Problem recapping not one but TWO Soyos
  • roazena
    • Feb 2008
    • 7
    Noob here. A friend's homebuilt Soyo blew and I tried buying a replacement mobo on eBay.
    The original board is a K7VME and the new one is a K7VXA (Dragon Plus). The new board arrived and it too had bad caps. No POST.
    I took down the specs of all the bad caps on both boards and ordered Panasonic replacements from STSI. After learning the hard way that most soldering irons are worthless for this tast, I finally got a Weller 30W/130W iron this morning and set about removing the old ones and replacing them -- being careful to note negative and positive, using a rubber bulb and dental pick to clean holes. Radio Shack standard rosin-core 60/40 .032" diameter solder.
    Neither board POSTs or beeps. With the new board, I noticed too late that there was a broken trace on the backside from one of the power connector's terminals, but the power LED on the board still lights when power's on so I'm not sure what that trace was supposed to power.
    I was *trying* to save my friend money by doing this myself, and between us we've already spent $200 on boards, RAM, and electronics supplies.
    Not to mention the roughly seven hours I've sat at this table since this morning.
    Help.
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Problem recapping not one but TWO Soyos
    post pics of the damaged trace.
    i just did 7 kt600 dragon plus for a customer and they all made it.
    nasty mess of exploded ost in clear jackets.
    • roazena
      • Feb 2008
      • 7
      Here's the picture from the Dragon Plus. Please ignore my feeble attempt to solder it back down to the board.
      I suppose there's a chance that both boards' CPUs were (separately) fried and this is why nothing's POSTing.
      • roazena
        • Feb 2008
        • 7
        I'll post a pic of the other board after my camera's batteries are done recharging --they were so low the autofocus refused to work.
        • roazena
          • Feb 2008
          • 7
          This is the K7VME.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            looks like a shorted card in pci 1 did that.
            just solder jumpers and test again.
            • roazena
              • Feb 2008
              • 7
              So it's safe to solder a jumper to the tiny thin strip of copper (I assume you're referring to the Dragon Plus pic). Would that actually be responsible for the board not POSTing?
              • roazena
                • Feb 2008
                • 7
                I don't get why the K7VME isn't working. How can I tell if I ruined something?
                • davmax
                  • Dec 2005
                  • 899
                  There are a number of possibilities other than a fault.
                  1. Make sure all caps are inserted with the correct polarity.
                  2. Clean up your soldering. One pic shows what looks like fine steaks of solder splattered on board. First get some methylated spirit and an old tooth brush (stiff bristles) and clean off all solder flux (looks horribly black, hope you used good quality solder) and dry it off. Then with a magnifying glass check for fine a minute solder pieces that may be causing a problem. Take a close look at your soldering and make sure the connections are good.
                  3. The CMOS(bios) may be corrupted. Look for the reset jumper (three pins oftem labelled CMOS or Jbat) move the jumper to the alternate position leave for 15 sec and then move it back to the default position. If you can access a manual check that this jumper is in the default position before you power on.
                  Gigabyte EP45-DS3L Ultra Reliable (Power saver)
                  Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
                  160Gb WD SATAII Server grade
                  Nvidia 8500GT 256Mb
                  160Gb WD eSATAII Server grade for backup.
                  Samsung 18x DVD writer
                  Pioneer 16x DVD writer + 6x Dual layer
                  33 way card reader
                  Windows XP Pro SP3
                  Thermaltake Matrix case with 430W Silent Power
                  17" Benq FP737s LCD monitor
                  HP Officejet Pro K5300 with refillable tanks
                  • roazena
                    • Feb 2008
                    • 7
                    They were. The board appears to be standard on "white half-circle = negative."
                    No idea how to tell if 60/40 rosin core solder is good or not. I will get methylated spirits tomorrow and clean the black stuff off.
                    This has been done with both boards, with the power supply unplugged (as per the Dragon Plus PDF manual).
                    Thanks for the advice and I'll report tomorrow on all of this.
                    • Fizzycapola
                      • Oct 2006
                      • 423
                      That soldering doesn't look too cool. After soldering what you see shouldn't look any different from the factory soldering.
                      Rubycon Rubycon Rubycon
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Check The Power Supply!!
                        Mann-Made Global Warming.
                        - Dr Seuss
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          The processor may have been damaged.
                          I hope you were careful when you reclipped the heatsink.
                          Is it socket A or slot A?
                          Socket A is the most likely to have crunched cores.
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Arc A770 16 GB
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • howardc64
                            by howardc64
                            07-24-2025, 05:17 PM
                          • Hakuu
                            by Hakuu
                            Hi There,
                            More Details
                            TV Model - LG OLED77G1PUA
                            07-12-2023, 02:37 PM
                          • jb_Bak
                            by jb_Bak
                            CN6401
                            Pin 01 NC
                            Pin 02 NC
                            Pin 03 "BL_ON": 0V
                            Pin 04 "N/C"
                            Pin 05 "STBY 3.3V": 3.5V
                            Pin 06 "GND": N/C
                            Pin 07 "AC_OFF"...
                            09-27-2021, 04:52 PM
