MSI P67A-G43 (B3) Missing Cap
  • DaleCarr
    • Sep 2015
    • 14
    I have a MB missing a cap and need to know if anyone can ID it for me with a like board or a schematic please. I circled the missing cap in the attached pic.
    Its an MSI P67A-G43 (B3) Motherboard
  • Bungz
    • May 2013
    • 133
    Re: MSI P67A-G43 (B3) Missing Cap
    Pretty sure it will be a 560uf 6.3v.
    Google nor proving as useful as usual
    • DaleCarr
      • Sep 2015
      • 14
      560 or 470 was my thoughts also.
      • cyjun1990
        • Jan 2016
        • 16
        • Philippines
        560
        • psychophat
          Fan Man
          • Feb 2013
          • 12
          • PH
          It's this one 560 4v . . . brand aside.
          • ugamazing
            820-02020 PPBUS_AON missing
            by ugamazing
            Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
            Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
            02-05-2025, 04:21 PM
          • gurj1979
            Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
            by gurj1979
            Hey guys.
            Need help with this one.
            Fan not spinning due to missing PWN Fan signal.
            Also 5 seconds from powering up it freezes, unless in BIOS.
            But as soon as Windows starts to load, it will freeze.
            CPU is COLD / Room temp when it freezes.
            I've replaced the CPU, same problem.
            Replaced SIO/KBC IT8987e and reprogrammed - same problem.
            Replaced fan - same problem.
            Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
            Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
            08-19-2024, 05:22 PM
          • salopian
            Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
            by salopian
            Hello. I would need some advice please.
            My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
            He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
            I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
            I have already replaced the logic board with another...
            02-27-2021, 07:30 AM
          • ein_individuum
            Missing Capacitator Intel I9-12900KF CPU
            by ein_individuum
            I bought a use Intel I9-12900KF CPU and i received it damaged. But it looks like only one component one the backside is missing. But the solder pads looks fine.
            I already "googled" it and compare the backside picture of other LGA1700 12th Gen CPU. They look all the same, no matter if its an I9 or an I3, even the Pentium. And at that spot should be a capacitor.
            Does anyone have a schematics or assembly diagramm of the alder-lake cpu-backside? Or just know what size and value i need to replace the missing capacitator.
            08-06-2025, 01:36 AM
          • reessi
            HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
            by reessi
            I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
            It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
            What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
            I have checked these lines in diode mode and they seam normal -> 600.
            I have checked to see if they come on for even a fraction of a second...
            07-15-2025, 09:14 AM
