Gigabyte GA 8S661FXM No Post No Beep
  • Solder Boy
    • Nov 2006
    • 178
    Hi all I have this motherboard as listed in the title appears to have an SiS Chipset. Motherboard turns on no problem, there are no beep codes. No POST either.
    CPU chip is bone cold, so obviously it's not getting voltage. Tested the single cap in the VRM section, it looked kinda flaky so I replaced it. Didn't solve the issue.
    I'm guessing the Mosfets are done and or the BIOS chip is kaput?
    Anyone else have experience with this board?
    www.bcrelectronics.ca
  • Harvey
    • Apr 2007
    • 264
    Re: Gigabyte GA 8S661FXM No Post No Beep
    If one cap in the VRM has failed, its likely the others have too. You either risk it and replace them all, or just dump the board.
    • EGuevarae
      • Nov 2008
      • 1336
      Personally, I saw one last week with the same problem. I didn't open the rig, just saw the manual. What version is it? 478 or 775?
      • ASUS ROG Maximus IX Code
      • Intel Core i5-7600K 3.8GHz
      • Windows 10 Pro x64
      • GeForce GT1050
      • swartz
        • May 2009
        • 31
        I realize this is an older thread.
        But just recently a friend I know brought in this same motherboard (GA-8s661fxm-775) with missing caps. He got it from someone who used it for spare caps but it was working before.
        Can you guys tell me what the values (capacitance, voltage and make/model if possible) for the following caps are on this motherboard?
        Spots on mobo marked as:
        dec7, dec6, dec8, dec9
        all are part of the CPU VRM (near the cpu socket).
        Thanks!
        • Solder Boy
          • Nov 2006
          • 178
          I couldn't tell you.. don't have this board anymore so I can't give you the correct information... sorry!
          • lucky13
            • Aug 2007
            • 412
            Thanks!
            Are all the caps removed?
            If not, can you post a close up pix and one of our senior member can probably offer up possible values to use.
            • swartz
              • May 2009
              • 31
              Yeap there are 4 caps missing for sure. At least that is all I can see from the flux/scratches on the back of the motherboard. If they took off any other ones they must've been much neater than when they took off the first 4.
              I include a link to the pic of the board. Its a 10Mpix image ~2Mb. The spots where caps are missing are highlighted. There is a row of 3 caps and another 1 above them that are missing.
              http://img.photobucket.com/albums/v1...30193-edit.jpg
              Having seen similar designs my guess is they all must be 3300uF 6.3v types but I would like to be certain.
              • lucky13
                • Aug 2007
                • 412
                swartz,
                Judging from your picture, it is a 4-phase VRM.
                So you are missing the input filters.
                Most input filters are like 1500uF-1800uF, 16V.
                You can browse other motherboard recap threads (llok for all Gigabyte GA-8 series) and you may see what other brand/models are using.
                • lucky13
                  • Aug 2007
                  • 412
                  In gigabyte's website, the pic shows there are 3 VRM input caps:
                  I googled for other images and there is this one which shows 4 VRM caps which matches with what you are looking:
                  • EGuevarae
                    • Nov 2008
                    • 1336
                    Definitively the same board.
                    I've seen those boards with 1800uf. The 3300uf I've seen were on AMD boards.
                    • GeForce GT1050
                    • swartz
                      • May 2009
                      • 31
                      Yeap looks the same.
                      What voltage were the 1800uF caps?
                      Coz i've had aprox. ten P4 board pass my hands with exclusively 3300uF 6.3v caps in the VRM section. Although all of them were Socket 478 based. This is the first Socket775 board that I've had. Mainly because a lot of manufacturers switched to solid caps or that the crappy caps were more or less exited the market (I hope).
                      • EGuevarae
                        • Nov 2008
                        • 1336
                        16v 1800uf Rubycon MBZ caps. I've seen same series/brand/cap. but in 6.3v
                        • GeForce GT1050
                        • EGuevarae
                          • Nov 2008
                          • 1336
                          Here's a pic from a dead ECS I had :
                          • GeForce GT1050
                          • lucky13
                            • Aug 2007
                            • 412
                            I guess you need to pull out your meter to figure out if you need 16V caps or 6.3V input VRM caps.
                            My guess is 16V as there is that 4-pin connector from your p/s.
                            • EGuevarae
                              • Nov 2008
                              • 1336
                              I second that. Pending confirmation from one of our seniors, I guess that you can use the 16v ones without problems if they fit and the ESR and ripple are within specs.
                              • GeForce GT1050
                              • swartz
                                • May 2009
                                • 31
                                Alright I'll just put four Panasonic FM 2200uF 16V caps as its all I've got in 16v.
                                As far as voltage testing goes... I dont have a 775 CPU to try it on. Like I said most mobos I've fixed so far were Socket 478s. So how would I test the supplied voltage if there is no cpu to start the mobo?
                                PS. I have plenty of 3300uf 6.3v Panasonic and Nichicon caps as its all I've seen on most motherboards. Alas they wont be usefull this time.
                                • sofTest
                                  • Aug 2008
                                  • 361
                                  The Intel-based GA-8I945P-series I've got, uses 1500uf 16V Rubicon MBZs, if that is useful. If I remember correctly, there is four of them on that one also.
                                  Be a mensch
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    I have a GA-8IG1000MK here with 3x 1500uF Sanyo WG there.
                                    Individual ESR / Ripple is 0.013 / 2550.
                                    Total ESR / Ripple would be 0.0043 / 7650.
                                    If you take that as a minimum you should be fine.
                                    Fill all 4 spots eguevarae circled though.
                                    The MOSFETS in that 3rd phase are pretty distance from the other two phases and that odd-out cap is probably needed there.
                                    Mann-Made Global Warming.
                                    - Dr Seuss
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      The date codes on those Nichicons looks to be mid 2004.
                                      If those are HM series you should replace those while you are at it.
                                      - Dr Seuss
                                      • EGuevarae
                                        • Nov 2008
                                        • 1336
                                        Not my pic or circles. It was taken from post #7 and posted back for clarity purposes.
                                        • GeForce GT1050
                                        • pkslowk
                                          Debug Card Error Code and Solution
                                          by pkslowk
                                          Sr. Motherboard Debug Error Code Solution
                                          1 Intel 845 E9 Bios Related Problem
                                          2 Intel 845 D4 CPU Socket Related problem
                                          3 Intel 845 37 Bios Related Problem
                                          4 Intel 845 7C Bios Related Problem
                                          5 Intel 945GCPE 34 Bios Related Problem
                                          6 Gigabyte 845 2 Ram Related Problem
                                          7 IBM Server A6 A7 Ram Mismatch Problem
                                          8 Asus 845 29 CPU Related Problem
                                          9 Lenovo I946 97 C-Mos Jumper related
                                          10 Gigabyte 845 A0 CPU Related Problem
                                          11 Asrock G31M-VS D7 Bios Related Problem
                                          12 Compaq 845 BD-70G B0 CPU Socket Related problem...
                                          01-28-2021, 12:51 PM
                                        • DynaxSC
                                          GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                                          by DynaxSC
                                          I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                                          General test conditions:
                                          - Tested with Core i5 6500 and Core I7 6700K - no difference
                                          - Default BIOS settings, but tried also altering several memory setting - does not change anything
                                          What is wrong:
                                          With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                                          When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                                          03-21-2025, 06:23 PM
                                          Thermal pad thickness for various laptop GPU / Graphics Cards
                                          ASUS Dual RTX 2070 OC 8GB
                                          ASUS ROG STRIX RTX 3080 OC
                                          ASUS ROG STRIX RTX 3090
                                          ASUS TUF Gaming RTX 3080 OC Edition
                                          ASUS TUF GTX 1660 S-O6G GAMING
                                          EVGA RTX 3060 Ti XC GAMING 8GB
                                          EVGA RTX 3060 XC GAMING 12GB GDDR6
                                          EVGA RTX 3080 FTW3 ULTRA GAMING
                                          EVGA RTX 3080 TI FTW3 ULTRA GAMING
                                          EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                                          Gainward RTX 2080 Phoenix GS Specs
                                          Gainward RTX 3070 Phoenix 8GB
                                          Gainward RTX 3080 Ti Phoenix
                                          GIGABYTE AORUS RTX 3080 MASTER 10G
                                          02-09-2024, 08:08 AM
                                          A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                                          by momaka
                                          More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                                          And a shot of the label:...
                                          01-26-2022, 03:26 AM
                                          Gigabyte Notebook Specification for Upgrade or Repair
                                          This specification for the Gigabyte Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the boardview and schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte Notebook is accurate, safe,...
                                          09-07-2024, 07:19 AM
