Lost MAC Address After BIOS Rewrite – Need Help Restoring on HP 800 G1 SFF
  • jjkevi
    • Jul 2025
    • Netherlands
    I’ve run into an issue with my HP 800 G1 Small Form Factor PC after performing a BIOS rewrite. Everything works except for one major problem — the MAC address for the onboard network adapter is missing.
    Here’s the situation:
    • Model: HP 800 G1 SFF
    • OS: Windows 10 Pro
    • Cause: After rewriting the BIOS, the system lost its original MAC address.
    • Symptoms:
      • Network adapter shows a generic or invalid MAC (or sometimes blank).
      • No Ethernet connectivity unless I use an external USB-to-Ethernet adapter.
    • What I’ve tried:
      • Checked BIOS settings (no MAC override option available).
      • Tried various Intel and HP utilities to restore or inject the MAC address.
      • Looked for NBDMFit tools, but most versions I’ve found are 32-bit and won’t run properly on my setup.
      • No luck so far with registry edits or netsh commands.
    From my research, it seems HP uses a special service tool to rewrite the MAC address into the NIC’s EEPROM after motherboard replacement or BIOS flashing. Unfortunately, I haven’t found a compatible one for this model.
    If anyone has experience with HP MAC address restoration tools (preferably 64-bit) or a workaround for the HP 800 G1, I’d really appreciate guidance.
    Thanks in advance for any help!
  • ianasystems
    Need Help Restoring BIOS and MAC Address for HP ProDesk 600 G1 SFF
    by ianasystems
    I'm currently dealing with a BIOS corruption issue on my HP ProDesk 600 G1 SFF desktop PC.
    After the BIOS got corrupted, my PC was showing no display, and I had to take it to a repair shop where the technician removed the BIOS chip from the motherboard and installed a BIOS I provided from a file I downloaded from the official HP website.
    While the display issue was fixed and the system is powering up again, there's one major problem: the Ethernet MAC address is now showing as FF:FF:FF:FF:FF:FF, indicating that it's been wiped or corrupted as well....
    04-16-2025, 02:04 PM
  • intelg
    HP Elitedesk 800 G6 lost BIOS admin password
    by intelg
    Hello everyone, I am looking for help as I am struggling to remove lost BIOS Admin password on an HP EliteDesk G6 800 series desktop. I wanted to reset the vPro remote control IP kvm for homelab use.
    Here is the hardware identification specs:
    HP EliteDesk 800 G6 Desktop Mini PC
    Intel(R) Core(TM) i5-10500 CPU @ 3.10GHZ 16384 MB RAM
    BIOS ver S21 Ver. 02.05.01 01/05/2021
    Born on date: 07/26/2021
    SN MXL11841GN
    SKU 3X8V9UCHABA
    UUID 8116E79EF6FFE94DB0B98A3188270C5C
    SYSTEM BOARD ID 8710
    SYSTEM BOARD CT NUKBER PJLHQ0A8JF236L...
    11-03-2023, 02:05 AM
  • macabook
    by macabook
    🧩 Initial Issue
    07-24-2025, 02:17 PM
  • pirati
    by pirati
    10-27-2025, 04:20 PM
    by Vesko356
    08-11-2023, 03:27 AM
