Dell GX270 still works regardless
  • SteveNielsen
    Retired Tech
    • 2327
    Check this out. This board has been working fine several years for me and I opened it up for some parts juggling after a recent upgrade to another box. Most of the caps along the CPU have opened and leaked. Not only that but the thermal goo on the CPU is weird, there is hardly any of the grayish paste I'm used to seeing and the CPU land and heat-sink have more of what looks and feels like something between vaseline and light machine oil than thermal goo. Do some thermal pastes contain that much oil? Or did some bonehead put it on there?
    I've ordered a cap kit for it. I figure it's a darn good board to have lived through that. It is from the smallest of the GX270's and I'm going to fit into a full size case after I re-cap it. One of you guys said you'd done that to one and had to mod the tray or something to fit. It appears the tray jacks the board up too high to fit the backplane of a bigger case. Of course the mtg holes on the MB don't jive either but I think I can work that out. Any tips?
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Dell GX270 still works regardless
    I received 4 of these GX280 small form factor PCs a while back and all but one had bad caps in the same area as yours.
    https://www.badcaps.net/forum/showthread.php?t=19392
    In addition, the power supply also had some obviously bloated caps so you want to check that as well too.
    After factoring in the time needed to desolder, cost of ordering new caps and given the age, and my general dislike for Dell (personal reasons) I decided to not to repair these and use them for parts. I think I recapped only the bloated caps on the power supply just to get one or two working.
    If you need the power supply, let me know. You can have them for $0 + the price of postage assuming this power supply is compatible with the GX270?
    --- begin sig file ---
    --- end sig file ---
    • SteveNielsen
      Retired Tech
      • 2327
      Thanks, I'm ok for PSUs at the moment. I've got no love affair with Dell either but this board has been good to me and deserves to live on for a while. It'll move on down the line in the household once I get it in a bigger case.
        • 31025
        open the psu and check the ceramic cap in front of and to the right of the main fet.
        if it's discoloured, replace it with a 2Kv rated one before it takes out the psu.
        • SteveNielsen
          Retired Tech
          • 2327
          While I'm not working on the PSU for the GX270 that is good advice. I'm not planning on using the original PSU when the MB goes in another bigger case.
          What has me curious though is the thermal paste condition, I've never seen it turn oily like this before. I doubt this board has been worked on before, knowing where it came from, so I doubt anyone has put actual grease or oil on the CPU/heatsink. There's no oily stuff in evidence anywhere else.
            • 31025
            who knows.
            manufacturers use all kinds of crap.
            i'v seen something like thick vasaline in a big psu once on the fets.
            on pc's i'm more used to the pink or gray bubblegum.
            • c_hegge
              • Sep 2009
              • 5219
              I'd quite common to see bad rubycons in those. For that reason, I polymodded the last one I got to recap.
              • SteveNielsen
                Retired Tech
                • 2327
                The bad boys on this board are MCZ series which don't have a good reputation from what I read around here, plus the visibly blown ones are all in a row nestled between the CPU and a heat sink for two ICs so it's a heat trap area and I'm sure that has something to do with them losing it. I've thought about polymodding too, but for this I decided to give a bit of well deserved business to Topcat and buy one of his kits.
                • c_hegge
                  • Sep 2009
                  • 5219
                  Actually, MCZ are usually very reliable when not overheated. In a standard ATX case with good ventilation, they usually hold up very well.
                  • Uranium-235
                    Comrade Glimmer
                    • Aug 2007
                    • 5042
                    • US
                    the heatsink of those dells have fins that are VERY close together. It easily gets clogged with dust. Combine that with the spacing and you have a formula for a heating disaster
                      • 31025
                      worst of all, they are DELL
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        Update:
                        The re-capped GX270 MB is successfully transplanted into a Dimension 4300 case with no mounting modifications required. I lucked out having that 4300 case. The GX270 MB tray fits perfectly, everything lines up. Even the front panel connector matches up and the leds, switch, usb and sound ports work perfectly.
                        • Bowline
                          by Bowline
                          06-11-2025, 10:13 AM
                        • TheQuentincc
                          Dell XPS 9300 (LA-H811P) internal display only shows Dell logo then nothing (everything else works)
                          by TheQuentincc
                          I have a Dell XPS 9300 that's working perfectly fine with an external display plugged, from windows the internal display isn't detected. At boot I can see the Dell logo then when it should display the boot/bios or whatever the screen goes black (no backlight, no image using a flashlight). I tried unplugging everything on the motherboard except the eDP cable but it didn't helped (so it's not the lid sensor). LCDVDD/backlight power are powered down when this happen, PANEL_BKEN_EC and ENVDD_PCH are also down to 0v. It's weird, it almost feels like the motherboard is shutting down the display...
                          06-26-2025, 01:44 PM
                        • CapLeaker
                          Dell ATX PSU won’t start, but forcing it works fine?
                          by CapLeaker
                          Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                          Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                          10-28-2024, 06:59 PM
                        • Grucha98
                          Dell Latitude E7440 battery not charging only works on AC Adapter LA-9591P
                          by Grucha98
                          Hi, i have problem with dell E7440, battery is not charging. Idk all story. Original Dell Adapter broken up (its not give 19V) i guess first ac adapter broken up and it broken charging circuit in laptop. Laptop has clone battery (Green Cell)
                          Laptop works on clone adapter, and its not charging battery. Like on photo. I checked mosfets near battery plug. They are not shorted. But on PQ809 and PQ810 are low on diode mode (both 0.25V) I desoldered them and check on bench and they are good both 0.5V on diode mode. I checked only drain - source way. So its board circuit it should be higher,...
                          09-09-2024, 11:22 AM
                        • huzo
                          Dell 5590 no image on LCD,HDMI works ,the board works...
                          by huzo
                          The board is LA-F411P ,DELL 5590 ...
                          The screen polarises,no backlight,no image,only black screen,tried another screen,the same,so there is no backlight,but there should be an image when i shine a lamp behind the screen,but there is none...only dark screen...when screen is connected and i press F8 to turn the image over to the external monitor, the external monitor gets coloured bars ,but when i disconnect the cable from the EDP ,the HDMI picture is good...What could be the problem? I don't have another edp cable, but i measured it with meter and it comes out good...i am baffled......
                          02-16-2025, 03:08 PM
