Chaintech Apogee 7VJL Unstable
  • bauto601
    • Sep 2012
    • 103
    • Netherlands
    I'm having a problem with a rather old board, a Chaintech Apogee 7VJL.
    The pc setup is:
    - Athlon XP 3000+ (175x13)
    - 3x 512MB Corsair XMS PRO @350MHz
    - ATI Radeon X1950PRO AGP
    - Chaintech Apogee 7VJL
    - Levicom VP550 (with an acrylic top, is actually fairly decent and recapped
    on the secondary side with Panasonic caps)
    - Club3D Theatron sound card
    - USB 2.0 card with ALi chipset
    - 2x 40GB Seagate HDD's
    - 2x CD/DVD Combo drive
    - 1x Floppy drive
    Now, the problem is that the board randomly does not boot (about a third of the times). Sometimes runs rock solid and a day later it is an unstable piece of crap.
    It is overclocked from a 166MHz FSB to a 175Mhz FSB, but it's got the same problems at the 166MHz FSB.
    The instability comes mostly in the form of memory errors, CRC errors while extracting zip files, random rebooting, windows that can't find one of it's many "important" files at startup, hanging while posting and i think that the experienced users can fill this list with all the other problems that come with that.
    But, sometimes it runs flawlessly, gaming, extracting and copying is not a problem at all then.
    Raising the DRAM voltage, Chipset voltage, CPU Voltage and even the AGP voltage doesn't help. Sometimes it looks like it runs stable, and other times it runs only stable when the voltages are set to default.
    Changing ram dividers, timings, different ram, nothing helps. Also swapping the GPU for 9600XT didn't help.
    And now i hear you thinking, "It's obviously that nasty Levicom unit that can't even power a led strip while staying in-spec". But, i also tried it on a Supermicro ATX PSU with 550W that i use for extreme overclocking and even that didn't help a bit. Voltages on the Levicom unit are 12.6V, 4.99V and 3.33V on the major rails. Ripple shouldn't be a problem since it's recapped with pannies. The PSU also doesn't produce any coil whine or other noises that indicate oscillation.
    You still here? Now comes the important part. The board is filled with C-grade caps. For the CPU vcore output purple G-Luxon (LW) caps, and for the rest green TEAPO with gold lettering. Ranging from 1500uF for the vcore input caps to 470uF caps for other smaller power delivery and filtering circuits.
    None of the caps are bulged or lifted, they all look brand new actually. Could they still be faulty?
    • 31289
    Re: Chaintech Apogee 7VJL Unstable
    yes, caps fail inside without external signs.
    you can try geating them with a hair-dryer to see if it becomes more stable - marginal caps work better when warm.
    • cpt.charlie
      • Sep 2013
      • 270
      • Spain
      Check VRM caps.
      • bauto601
        • Sep 2012
        • 103
        • Netherlands
        So i did some further research on the interwebz and i found out that this board does not have the 166fsb dividers.
        So i will change the board to a DFI NF2 Ultra B, but that one definately needs a full recap.
        It uses the following caps:
        CPU VRM output: 5x 3300uF 6.3V KZG
        CPU VRM input: 3x 1500uF 16V KZG
        And the following caps are spreaded over the board and i don't know exactly the purpose of each one:
        - 7x 470uF 16V OST RLG
        - 10x 1000uF 10V OST RLG
        - 5x 220uF 10V OST RLG (around the ram slots)
        - 15x 100uF 16V OST RLG
        Now, i want to do a full recap. For general caps, i was thinking of replacing them with the following (the same order, number 1 replaces number 1 and so on..):
        - 7x Nichicon RNE1C471MDN1 470uF 0.010ohm 16V Poly caps
        - 10x Kemet A755KS827M1AAAE014 820uF 0.014ohm 10V Poly caps
        - 5x Panasonic 220uF 0.018ohm 6.3V Poly caps (6.3V since they must be really flat and they probably only get 5V max)
        - 15x Rubycon 16ZLQ150MEFC5X11 150uF 0.21ohm 16V Poly caps
        I went with poly caps because the original caps seem to have such a low ESR spec that only poly caps can match or exceed them nowadays.
        For the CPU VRM i am still deciding between poly's or normal electrolytics. Which option would be better?
        CPU VRM OUT:
        - Poly: 5x Nichicon PLG0G272MDO1 2700uF 0.008ohm 4V
        - Normal: 5x Rubycon 6.3ZLQ4700MEFC10X25 4700uF 0.015ohm 6.3V
        CPU VRM IN:
        - Poly: 3x Nichicon RNL1C222MDS1 2200uF 0.008ohm 16V
        - Normal: 3x Rubycon 16ZLQ2200MEFC10X25 2200uF 0.015ohm 16V
        For the poly caps, i sometimes have to choose for a lower capacitance model than the original cap since the poly caps seem to have a larger diameter at the same capacitance as a normal cap. And thus, do not fit on the board.
        I really want to have the board perform as good as when it was new, or even better. Money is not that big of an issue, the difference between the full poly caps or semi poly caps recap is only €8 in total.
        I want to know if the capacitors i picked as a replacement will work in this board and if i should also choose poly caps for the CPU VRM, altough i would lose some capacitance there.
        What do you guys think?
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Yep, the KZG-series caps on that motherboard, especially from 2004 or 2003, are most likely bulging, if not already spewing like a volcano!
          Like my 2004 Asus A7N8X-X had! (nForce2)
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • bauto601
            • Sep 2012
            • 103
            • Netherlands
            Yup, all the KZG caps are already bulging and leaking. And i don't really trust those OST caps either. They look good but i don't think they will be in-spec anymore. These were bad times for motherboards capacitor wise.
            • thuygsm
              Macbook Air 2020 A2179 820-01958 (5V to the USB-C port unstable)
              by thuygsm
              I have a MacBook Air A2179 in my hands that had power problems (5V to the USB-C port unstable).
              I noticed there is liquid at U3200 and U3100 and have replaced them.
              PP1V5_UPC_X_LDO_CORE : 1.575V
              PP3V3_UPC_X_LDO : 3.280V
              PP3V3_G3H_RTC: constantly fluctuating from 0.5V to 3.284V
              I have isolated R6979,
              Pin 1: 3.280V stable
              Pin 2: 0.447 (diode)
              PPBUS_G3H: 12.28V (with R6979 isolated)
              PPBUS_G3H: fluctuates 5V -> 4V -> 6V -> 12.28V(when R6979 is present), and repeats in a loop
              What should I do next?
              10-29-2025, 06:02 AM
            • G0RIT
              Reebok one GT40s treadmill lift motor runs at switch on
              by G0RIT
              Good evening I am working on a Reebok oneGT40s treadmill. It had a flashing display which the replacement of D3 rectified. However the lift motor now runs when the mains is turned on and does not stop. If I then select start so the tread motor runs and disconnect the up lead to the lift motor it stops. If I then reconnect the lead the lift motor works as it should with the controls. It will continue to work correctly until the mains is turned off and on again, or the safety device is removed and replaced. It then runs again and only by disconnecting and reconnecting the up lead will it operate...
              06-23-2022, 05:57 PM
            • tyl85
              Imac A1418 late 2013 21.5" fan runs at max speed
              by tyl85
              Hi, i have this iMac issue
              I've checked temperature by using macfans with no results
              techtool pro shows me AMBIENT AIR TEMP FAULT
              i'm going crazy, the mac runs very slowly
              where i can find this sensor on motherboard?
              thanks in advance
              12-03-2024, 01:09 AM
            • Syseng
              Lenovo P14s Gen 5 SVP unlock
              by Syseng
              This sums up discussion related to Lenovo P14s Gen5 in this thread. Credits go to Sbaro and especially Maxpower3. The locked dump is attached.
              The device is based on NM-F871 motherboard with Nuvoton NPCK397 series controller. The motherboard also contains three BIOS chips: two different Winbond chips for main BIOS and external EC flash, and also a Gigadevice chip which purpose I do not know. The password information is contained directly in controller and thus can be manipulated by reprogramming it, so reprogramming BIOS chips is technically not required, however you may wish to make...
              06-22-2025, 07:44 AM
            • dr.thodt
              Lenovo laptops unstable with sodimm ram
              by dr.thodt
              For the second time this week I received a Lenovo laptop with onboard ram and one sodimm slot. Both laptops run stable from their onboard 4GB RAM, but turn out to be very unstable when there's a sodimm inserted in the slot.
              Both times it was a GS44D/GS54D NM-C711 rev 1.0 board.
              Both times there were no loose pins on the slot and it did not matter what sodimm I put in. It just artefacts and crashes randomly when there's extra ram.
              What I did notice is that almost all coils have very dirty phases one the mosfet side when checked with an oscilloscope. Not something I see very often....
              06-07-2024, 09:16 AM
