Advent 3117 PC mobo (Trigem 865PE)
  • JEWilson
    • Sep 2007
    • 369
    • Scotland, United Kingdom
    Rec'd this mobo as known dead.
    Was formerly used with a Bestec ATX-250-12E Rev F1
    Have tried to start with known good PSU which does not have an on/off switch
    Symptom - PS-ON will not go low.
    The mobo front panel header for Power on will not start mobo.
    Took reading with mmeter across the two pins, only drops to 4.88V
    Shorted pins 13,14 on ATX (2 x10) connector - can get the PSU,
    in turn, mobo to start but the southbridge is getting very hot. Albeit I shut
    the system down from the wall outlet before the s/bridge gets
    totally fried, the mobo did appear to POST.
    Next, using freezer spray, cooled down the s/bridge for sufficient
    time to observe mobo behaviour. Only had diskette drive attached
    with Memtest86 v3.3 utility - this all goes smoothly and will load
    the utility from diskette into memory and starts testing memory.
    I have tested the mobo to the extent, tested ATX (2x10) connector
    for ground fault on pins 3,5,7,13,15,16 and 17 all ok
    The Intel part FW82801EB SL73Z - is it known to have a thermal problem?
    Is the board exhibiting problem consistent with over voltage problem per
    Bestec failires?
    Any insight, help, advice and guidance appreaciated
  • Harvey
    • Apr 2007
    • 264
    Re: Advent 3117 PC mobo (Trigem 865PE)
    Was
    Says its all really, its going to be a killed southbridge, the most obvious symptom being the overheating.
    FW82801EB SL73Z
    Hmmm, I've just recently been looking at a MSI 865PE NEO2-P board, that has a blown southbridge, seemingly from a design fault in the USB if http://www.devhardware.com/forums/mo...b-s-33530.html is accurate. It's southbridge is a FW82801EB SL73Z too... I wonder if there's a design fault in the chip??
    • JEWilson
      • Sep 2007
      • 369
      Maybe
      However, so far as I have forced PS-ON to start the PSU and
      supply power to the board, the first time I did this, I got a
      clicking sound consistent with starting into a short. The second
      time I started the mobo, as I recall, the clicking sound disappeared
      and has remained consistently so since. The sound (FWIW) came
      from around the s/bridge and at first, I figured it might be the xtal.
      Such a first short given the Bestec PSU may have resulted from an
      over voltage condition which did for the mobo in the first instance.
      So...
      Given I have tested ground faults o/c on the mobo and have none,
      I suspect a short had developed in the first instance which accounts
      for the PS-ON being unable to be pulled to ground.
      The clicking sound may have accounted for the original fault and that
      further, shorting PS-ON to ground on the ATX connector to get the
      PSU and mobo to start may have generated a further short such as
      with a supply cap on a rail which delivers supply to the s/bridge.
      This may account for the established (that being so) and/or further
      short as suggested, developing the heat in the IC.
      Looking at the part
      see further http://www.alldatasheet.com/view.jsp...word=FW82801EB
      Having investigated the part, the IC can tolerate temp up to 109 deg C.
      IC supply voltage should be 1.8V albeit it can supply 3.3V I/O and tolerate up to 5V with some of its buffers (see p1 of 84)
      The power pins detail is shown at p48 of 84 @ 3.2.20 Power and Ground at Table 26 as well as singalling for power at p42 of 84 @ 3.2.10 Power signals at Table 16
      Note VRMPWRGD - should be connected to the processors VRM Power Good
      Turning to regulation, p51 of 84 @ 3.4.1 Power planes and Table 29
      Vcc3_3 IC I/O is powered at 3.3V by PSU
      Vcc1_8 IC Logic is powered at 1.8V by PSU
      V_CPU_IO is powered by the main PSU via CPU VRM
      So far as the PS-ON failure points to a mobo logic problem and
      the s/bridge IC develops a thermal problem when the first issue
      is circumvented, my attention is drawn to regulation of the IC.
      Where and how is 1.8V synthesised? The ATX PSU does not deliver
      a voltage such as this. If any cap are s/c- really need an ESR meter
      to do this job.
      Any suggestions?
      • JEWilson
        • Sep 2007
        • 369
        Sorry
        Got distracted
        I do have one of those boards and was planning to work it
        up for production use. These are regarded as being a high-spec.
        mobos so I believe. Of course, the matter with repeated failures
        on MSI 865PE NEO2-P MS-6728 re - USB, tells me at this stage;
        just a guess please note, due to, very probably bad caps vis-a-vis
        a cap or caps failure.
        Get a BOM of the electrolytics and establish whether (not) they
        are of an acceptable quality. To do this, refer to the good
        https://www.badcaps.net/forum/showthread.php?t=414
        and bad
        https://www.badcaps.net/forum/showthread.php?t=388
        caps lists respectively.
        You may also want to consider the power sunk by a board of this
        spec. under light and full load conditions as well as the number of
        devices attached such as with;
        USB
        1394
        LAN
        HDD
        FDD
        Fans
        and what PSU you decide to mate these with.
        For a quick giude to power usage, you could go to
        http://www.extreme.outervision.com/p...ulatorlite.jsp
        This is the free, lite version - you will have to pay to get the
        pro version which details guidance re - current draw on the
        relevant PSU rails.
        HTH
        • ChaosLegionnaire
          by ChaosLegionnaire
          09-13-2022, 09:02 AM
        • Cerberuska
          Mobo MSI B550-A PRO password popup
          by Cerberuska
          Hello guys,
          I have interesting problem. My MoBo MSI running on Ryzen 7 w/o graphics just good. I swapped to Ryzen 5 5600G and on the boot I stuck with screen on picture. Enter Password. I checked BIOS setting with Ryzen 7, no security is enabled, BIOS password or TPM.
          BIOS I updated to last one.
          any suggestions?
          And same thing for two different 5600G, and yes, MoBo supposed to support it.
          Thank you...
          11-10-2024, 01:23 PM
        • mrsith
          Dell G3 17 3779 - no display after mobo replacement
          by mrsith
          Hi guys,
          I have a friend's Dell 3779 that came to me with severely shorted mobo. Did not manage to isolate the cause, most likely that was a bga shorted. Went for a replacement motherboard. Got one from China, apparently it's been tested prior to shipping. The mobo starts up normally but I am getting no display whatsoever.
          Tried using external monitor, but being blind I am not sure if laptops goes as far as booting to Windows, a d without it I cannot get hdmi to work. Can't see boot menu options to make sure it boots to Windows. Went ahead and did a blind bios update,...
          04-30-2023, 05:11 AM
        • Ibod
          Corsair cx600 psu & ASRock B450Pro4 mobo wont start
          by Ibod
          HI I have a PC using a Corsair cx600 psu & ASRock B450 Pro4 mother board that won't power on after a shutdown (replaced a dead drive in a raid array) Not the boot drive.
          With most things unplugged, including the 24 pin ATX connector, but not the ATX12v to cpu, I have +5.01V on the +5vsb pin 9 from the PSU. When I plug the 24 pin back in to the mobo, the +5vsb fluctuates between 1.1v & 1.9v.
          Not sure where to go from here ?
          Is the PSU at fault or is the mobo causing the problem
          Look forward to any help :-)
          If I plug the 24...
          02-08-2023, 11:00 AM
        • Felipe_Serra_83
          Dell Inspiron 14-5448 - fan turns off and mobo keeps running
          by Felipe_Serra_83
          Hi, everyone. First post of an actual repair. I'm a technician but a complete newbie with laptops.
          So I got this Dell Inspiron to play with.
          No charger, so I connected to my bench PSU.
          The laptop also didn't include: hard disk (I added one of my own for testing, see below) and wireless PCB (but I doubt this could have anything to do with this particular failure).
          ------What it did (and didn't do)------
          1) I turned it on and it powered on. Powered down in 2 seconds by itself.
          2) Removed RAM, changed slot. Same...
          04-04-2024, 12:39 PM
