GA-EP45-DS4P lost cause ?
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Bought this cheap, described as "faulty. Does not post"
    Doesn't even power on actually, not surprising with physical damage pictured
    Board has everything, including "Quick Switches" so owner can easily Power on, Clear CMOS or Reset by pressing the appropriate button
    It's the Reset switch which seems to have been forcibly ripped from the board
    I've tried bridging the two big broken tracks pictured, to no avail
    I think this one's destined to join my junk board collection
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
  • Dan81
    SNES-powered
    • Oct 2013
    • 1866
    • Romania
    Re: GA-EP45-DS4P lost cause ?
    I think joining the big ones wasn't enough,seeing that a quite deep scratch is located just next to the broken tracks.
    Main rig:
    Gigabyte B75M-D3H
    Core i5-3470 3.60GHz
    16GB DDR3-1600
    Samsung SH-224AB DVD-RW
    Delux MG760 case
    • R_J
      • 9607
      And there is a thin trace between the two wide ones, I would also check the thin traces between the thicker trace and the edge of the board
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Unless your very good at soldering or can find where easy broken trace links to and bridge it with wires, this is going to be very hard to do.
        • lti
          • May 2011
          • 2557
          It looks like something shorted and the traces melted open (like a fuse). There is some discoloration around the break.
          • pfrcom
            Oldbie
            • Jun 2006
            • 1230
            There's also damage underneath the same area
            Thanks for your responses
            Unfortunately concurs with my thinking - win some, lose some, and this one's a loss
            Pity, rest of board's in impeccable condition
            • Dan81
              SNES-powered
              • Oct 2013
              • 1866
              • Romania
              Could have looked in worse condition - just got a MSI 845E MAX without NB sink,bulged KZGs (6.3v 2200uF,5 of em') and ripped VRM heatsinks - in fact,the only sign that there were VRM sinks was the thin legs the heatsinks had.
              Main rig:
              Gigabyte B75M-D3H
              16GB DDR3-1600
              Delux MG760 case
              • ChaosLegionnaire
                HC Overclocker
                • Jul 2012
                • 3266
                • Singapore
                i see some oscon sepc polys on the board. those can be salvaged for recapping other mobos. did u get a boardful of oscon sepc polys or are there some chemicon psc polys in there as well? lucky u if u got a boardful of either. i got an ep35-ds3 with a boardful of fujitsu fpcaps except for a handful of sepc polys for usb filtering and needless to say the board didnt last long to my overclocking attempts...
                • jjkevi
                  Lost MAC Address After BIOS Rewrite – Need Help Restoring on HP 800 G1 SFF
                  by jjkevi
                  I’ve run into an issue with my HP 800 G1 Small Form Factor PC after performing a BIOS rewrite. Everything works except for one major problem — the MAC address for the onboard network adapter is missing.
                  Here’s the situation:
                  • Model: HP 800 G1 SFF
                  • OS: Windows 10 Pro
                  • Cause: After rewriting the BIOS, the system lost its original MAC address.
                  • Symptoms:
                    • Network adapter shows a generic or invalid MAC (or sometimes blank).
                    • No Ethernet connectivity unless I use an external USB-to-Ethernet adapter.
                  • What I’ve tried:
                    • Checked BIOS settings (no MAC override
                  08-11-2025, 05:05 AM
                • jerem57m
                  Lost bios password on HP Spectre Pro 13 G1 (X2F00EA)
                  by jerem57m
                  I hope I'm in the right place to make my request. Now that I've made my presentation, I'd like to make a request regarding a 2017 HP Spectre PRO 13 G1 laptop. I have a lost BIOS password. I really don't remember setting a password on this computer, and after changing the battery, the computer no longer wants to boot without it. Can you help me remove the password?
                  I read on the forum that someone who had a model similar to mine managed to remove the password, so I figured with any luck I'd find some help here.
                  Exact information:
                  Product: X2F00EA
                  Trade name:...
                  07-17-2025, 06:26 AM
                • rive.hafintosh
                  HP Probook 650 G4 - Lost power?During AMT de-provision process, now I get blackscreen
                  by rive.hafintosh
                  First here is how things went down.
                  I entered the bios and began to de-provision Intel AMT - it began with a reboot and then prompted me to de-provision AMT - proceed Y/N -
                  I pressed Y and hit enter, and I thought the PC shutdown, but perhaps it actually lost power at this point. I had the power adapter plugged in but apparently the plug from the wall came out of the brick when I wasn't noticing so 1 of two things could have happened…
                  Something went wrong with the process, or it lost power during the process and corrupted something
                  I tried making a HP recovery...
                  10-12-2023, 07:42 PM
                • ktmmotocross
                  Did all laptop works when they lost one of power phases for cpu?
                  by ktmmotocross
                  Hello.
                  Have this acer nitro that have short on 1of4 for powerstage for cpu. i remove shorted drmos and power for cpu and laptop start but have no video or BL on lcd. all voltages are now ok. as i see there is some amateur injection marks so i think someone toasted cpu with highvoltage.
                  quistion is - should all/most of laptop works in basic when lost one of power phases for cpu/gpu ? i know that many does, but did all?...
                  04-25-2025, 02:06 AM
                • the Benninger
                  ADVANTECH AIMB-581 lost Tsop
                  by the Benninger
                  hi folks, The BIOS chip of this board literally went missing during its maintenance. It might have happened that the socket where the chip is connected accidentally opened. As a result, it was lost and is no longer present. I have no idea if it’s 8MB or 4MB. If someone could lend me a hand, I’d be grateful.
                  Advantech
                  model: AIMB-581 Rev A1
                  s/n: 19A2058102...
                  03-18-2025, 01:35 PM
