ADVANTECH AIMB-581 lost Tsop
  • the Benninger
    • Nov 2022
    • 189
    • venezulan
    hi folks, The BIOS chip of this board literally went missing during its maintenance. It might have happened that the socket where the chip is connected accidentally opened. As a result, it was lost and is no longer present. I have no idea if it’s 8MB or 4MB. If someone could lend me a hand, I’d be grateful.
    Advantech
    model: AIMB-581 Rev A1
    s/n: 19A2058102
  • the Benninger
    • Nov 2022
    • 189
    • venezulan
    Get the bios on the support page if anyone needs this please write in the post
    • bseinfo
      Brother MFC-J480DW printer stuck in maintenance mode
      by bseinfo
      I have a Brother MFC-J480DW printer stuck in maintenance mode (BHL2 USB Maintenance). The screen only shows white bars, and it’s completely unresponsive. The official Firmware Update Tool doesn’t detect it, and I’ve tried multiple versions.
      I’m looking for the raw firmware file LZ5313_L.blf (or .djf), compatible with FILEDG32.exe, so I can attempt a manual recovery.
      If anyone has a full dump of this model (or a compatible one like MFC-J485DW or J885DW), or knows a private Discord or Telegram group where this kind of firmware is shared,...
      07-05-2025, 10:53 AM
    • jjkevi
      Lost MAC Address After BIOS Rewrite – Need Help Restoring on HP 800 G1 SFF
      by jjkevi
      I’ve run into an issue with my HP 800 G1 Small Form Factor PC after performing a BIOS rewrite. Everything works except for one major problem — the MAC address for the onboard network adapter is missing.
      Here’s the situation:
      • Model: HP 800 G1 SFF
      • OS: Windows 10 Pro
      • Cause: After rewriting the BIOS, the system lost its original MAC address.
      • Symptoms:
        • Network adapter shows a generic or invalid MAC (or sometimes blank).
        • No Ethernet connectivity unless I use an external USB-to-Ethernet adapter.
      • What I’ve tried:
        • Checked BIOS settings (no MAC override
      08-11-2025, 05:05 AM
    • jerem57m
      Lost bios password on HP Spectre Pro 13 G1 (X2F00EA)
      by jerem57m
      I hope I'm in the right place to make my request. Now that I've made my presentation, I'd like to make a request regarding a 2017 HP Spectre PRO 13 G1 laptop. I have a lost BIOS password. I really don't remember setting a password on this computer, and after changing the battery, the computer no longer wants to boot without it. Can you help me remove the password?
      I read on the forum that someone who had a model similar to mine managed to remove the password, so I figured with any luck I'd find some help here.
      Exact information:
      Product: X2F00EA
      Trade name:...
      07-17-2025, 06:26 AM
    • vuko
      advantech innocore dpx-w220 bios
      by vuko
      advantech innocore dpx-w220 can you remove or reed bios password,please.I will put the 2 files....
      07-03-2025, 02:45 AM
    • rive.hafintosh
      HP Probook 650 G4 - Lost power?During AMT de-provision process, now I get blackscreen
      by rive.hafintosh
      First here is how things went down.
      I entered the bios and began to de-provision Intel AMT - it began with a reboot and then prompted me to de-provision AMT - proceed Y/N -
      I pressed Y and hit enter, and I thought the PC shutdown, but perhaps it actually lost power at this point. I had the power adapter plugged in but apparently the plug from the wall came out of the brick when I wasn't noticing so 1 of two things could have happened…
      Something went wrong with the process, or it lost power during the process and corrupted something
      I tried making a HP recovery...
      10-12-2023, 07:42 PM
