AZZA mainboard
  • davmax
    • Dec 2005
    • 899
    AZZA mainboard
    This Azza 601BM is cheap and rare. It was filled entirely with DO brand caps made about 2001. They have lasted pretty well. However to get it working all the low ESR caps were replaced. It now computes fine however whenever the hard drive works hard the video display suffers steaking noise breakup. Because the video is on board my guess is that at least one of the ordinary caps (not low ESR) is faulty and therefore not decoupling the noise generated by hard drive action. The computer had to be pressed back into service as a server!!! I will try get it back to replace all the small caps (caps that I do not normally have to hand, low ESR I do have).
    Has anyone come across this type of hard drive interaction with the display?
    160Gb WD SATAII Server grade
    Nvidia 8500GT 256Mb
    Samsung 18x DVD writer
    33 way card reader
    Windows XP Pro SP3
    17" Benq FP737s LCD monitor
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: AZZA mainboard
    post a pic.
    is that the dual 370 board?
    • davmax
      • Dec 2005
      • 899
      Re: AZZA mainboard
      Sorry no full pic right now as I have no access. Some pics taken and posted in the Bad cap threads yesterday https://www.badcaps.net/forum/showthread.php?t=4921. It is a single 370 microATX board AGP + 3 PCI slots.
      Nvidia 8500GT 256Mb
      33 way card reader
      Windows XP Pro SP3
      • zandrax
        Hit and miss
        • Dec 2007
        • 1157
        • Italy
        Re: AZZA mainboard
        Originally posted by davmax
        [...] whenever the hard drive works hard the video display suffers steaking noise breakup. Because the video is on board my guess is that at least one of the ordinary caps (not low ESR) is faulty and therefore not decoupling the noise generated by hard drive action. [...]
        I had the same issue but with an old Cirrus Logic isa graphic card on a noisy 486 mobo. Since other cards worked fine and had an oscillator on board while the CL hadn't, I thought it was a side effect of card's cheapness.
        On your motherboard it may be due to some unfiltered noise: since it's used as a server board, it would be interesting to find out if noise affects only the vga connector (the board is ok, screen dizziness apart: you can plug any old pci graphic card, e.g. old Ati Rage ones) or other periphericals too (e.g. hard disk controller: there is a SMART parameter called UltraDMA CRC Error count which increases if noise corrupt data transferts).
        Zandrax
        Have an happy life.
        • davmax
          • Dec 2005
          • 899
          Re: AZZA mainboard
          Thanks for input I am going to recall the computer in about two weeks. The PSU has already had a 150,000hr fan installed and I plan the install a new Arctic Cooling Copper Lite heatsink and fan on CPU (Fan 137,000hrs mtbf). I will then investigate this video problem.
          Nvidia 8500GT 256Mb
          33 way card reader
          Windows XP Pro SP3
          • federalhouse
            **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
            by federalhouse
            I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
            **Background:**
            I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
            **What I've Tried So Far:**
            1. I accessed
            08-01-2024, 07:03 PM
          • ash91
            Hp pavilion 15 not detect hard drive
            by ash91
            Hello gentelmen .... this is my first post and sorry for my bad english,
            so my proplem is my laptop keep losing hard drive even if i but the
            hard disk in the cady (the box that can replace the dvd rom with hard disk)
            when i turn the laptop on the massage that said no boot media found pop on
            the hard disk is fine and to be sure i try another hard
            i also update my bios to the last update
            the 5 volt is present on the hard connector on the motherboard
            the dvd rom work fine when i but a windows dvd in it
            also when i boot from flash...
            06-07-2023, 01:45 PM
          • Mirenia
            Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
            by Mirenia
            I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
            I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
            In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
            The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
            03-30-2025, 06:47 AM
          • orcic
            MASTER TL240 and new mainboard LW36BKC01
            by orcic
            I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
            The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
            After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
            Now I have some doubts about how to connect the new mainboard to the old power supply.
            First of...
            05-12-2023, 08:10 AM
          • madura2010
            DAY11AM6E0 hard disk drive and optical disk drive not detected
            by madura2010
            Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
            i checked the connectivity of ribbon=good communication with hard and motherboard
            changed hard disk and checked=3f0 error persist
            sata power=+5v available
            Then checked data capacitors=all good
            Then checked data lines path connectivity to pch=all good
            reflashed...
            03-12-2023, 09:09 AM
