer a Radeon 9200 though. (yes, 9200. NOT anything with a bigger number). but if the price is right, I'd live with an nvidia card.
    --Randy
    • OldeCrow
      • May 2005
      • 18
      well if either of them actually work when im done maybe we can work something out
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        that is an interesting pic you have there. cap has vented with some force so i am thinking that those are normal electrolytics and not polymer. those type of caps are annoying though, it is impossible to identify who made them. if you recap it see if there is some info on the bottom of the cap. i would like to see one of those caps cut and unrolled also.
        did the other card have the same position cap vent exactly the same? it would indicate more stress at that position.
        the voltages are crazy also 10v???. agp=1.5v i guess those caps were cheapest for them to get.
        they look like radial lead rather than chip type so i guess recapping will be easy. looking forward to seeing pics of the recapping. i think all those caps will have to go.
        • bushytails
          Moderator
          • Dec 2004
          • 217
          I was thinking before they're fixed, to save you time and me money.
          --Randy
          • OldeCrow
            • May 2005
            • 18
            yup they are all going to get replaced
            the 470s that are paired up in the photo are the ones that seem to split, the other card has the other 470 split and one of the 1000's is bloating on the one in the photo. and your right they are radial lead not surface mount so they wont be too much trouble ..
            • OldeCrow
              • May 2005
              • 18
              all the paired up ones are in parrallel too so i may just replace them with single 1000uf caps for the paired 470's and a 2200uf for the pair of 1000'sand test it out ..
                by momaka
                03-12-2025, 03:42 PM
              • flibidy
                Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                by flibidy
                I have here a Magnum IA.100 which belongs to my parents.
                The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                What Ive done........
                01-01-2025, 01:26 PM
              • howardc64
                TCL 49S405 double image
                by howardc64
                LCD displays a 2nd image slighty offset vertically. And multiple pairs of black lines along the bottom. Probably common as google "TCL 49S405 double image" pulls up this ifixit post ( link ) with identical ( nearly, but their fault seems to be on the other half of the panel than mine ) problem without solution.
                This one looks to be a more difficult to diagnose because most? of TCON seems integrated ( CSOT BGA on buffer baord) into the left panel edge board ( looking from rear of TV) There are 2 buffer boards for each 1/2 of the screen. Main connects to the left buffer board...
                06-23-2025, 03:20 PM
              • budwich
                ESD Diode on HDMI output of Yamaha a1050 RCVR
                by budwich
                I lost one of the two hdmi outputs on a yamaha rx-a1050 receiver. Of course, it is the hdmi1 which has the arc capability which was useful. The second output hdmi works OK.
                I got an hdmi breakout board which gave me access to the "little guys" in the hdmi. I did some gross DC voltage measurements to ground and found that the Data1 pair (4 and 6) had a lower voltage than the working hdmi.... 1.1v versus 2.9. All others pins seem to be OK. Further when plugged into a display, there is no video but a message on the screen which I assume is the display's status for the...
                09-11-2023, 12:21 PM
                Copy DMI info easily with Hex editing software and Macro script
                by SMDFlea
                Copying DMI information from an old bios to a new one is difficult for some members, often they have no experience with a hex editor,or some that have tried find it too hard.There is an option to make things easier for those members so that they don`t need to post their own bios backup for the DMI copying.
                Experienced bios modding members can help by posting in other threads the DMI offsets,macro script generated by the software and a download link to the software at softpedia mentioned in this guide,or post your macros in the comments here with a link to the bios request thread ....
                02-28-2023, 02:14 PM
