Something is blowing my Intel Little Falls 2 D945GCLF2 mobo!?
  • davcom1
    • May 2009
    • 23
    Guys,
    Sorry to just barge on here and post but I need so advice...
    I have built a car PC running with an Intel Little Falls 2 mobo (D945GCLF2).
    It has been running great for months and then suddenly decided to 'die' the other day. The mobo was mounted in the dash but not particularly well protected so I decided something had shorted as the M2-ATX car PSU was apparently running fine and the green power indicator on the actual motherboard was lit but with no other signs of life.
    I purchased a replacement board together with a mini ITX case and rebuilt. The PC booted fine and ran for all of 60 seconds before it also died with the exact same symptoms!!!?
    I've checked the PSU on a standard desktop board and it runs... just although it does shut down and start again after a few minutes but I am guessing this has more to do with my 12v supply and the wattage of the CPU than any fault.
    I've metered the voltages and they all read spot-on 3.3, 5 and 12V
    The only things left to check are the various USB components - FM radio tuner, touchscreen, hub plus a serial GPS mouse.
    The speaker jacks run to an amp in the car but I would have thought that's one-way traffic as far as current is concerned?
    I've noticed that both dead boards are very hot on one transistor (voltage regulator?) - see yellow circled area below:
    Two questions...
    1. Does anyone think the boards are repairable? If so, any ideas?
    2. What could be causing the boards to blow?
    Big thanks in advance for any help!!
    David
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Something is blowing my Intel Little Falls 2 D945GCLF2 mobo!?
    Try with bare minimum system.
    No drives, mouse, etc. - Just video and keyboard.
    See if you can get into the BIOS.
    Mann-Made Global Warming.
    - Dr Seuss
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Board in photo looks like it might have Nichicon HN caps.
      Those were defective from 2001 thru 2004.
      - Dr Seuss
      • davcom1
        • May 2009
        • 23
        Hi PcBonez
        Thanks for the replies.
        The boards both show ATX power is connected but will not power up - no fan spin etc. All that happens is the circled transistor gets very hot.
        These boards first appeared in 2008 although I can see Nichicon PET written on at least 2 caps. Also used is Samxon, N.P.N(?) and Rubycon.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          You have two boards with the same problem.
          Most likely something from outside affected the boards so check the things they have in common.
          The first thing to do is get rid of everything you don't need to boot it to a BIOS screen because if some outside bad part is still connected you aren't going to get anywhere.
          - Dr Seuss
          • 370forlife
            Large Marge
            • Aug 2008
            • 3112
            What is this power supply, show some pics of it.
            It may be in-spec on a DMM, but the fluctuations in voltages can happen quicker than it refreshes, so you may not see them.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Two different boards.... Same FET gets hot.
              - - Trace it and find out what powers the FET.
              - Dr Seuss
              • Wizard
                • Mar 2008
                • 2296
                Make sure your power supply is good. Noisy PSU kill these. I was lucky I caught this.
                Cheers, Wizard
                • davcom1
                  • May 2009
                  • 23
                  Hi guys,
                  Thanks for the responses so far.
                  I have to say I'm no electronics specialist.. the PSU is a custom 12v in, car ATX. It is less than 8 months old and only used for 30 mins per day on average.
                  Here's a pic -
                  Someone has suggested the car alternator but for the second board, the car was not running and ignition was at ACC position.
                  I have tried both boards bare and get the same result - the transistor gets very hot, very fast BUT no fan spin so no BIOS.
                  There's no obvious signs of fried component. Would they be close to the transistor? I measured the resistance across the pins and get 170 and 19 ohms in both directions.
                  The transistor has got the marking 1117A 822176 impressed onto it. I did a search for the numbers on the 'net but nothing came up.
                  Here's a closer image of the component:
                  A full-size version is also here: www.tapsupply.co.uk/CVR4/moboclose.jpg
                  Thanks again for any guidance.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    1117A is a Low Voltage Dropout Regulator but it ID's a familiy not a specific part.
                    Some are fixed voltage and some adjustable.
                    Might be regulating any of 1.8V, 2.5V, 2.85, 3.3V, or 5V.
                    Most are rated from 800 mAmp to 1 Amp and getting hot might be normal for that much current through a part that small.
                    For instance 1 amp at 5v would be 5 watts [and that's just the load on it].
                    - Dr Seuss
                    • davcom1
                      • May 2009
                      • 23
                      Thanks PCBONEZ!
                      So, even though there's no obvious signs of life apart from the LED on-board, this regulator might be working ok? - Shame because I was hoping it would be an easy-ish fix!
                      Is there a way of testing with a meter? (Sorry for my ignorance)
                      • davcom1
                        • May 2009
                        • 23
                        I've just plugged one of the boards into a standard ATX PSU and left for a while - the regulator/transistor took about 30 seconds to get noticably hot.
                        The southbridge chip also began to warm up a little.
                        The voltage across the regulator (outer pins) was 1.80V.
                        Think I'll start the project from scratch!!
                          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                          12-14-2023, 07:45 PM
                        • Cerberuska
                          Mobo MSI B550-A PRO password popup
                          by Cerberuska
                          Hello guys,
                          I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
                          BIOS I updated to last one.
                          any suggestions?
                          And same thing for two different 5600G, and yes, MoBo supposed to support it.
                          Thank you...
                          11-10-2024, 01:23 PM
                        • grimacelord
                          Xbox One S - 12V Rail Short - Q9F1 Keeps Blowing
                          by grimacelord
                          Have an Xbox One S here that has a short on the 12V power rail. There is no power, beep, or partial fan spin when connecting power cable.
                          After diagnosing with thermal camera, Q9F1 MOSFET (NTTFS4C50N) is getting hot. When I remove this MOSFET, the short on the 12V rail disappears.
                          I first replaced Q9F1 with one from a donor board and then partially reassembled the Xbox to test. When I plugged the power cord in, I got a partial fan spin and I thought I had fixed it, but unfortunately, the Xbox still did not power on. So I then disassembled the Xbox...
                          10-24-2024, 12:31 PM
                        • 90Ninety
                          Dell XPS 8100 Motherboard VRMS keep blowing
                          by 90Ninety
                          I wanted to save this thing from E-waste ... I helped a neighbour with their Dell PC , it had a blown visably blown VRM causing a short on the 12V EPS ..
                          I replaced this VRM which fixed the short but, the high side VRM's keep blowing , seemingly the same two phases .. I replaced the low side mosfets on the respective blown phases . Though still the High side VRMS are blowing ..
                          After a few minutes one of the four phases will get extremely hot , then blow ..
                          I purchased replacement VRMS both High Side (72T02GH) and Low side (86T02GH). Pictured below , I just...
                          10-05-2024, 08:36 AM
                        • mrsith
                          Dell G3 17 3779 - no display after mobo replacement
                          by mrsith
                          Hi guys,
                          I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
                          Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
                          04-30-2023, 05:11 AM
