Mystery ECS Motherboard?
  • Scenic
    o.O
    • Sep 2007
    • 2642
    Re: Mystery ECS Motherboard?
    Originally posted by kikkoman
    seems they all use the same design.
    e.g. here:
    http://sh.beareyes.com.cn/2/lib/2002...0020731230.htm
    ECS uses different PCB colors and slightly changed layout in different versions, and sometimes the VRM section isn't fully populated.
    maybe PCChips and ECS working together? what an unholy alliance.
    edit: too slow.
    well.. those boards don't get better with a fancy PCB color
    polish a turd.. its still a turd..
    edit: @ kikkoman: its ok... just nothing special and a little bit unstable..(even recapped)..
    i used to flash the cheepo-BIOS after i recapped them to get a little bit fine-tuning in there
    BTW: noch oder schon wach? hehe
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      PcChips boards are actually built by Hsing Tech.
      Hsing Tech = Manufacturer.
      PcChips = Distributer.
      [Same Company]
      So I understand ECS has outsourced to PcChips to have boards built but that's recent and I think after Socket A was out of production.
      Asus does the same thing. That's what Asrock boards are. Asus+PcChips=Asrock
      PcChips =
      Topgun, Amptron, Eurone, Matsonic(some), Pine, PcPartner(older), and maybe a dozen others.
      Many of them ordered the boards without BIOS chips and used their own BIOS.
      I used to cross-flash PcChips OEM boards that were unstable with the BIOS from another OEM for the same board. Fixed a lot of problems with them that way.
      Mann-Made Global Warming.
      - Dr Seuss
      • i4004
        • Oct 2006
        • 2029
        i don't get this thread; why do you need to know what mobo is it?
        fix those caps and run it, and then you'll know.
        probably...
        what's the advantage of knowing first?
        i don't think you can buy capacitor kit from topcat for such..huhm...god, how do you call a pcchips clone?
        (or a pcchips ripoff of ecs...OMG!
        edit/
        or whatever pcbonez just said...)
        oh yeah, photobucket is a good image hosting service.
        ads sponsored, but still good.
        you can create album and put many jpegs at once...
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Advantage of knowing first... Ummmmm.
          To know which CPU's and memory are actually correct for it. DUH!
          - Dr Seuss
          • i4004
            • Oct 2006
            • 2029
            ah yeah, because it's so hard to see it now it's out of the case...hehe...
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              I actually managed to get the CEO of Hsing Tech's email address a few years ago. (Back in the 1990's) I didn't know it was the CEO's email, I thought I was writing tech support or an engineer at the factory or something. - I ask him if there was a way to build a motherboard that supported an older CPU and a newer feature. (Don't recall exactly what it was. Maybe like UDMA66 on a socket 7 or something like that.)
              - He said "sure", He could do that if I ordered 20,000 motherboards minimum.
              - Dr Seuss
              • genosmm
                • Oct 2005
                • 51
                #27
                PCBONEZ,
                Thanks for all your detective work!!!
                Here are all the closeup ID stickers and numbers I could find on both sides of the mobo.
                ECS Sticker URL: http://www.img-share.com/view/2412 The ECS sticker has 7 and 01 crossed out so am guessing it is July 2001.
                PCI area ID sticker URL: http://www.img-share.com/view/2413 Googled M017A6021002091 but got nothing for both images and std search.
                only ID on back URL: http://www.img-share.com/view/2414
                Gene
                • genosmm
                  • Oct 2005
                  • 51
                  #28
                  PCBONEZ,
                  Thank you for your help!
                  The PC Chips link was especially helpful. http://www.pcchips.com.tw/PCCWebSite...2&LanID=0&ln=1
                  Checked a number of M810 ver manuals and v3.0 matches all the jumpers and components Except for the BIOS chip. Mine is much smaller URL: http://www.img-share.com/view/2457
                  Closer inspection of the bottom left of the motherboard has Rev 3.0 URL: http://www.img-share.com/view/2460
                  I rechecked the PCI motherboard area where these motherboards generally have a model marking but again found nothing. URL: http://www.img-share.com/view/2463
                  Am wondering of the ID and Serial # found on the parallel port is of any help? URL: http://www.img-share.com/view/2464
                  You mentioned "PcChips boards are actually built by Hsing Tech.
                  [Same Company]
                  Question: Is ECS a distributor like PC Chips?
                  Thanks again for all your help!
                  Gene
                  • genosmm
                    • Oct 2005
                    • 51
                    #29
                    PCBONEZ,
                    Should rephrase my question since after posting discovered my mistake.
                    You mentioned "So I understand ECS has outsourced to PcChips to have boards built but that's recent and I think after Socket A was out of production."
                    Question: Would not ECS outsource to "Hsing Tech = Manufacturer"? Since "PcChips = Distributer" or is it the marketing division? Does not really matter much because I tried to search using "Hsing Tech motherboards" but got nowhere so am guessing the only info available may be from the PCChips link you provided.
                    Must say this is a mystery. I checked the ECS website http://www.ecs.com.tw/ECSWebSite/Pro...D=52&LanID=0#4 and none of their 462 motherboards http://www.ecs.com.tw/ECSWebSite/Pro...D=52&LanID=0#4 comes as close to matching this mobo as the PC Chips M810 v3.00!
                    I would think if they sold this motherboard there would be some listing on their website? Never thought it would be this difficult to track down a "nonworking motherboard"!
                    Thanks again for your help!
                    Gene
                    • Scenic
                      o.O
                      • Sep 2007
                      • 2642
                      Originally posted by genosmm
                      Must say this is a mystery. I checked the ECS website http://www.ecs.com.tw/ECSWebSite/Pro...D=52&LanID=0#4 and none of their 462 motherboards comes as close to matching this mobo as the PC Chips M810 v3.00!
                      the K7SEM Rev. 1.0 does... but its listing (on the ECS page) is dead (no pic, no description)
                      http://www.motherboard.cz/mb/ecs/K7SEM.htm
                      • genosmm
                        • Oct 2005
                        • 51
                        #31
                        Scenic,
                        First I only checked the ECS motherboards with pics.
                        Thanks for the "K7SEM Rev. 1.0 does... but its listing (on the ECS page) is dead (no pic, no description)" tip! Will try to find some pics for it.
                        Gene
                        • genosmm
                          • Oct 2005
                          • 51
                          #32
                          Scenic,
                          Did a quick search for K7SEM Rev. 1.0 images and found
                          http://images.quebarato.com.br/photo.../6/490D6_2.jpg
                          http://img.mercadolivre.com.br/jm/im...6_9638.jpg&v=P
                          http://images.quebarato.com.br/photo.../6/490D6_1.jpg
                          http://img.mercadolivre.com.br/jm/im...8_8597.jpg&v=P
                          The K7SEM Rev. 1.0 motherboard is different from my mystery motherboard in the battery placement and order of Floppy and IDE sockets plus there are 4 inductors (mine has 3).
                          The PC Chips M810 v3.0 matches all the mainboard components Except for the BIOS chip and you can see on the mobo solder holes for the other BIOS chip.
                          So should change the topic from Mystery to Unknown ECS Motherboard.
                          Thanks again for your help.
                          Gene
                          • genosmm
                            • Oct 2005
                            • 51
                            #33
                            i4004,
                            Should have addressed this subject in my first post.
                            To answer your question "i don't get this thread; why do you need to know what mobo is it? fix those caps and run it, and then you'll know."
                            I would like to determine if this ECS mobo is worth repairing by checking if it has in addition to the bad caps any other "weak components" or problems.
                            Gene
                            • iMic
                              IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
                              by iMic
                              Hi folks,
                              I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
                              The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
                              11-29-2023, 06:44 AM
                            • glovecaps
                              Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                              by glovecaps
                              I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                              My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                              The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                              11-25-2024, 04:23 PM
                            • Docus
                              Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                              by Docus
                              Hi everyone 😀,
                              I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                              To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                              Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                              1. I already own the exact same model, but its plastic chassis is badly damaged.
                              06-10-2025, 04:24 PM
                            • Archimedes
                              HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                              by Archimedes
                              Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                              Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                              Fans are spinning. Blindly could install windows11 and got the device manager...
                              07-30-2024, 05:14 PM
                            • dragon3x
                              After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                              by dragon3x
                              Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                              power on.
                              Here are some examples :
                              (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                              switching supply area).
                              (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                              than 6.3 V.)
                              1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                              I replaced capacitors with aluminum-polymer.
                              3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                              03-21-2025, 02:46 PM
