Bfg Bfgrnf4u
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: Bfg Bfgrnf4u
    From what I could see in that picture, in the first one I saw some small fujiyuu's to the left, the big one in the middle looks like a fujiyuu, but had the same style font as asia-x, and fujiyuu dosen't have a A after the I, so it must be. The one next to it is a teapo.
    You should recap it or get a newer, more reputable power supply.
    • Dustmaker
      • Jun 2009
      • 5
      Re: Bfg Bfgrnf4u
      I put in a new power supply but am having the same response, which is no beeps. The fans come on. The hardrive light comes on and stays solid and that is were it sits.
      If I diconnect the hardrive before turning the system on, then all I get are the cpu and chipset fans running.
      By the way. Thanks for all the help so far.
      • Dustmaker
        • Jun 2009
        • 5
        Re: Bfg Bfgrnf4u
        Three different new power supplies and still no change.
        • lucky13
          • Aug 2007
          • 412
          Re: Bfg Bfgrnf4u
          Did you check the CMOS battery?
          Tried to reset the BIOS?
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Re: Bfg Bfgrnf4u
            maybe you have 3 bad power supplies
            brand/ model of them please
            sigpic
            (Insert witty quote here)
            • Scenic
              o.O
              • Sep 2007
              • 2642
              Re: Bfg Bfgrnf4u
              btw... is it just me or wth is going on..?!
              i keep reading "big bang4u" as the topic every time i stuble across this thread.. o.O
              lol
              • ratdude747
                Black Sheep
                • Nov 2008
                • 17136
                Re: Bfg Bfgrnf4u
                odd... id think having german as a ntive language would do that, but i speak some german my self (first year of it completed in high school, ill resume next month...
                so
                sigpic
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Re: Bfg Bfgrnf4u
                  I've only heard bad things about BFG products.
                  Everything from Sacon FZ caps on video cards to caps loose and rolling around in the box as new. [More than one instance of both.]
                  I won't buy their stuff.
                  Mann-Made Global Warming.
                  - Dr Seuss
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    #29
                    Re: Bfg Bfgrnf4u
                    PCBONEZ; aww, now your gonna make Jonnyguru sad
                    • Newbie2
                      • Sep 2005
                      • 885
                      Re: Bfg Bfgrnf4u
                      In my opinion BFG isn't so bad, it depends on the product that you buy from them.
                      I had a BFG NVIDIA GeForce FX 5500 256MB AGP 8X video card back then, factory overclocked to 290MHz (the FX 5500's stock speed is 270MHz). It had green 8mm Taicon 1000uf 6.3V caps. Those caps were still good, but I decided to replace all of the Taicon caps with Nichicon HE series 1000uf 6.3V 8mm caps. It's been retired from my own use a long time ago, but I still have it and it still works great.
                      Also, its stock fan/heatsink was replaced with a slightly larger and better looking fan/heatsink from a dead XFX NVIDIA GeForce FX 5500 video card.
                      My gaming PC:
                      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
                      ASUS M4A77TD AMD 770 AM3 Motherboard
                      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
                      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
                      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
                      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
                      ASUS Xonar DG 5.1 Channel PCI sound card
                      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
                      Antec Three Hundred Mid-Tower Case
                      Microsoft Windows 10 Pro 64-bit
                      Microsoft Windows 7 Ultimate SP1 64-bit
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Re: Bfg Bfgrnf4u
                        Well that's jonnyGURU's problem isn't it.
                        - Dr Seuss
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Re: Bfg Bfgrnf4u
                          Use BFG if you want to. I don't need the extra trouble.
                          I have enough to do already.
                          http://www.taicon.com.tw/product/en-index.htm
                          [ See upper left corner. ]
                          Taicon is affiliated with Nichicon so for all we know your old caps and your new caps came out of the same factory.
                          Taicon -labeled- caps don't necessarily get [or don't -always- get] Jap' procured Aluminum and electrolyte as specified by Nichicon for the Nichicon branded caps which is why Taicon isn't as consistent or reliable as Nichicon. Presumably, when they -can-, Taicon will use the 'good stuff' in their own branded caps, so, Taicon can be assumed to have good runs and bad runs of caps. Problem is at our end there is no way to know which you got. [Unless they fail of course.]
                          - Dr Seuss
                          • ratdude747
                            Black Sheep
                            • Nov 2008
                            • 17136
                            Re: Bfg Bfgrnf4u
                            quote from site:
                            "Best Viewed with Internet Explorer 4.0 . The best exploring resolution is 800x600."
                            im not kidding:
                            Bullshit. not only do the caps suck, so does the site. at least teapo has a decent site (when it isnt being reported as an attack site )
                            sigpic
                            • 370forlife
                              Large Marge
                              • Aug 2008
                              • 3113
                              Re: Bfg Bfgrnf4u
                              Interesting, teapo has a pdf you can download that shows you comparable series from other manufactures to their series.
                              They have nichicon, rubycon, panasonic, NCC, capxon, ost, lelon, ltec, elite, elna, and samxon.
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                Re: Bfg Bfgrnf4u
                                800x600? ie4? OLD SKOOL!!!
                                sigpic
                                • bauto601
                                  Chaintech Apogee 7VJL Unstable
                                  by bauto601
                                  I'm having a problem with a rather old board, a Chaintech Apogee 7VJL.
                                  The pc setup is:
                                  - Athlon XP 3000+ (175x13)
                                  - 3x 512MB Corsair XMS PRO @350MHz
                                  - ATI Radeon X1950PRO AGP
                                  - Chaintech Apogee 7VJL
                                  - Levicom VP550 (with an acrylic top, is actually fairly decent and recapped
                                  on the secondary side with Panasonic caps)
                                  - Club3D Theatron sound card
                                  - USB 2.0 card with ALi chipset
                                  - 2x 40GB Seagate HDD's
                                  - 2x CD/DVD Combo drive
                                  - 1x Floppy drive
                                  Now,...
                                  10-29-2019, 10:05 AM
                                • Gwynz
                                  First time recapping a motherboard, need advice!
                                  by Gwynz
                                  Hey guys, I just picked up an old Athlon motherboard (Chaintech 7AJA2) to build a vintage PC system around and noticed it had a leaking cap and a few others that appear to be bulging
                                  It does boot up fine though, just finished installing Windows XP and it ran through a few 3dfx demos successfully (using a Voodoo3 3000 AGP card) but it does seem to have issues when I have more than one stick of RAM installed, should I also change out the little squat capacitors that are around the DIMM slots even though they appear fine?
                                  04-04-2022, 11:44 PM
                                • Newbie2
                                  Chaintech Volari V3 128MB AGP
                                  by Newbie2
                                  I got this old Chaintech Volari V3 128MB AGP video card, and it has 6 TEAPO 1200uf 6.3V SC caps on it. None of them are bad yet, but this is a preemptive recapping that Topcat recommends. The problem is, that when I try to desolder the old cap out with my soldering iron, the positive lead comes out fine, but the negative is stuck in there that I couldn't get it out. I tried wiggling the cap out of the negative hole with the soldering iron touching the lead's little solder area, but the lead from the cap broke, leaving a piece of its lead stuck in the video card, since the lead...
                                  08-06-2007, 07:08 AM
                                • Dan81
                                  Help with Chaintech system
                                  by Dan81
                                  Okay.I've got here a old Chaintech MPM800-000LE motherboard.I don't know what CPU it has.All good and nice,hooked most of the cables up....except the front panel.It doesn't write anywhere how to wire it up.Anybody can help me?
                                  Sorry if I posted in wrong section.
                                  01-12-2014, 04:23 AM
                                • Per Hansson
                                  HardOCP Seasonic S12 II 500w PSU Review
                                  by Per Hansson
                                  To say that Seasonic makes good PSU's is an understatement, I really like their regular S12 and this one only improves upon it.
                                  Rubycon 400v bulk cap and Nippon Chemi-Con for the secondary side, plus one solid cap on the +12v rail (I think it's an NCC too but difficult to make out.) That rounds up their excellent choices of capacitors.
                                  It actually performed better than Seasonics own specs, which in the PSU world is pretty much unheard of. Head over to Hardocp to read their review of it.
                                  07-17-2007, 02:42 PM
