Dead Original All-In-Wonder ATI Card
  • canadaboy25
    What is normal?
    • May 2013
    • 509
    Hey guys I have an ATI All-In-Wonder video in/video out card from 1996. I also have an All-In-Wonder Radeon 7200 from 2000 which I recently got set up and working. The original card from 1996 was in my Asus PII machine that got killed when the psu melted down. I am not 100% sure but based on the scorch marks some members of badcaps thought that it was a 5v stand by rail that went over voltage. I have yet to fix the motherboard but that is another issue on its own.
    The card is a standard PCI card. I plugged it into a working PC and it gave me 8 quick beeps which means bad video card. Bummer. I'm guessing that video cards have no protection and it fried the GPU? Or is there something simple that took the grunt of the over voltage? The sound card which was an ISA card still works fine.
    Any thought would be appreciated because I would love to have at least a few pieces of my first ever system live on.
    canadaboy25
    -Sometimes the light at the end of a tunnel is an on-coming train
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Dead Original All-In-Wonder ATI Card
    the processor appears to have a crack in it.....the holy smoke has been released.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • canadaboy25
      What is normal?
      • May 2013
      • 509
      I saw that just after I posted. Looks like some old dried glue or similar. It scraped off very easily.
      canadaboy25
      • ChaosLegionnaire
        HC Overclocker
        • Jul 2012
        • 3266
        • Singapore
        one last thing u can try, i noticed the video bios chip is socketed. try to replace it. the flash could have been damaged by the overvoltage. if that doesnt work, im afraid its a goner. either the gpu is fried and/or the video memory is fried...
        • rhomanski
          nowhere man
          • 5157
          • U S of A
          On my old Amiga the bios was socketed. About every six months I had to open it and run my finger across the plastic of the chip side to side and top to bottom. It would work fine for another six months or maybe a year after that. Eventually though it wouldn't come up with the beginning screen and I'd have to open it again.
          sigpicThe Sky Is Falling
            • 31248
            that was the AGNES chip in the square socket that had that problem.
            • rhomanski
              nowhere man
              • 5157
              • U S of A
              I always assumed it was the one with the bios in it. Is that right?
              • Agent24
                I see dead caps
                • Oct 2007
                • 5069
                • New Zealand
                You could check the 7805 for a bit of fun, but if the PSU blew up, most likely one of the important chips has blown, whether you can see visible damage or not.
                -David VanHorn
                • jiroy
                  • Jun 2016
                  • 2416
                  • Lebanon
                  It's not necessarily dead . It is a PCI VGA card in the end , and that would surely put it in conflict with the already assigned VGA card by the system . By default , the system will try to locate the last VGA configuration and take its boot from it . On win98 and older , Irqs were fairly sensitive , and options to change them under working windows is the impossible itself .
                  I think a good work out , is first of all to treat this card in its original environment , meaning it was designed for win 95 and 98 . Then second , is to change some BIOS options , like resetting to standard configuration , and like forcing the VGA booting from PCI , not Agp . and third , to try the card in different PCI slots as such operating systems were very adequate concerning IRQs assigning . Such difficulty would even near the impossible if a sound card for an example shared the same IRQ (let's say irq 5 here ) with the VGA ..
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5069
                    • New Zealand
                    Good points though I must admit I assumed that canadaboy25 already tried that.
                    Multiple video cards may not be an issue though. I've certainly had AGP and PCI cards running in the same machine before, to drive extra monitors.
                    -David VanHorn
                    • jiroy
                      • Jun 2016
                      • 2416
                      • Lebanon
                      Yes Agent24 ; Once installed and configured properly , you can run multiple monitors , and that was a good specialty in windows 98 .
                      • canadaboy25
                        What is normal?
                        • May 2013
                        • 509
                        Unfortunately the input is 12v and the output is a perfect 5v so that seems ok.
                        The card was tested in every PCI slot on the board and no other cards were installed at the time. The card was last used in a machine running windows XP and the machine I was testing it in has a hard drive in it with XP installed so that shouldn't be an issue. When the card was working there would always be an ATI splash screen before the BIOS of the pc booted and I am not seeing it.
                        canadaboy25
                        • Agent24
                          I see dead caps
                          • Oct 2007
                          • 5069
                          • New Zealand
                          Are you sure there's no crack in the IC behind that "Glue"?
                          -David VanHorn
                          • jiroy
                            • Jun 2016
                            • 2416
                            • Lebanon
                            I assumed it could be a board with an integrated VGA , with maybe a Nvidia Agp , which makes in such case 3 working VGAs at the same time , counting the All-In-Wonder ATI pci Card , Some resources in conflict with other devices ... and yet , you seem aware of all that ...
                            And yes , if configured well , it works fine in XP , and i even managed to install ones in w7 , with some of the TV software excluded .
                            What remains to say , cleaning connectors , searching for weak and stressed soldering points , maybe reflowing . those were piece of art , and very solid . worth time and efforts .
                            • canadaboy25
                              What is normal?
                              • May 2013
                              • 509
                              Ha, yep quite certain. Even under magnification I can't see any physical defects with the processor.
                              Yeah, there is no on-board graphics and I have tried with other boards too. I have a hot air rework station with liquid flux so re-flowing specific items shouldn't be an issue if that is the case. I was hoping a transistor or some memory would be toast. Something generic that could be replaced.
                              I agree they are pretty awesome cards. I love the one that I have working and would love to get this one working too. Especially since any av input PCI card these days still costs a pretty penny.
                              canadaboy25
                              • jiroy
                                • Jun 2016
                                • 2416
                                • Lebanon
                                Yes canadaboy25; They can even take the best still pictures among other brands .
                                Let us know on any progress ..
                                • paparazzo79
                                  sound card dead after graphics card installation
                                  by paparazzo79
                                  Hi guys.I own Z690 F Strix board in one of my PCs....everything was working fine with integrated graphics card.I turned off power from it, installed graphics card from another PC, connected all the peripheral cables, optical sound cable of course when everything was switched off.Then I powered on the machine and integrated soundcard is dead.How did this manage to happen and if there is a way to diagnose and replace damaged component?
                                  The new pci-e soundcard costs here 80 euros which is half of money I spent on motherboard.
                                  I still can not believe that I am such a looser and don't know...
                                  07-23-2024, 12:22 PM
                                • EbrahimSiami
                                  Acer Aspire 5920G - Requesting Modded BIOS (9600M GT) from .WPH for CH341A Flasher
                                  by EbrahimSiami
                                  I need help with my Acer Aspire 5920G laptop. Its original GeForce 8600M GT graphics card failed, so I replaced it with an Nvidia GeForce 9600M GT MXM card.
                                  **Problem:** The laptop powers on, but there is no display (black screen) on either the internal LCD or external monitor. This indicates a BIOS compatibility issue with the new graphics card.
                                  **What I have tried so far:**
                                  1. I have my **original stock BIOS dump (1MB .BIN file)** from my laptop, which works and allows the laptop to power on normally (but no display with 9600M...
                                  07-02-2025, 02:31 PM
                                • paparazzo79
                                  HP Elitedesk 800 G5 LAN card dead
                                  by paparazzo79
                                  Hi guys.
                                  I purchased this mini desktop PC from a guy in uknown condition but noticed that network LAN card is not working.
                                  I changed few LAN cables,neither of the led lights on the LAN ports is blinking.
                                  The card model is recognized in device manager, and no exclamation marks or smth like that.
                                  Is there a way to physically test the LAN card (and how) with multimeter?
                                  I also tried Ubuntu live distro, no luck.
                                  08-10-2023, 09:48 AM
                                • Christos Tsiligiannis
                                  Marian Trace Alpha sound card repair help
                                  by Christos Tsiligiannis
                                  Hello to the forum.
                                  My name is Christos, I am new to the forum here and i am posting from Greece.
                                  So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                  To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                  So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                  11-18-2024, 05:26 AM
                                • Kemer
                                  Graphics Card mounting frame
                                  by Kemer
                                  Hello, I removed the graphics card from my laptop and I want to heat it in the oven. What I want to ask is, is it okay to heat the card without removing the metal mounting frame on it?
                                  As you can see in the photo, there is a plastic (black) gasket between the metal frame and the card. It sticks the frame tightly to the card.
                                  I previously removed the metal frame while heating it, but it is quite difficult to separate it from the surface it is attached to. If there is no problem, I do not want to remove it.
                                  What worries me right now is the possibility that...
                                  09-14-2024, 08:57 AM
