ASUS P5LD2 SE Recap and partial Polymod
  • c_hegge
    • Sep 2009
    • 5219
    I ended up with this board as a freebie, just because it had a bad cap in between the PCI slots (an 820uF 6.3V KZG to be specific). It appeared to be working fine, though in spite of the bad cap. I didn't have very many 820uF lytics on hand, but I have LOTS of 820uF 2.5V polies, most of which are scavenged from motherboards, plus a few new Fujitsu "bumble bee" polies from Topcat.
    So, after measuring the voltages on them, I found that only a few of them had 5 or 3.3V on them - most were on the low sides of RAM and Chipset VRMs, so here was my approach. For the 820uF parts which were on the high sides of VRMs, I used the few 820uF 6.3V Ruby MCZ and MBZ caps I had left. The VRM low side caps which had less than 2V on them, I used Fujitsu 820uF 2.5V polies, and for the USB and Audio filtering caps, I used 1000uF electrolytic caps. The Ethernet NIC controller was also missing the cap on its power supply from the factory ( goes to ASUS for that one). I added a 220uF 16V Panny FR there. The best part is, I managed to get all of them in the first time without reverse-polarising any of them.
    The board boots to the BIOS reliably still. I haven't installed an OS yet, but hopefully, it will work fine.
    EDIT: I didn't touch the CPU VRM on this board. It came with Panny FJs on the VRM high side and NCC PSC Polies on the low side.
  • BigTroll
    • Sep 2010
    • 1317
    • LAMBDA SOND
    Re: ASUS P5LD2 SE Recap and partial Polymod
    great work! can't believe they would leave out a cap like that wonder if it affected network stability.
    My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
    • c_hegge
      • Sep 2009
      • 5219
      I can. It is ASUS after all.
      • SIDMX
        • Nov 2010
        • 165
        • Mexico
        Nice job! You probably saved the NIC from a sudden death in case of a bad P/S or something like that by adding the cap, I too measure the voltages to know whether I can get away with a lower voltage cap wish my freebies came in such a decent condition needing a recap or other quick fix but somehow I always get messed boards , anyways that's a nice board I like the layout, clean and simple except those misaligned DIMMS, hope it never shows the so dreaded Asus-Sudden-Death-Sindrome though.
          master hoarder
          • May 2008
          • 12175
          • Bulgaria
          I just did a partial recap on (another) ASUS board 2 days ago. The patterns seems to be that caps close to the PCI slots are on the 12V, 5V, and 3.3V rails. These are usually general filters, so most of the time it's not critical if they go bad. There may also be a cap for 5VSB and the Southbrdige Vcc (normally 3.3V and always ON even with the board turned OFF), again close to the PCI slots, but not necessarily.
          Yup, I do the same as well, since my 1000 uF and 820 uF electrolytic cap stash is always low, whereas my 2.5V 820 uF poly cap supply isn't that bad (I have a pile of dead Xbox 360 motherboards). My general principle is, only use 6.3V and higher voltage electrolytics if they are needed due to voltage requirements.
          No surprise there. ASUS boards always come with a ton of caps not installed from the factory, hence many empty spots. The good thing about that, however, is that it allows you the flexibility to use mid-grade low-ESR caps in higher numbers (if that's all you have on hand, for example).
          ... or just add more crappy KZG caps to extend the board's life a tiny bit longer before they all bulge .
          Hehe, I've recapped ASUS boards more than any other brand, so I'm almost "used to" putting my caps in "backwards" .
          Nice recap, by the way.
          With a crappy PSU, it probably would.
          • c_hegge
            • Sep 2009
            • 5219
            The PSU was a recapped K-Mex PW-450 which I installed a few years ago. It is one of K-Mex's better units and isn't too bad. It will do 350W with everything in spec.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              Yeah, Key Mouse PSUs aren't bad, really. I know of several on their 7th year or older, with the stock fukyoo/asia'x capacitors, still not bulging. As opposed to other cheap brands they usually provide adequate cooling.
              A working TV? How boring!
              • Dan81
                SNES-powered
                • Oct 2013
                • 1866
                • Romania
                Is there any possibility that Delux PSUs are based on that? (minus adequate cooling,but that can be solved with a big Socket A fan)
                Main rig:
                Gigabyte B75M-D3H
                Core i5-3470 3.60GHz
                16GB DDR3-1600
                Samsung SH-224AB DVD-RW
                Delux MG760 case
                • c_hegge
                  • Sep 2009
                  • 5219
                  It's possible that they are made by Key Mouse, but there are also hundreds of other small OEMs they could use.
                  • Dan81
                    SNES-powered
                    • Oct 2013
                    • 1866
                    • Romania
                    Maybe. All I know is those either use YC caps (450W) or Seacon caps. (400W).
                    I guess both are crap,right?
                    Main rig:
                    Gigabyte B75M-D3H
                    16GB DDR3-1600
                    Delux MG760 case
                      master hoarder
                      • May 2008
                      • 12175
                      • Bulgaria
                      YC caps aren't too terrible. Still loads better than CapXon IMO - at least with decent cooling. Probably on par with Fuhjyyu (which, in my opinion, work okay for the most part but do have some "random" failures - and certainly many more with added heat).
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        When he says "YC" I think he's referring to the generic ones found in KME PSU's pictured below (BTW, I like the design of KME PSU's). Not Yang Chun that Solytech likes to use
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          I totally forgot there are two YC brands. In fact, just a few days earlier I saw a picture of them like the ones you posted, and I noted it to myself.
                          • Pentium4
                            CapXon Be Gone
                            • Sep 2011
                            • 3741
                            If in means anything when I see "YC" I think of the saturn ones as well. There are a lot more "Deer" than "Mice" PSU's out there
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              Nope. Depending on the model, Delux PSUs are either based on the AT-2005B platform (halfway decent, i've made one do 650W with room to spare, but i'm Th3_uN1Qu3 so it's to be expected ) or those godawful generic TL494/LM339 jobbies, with completely unapproved everything. Beware of the ones with the green label, 400-450W, i've seen those eat whole PCs for lunch when they fail. The 600W model is okay.
                              "Rexpower" and "Maxpower" PSUs are made by Key Mouse. Also the ones that come with KME cases (which are obviously made by them, too).
                              I'd actually say YC (the ones with the "saturn" logo) do better than Fuhjyyu.
                              Yes, those are the ones.
                              • Dan81
                                SNES-powered
                                • Oct 2013
                                • 1866
                                • Romania
                                Crazy enough,both my signature rig and secondary PC have the green label DeluX and both work fine.
                                The primary PC has a 450W one and that one seen usage for,no lies,7 years. Even though the fan was dying,it worked without a problem. Works even better now with a Socket A fan (Titan cooler for S370/A) despite now being loud. Maybe it's true that with good cooling,even Saturn (Yang Chun) caps can survive?
                                Forgot mentioning that this PSU survived easily power surges in storm times!
                                The 400W one I have it for a year,it has Seacon caps (anybody, can you please rate those?),but I still think it will work fine,since all it powers is :
                                -Pentium 4 1.8A CPU
                                -mATX board (P4P800-VM)
                                -DVD drive
                                -80GB HDD
                                -FX5200 128MB GPU
                                and that's all. All of those don't use so much power I guess.
                                Worth mentioning is that this PSU doesn't have it's original case anymore. I had to change it with another case from a Codegen 350W I discarded.
                                Good thing I didn't repair the Codegen with it's HEC(K) caps.
                                Main rig:
                                Gigabyte B75M-D3H
                                16GB DDR3-1600
                                Delux MG760 case
                                • c_hegge
                                  • Sep 2009
                                  • 5219
                                  All brands except for the Japanese brands (Rubycon, NCC, Nichicon, Panny, Sanyo) are junk. It's just a question of how junk they are
                                  • Pentium4
                                    CapXon Be Gone
                                    • Sep 2011
                                    • 3741
                                    c_hegge is correct. But if the Seacon are the big primary caps, you can leave them. Keep in mind they will probably not have the capacitance labeled. I've seen two pair, one said 470uF but read ~323uF and another pair of 470uF that read ~227uF
                                    • Dan81
                                      SNES-powered
                                      • Oct 2013
                                      • 1866
                                      • Romania
                                      Seacon are the 2 big primary caps and have 330uF written on them,and the rest (Saturn logo)
                                      Other components (sorry for me not knowing all the pieces in a PSU but I haven't given attention to those yet) listed:
                                      -ERI-35N (TB-1116T V:2.0)
                                      -EE-19 (TB-1120T)
                                      -EE-16 (TB-1118)
                                      PCB reads AT-2005B,which Th3_uN1Qu3 said they are halfway decent.
                                      Anybody know what other manufacturer uses AT-2005B?
                                      Main rig:
                                      Gigabyte B75M-D3H
                                      16GB DDR3-1600
                                      Delux MG760 case
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        • Romania
                                        A lot of brands use the AT-2005B platform. The most complete i've seen was in a Spire 450W. It still had crap caps (CS) but otherwise the construction was very good.
                                        • reparetech
                                          Lenovo NM-C421 partial RTCVCC short
                                          by reparetech
                                          Hi, I seem to have a partial short on the VCC3SW circuit coming from RTCVCC.
                                          • VCC3SW initially measures about 1.1V.
                                          • RTCVCC to ground measures approximately 9 ohms, but it does seem to fluctuate as I have measured it at 2 ohms.
                                          • There is no apparent water damage (or any other damage) on the board.
                                          • Removing PD0001 disconnects RTCVCC from VCC3SW and VCC3SW is back to 3.3V.
                                          • R1301 measures about 1M measured directly on board
                                          • C1608 and C1609 have been removed.
                                          • There is no CMOS battery connected.
                                          • C2001 is a no stuff.
                                          11-11-2022, 07:04 PM
                                        • TheNuclearOption
                                          Macbook Pro (820-2773) 20 ohm partial short on the pp3v8 power rail after water damage
                                          by TheNuclearOption
                                          water damage to the left speaker channel circuit caused an internal board short that has been carved out and damage to various capacitors. I removed both chips ur630 and ur600 both were burnt. Im not sure how to track down this partial short. Any suggestions would be greatly appreciated.
                                          The fuse is blown on ppbus and im getting 12.24v to the ppvbatt side of the fuse
                                          03-11-2024, 06:16 PM
                                        • iMuhtaseb
                                          820-02098 M1 Pro 14" PPBUS partial short
                                          by iMuhtaseb
                                          board came with no signs of life whatsoever, taking only 5V.. measured PPBUS and it was partially shorted (I kinda know this is not an easy one when it's a partial short) around 9 ohms in resistance and 0.012 in diode mode.
                                          Injected 2 volts since 1v was not enough and my initial suspicion was correct it was the haunted TPS62180.. and on board it looked little discolored to my on the visual inspection..
                                          Removed and replaced successfully now left ports take 20V for 2 seconds then switch to 5v and cycle.. on the right side it does not even power on the amp meter.....
                                          01-04-2024, 01:53 AM
                                        • ChristianBr01
                                          Dell 34 inch U3419W Monitor with thin stripes on partial screen
                                          by ChristianBr01
                                          I have a Dell U3419W Monitor that has some thin stripes on a part of the screen since Tuesday.
                                          This lines cover about a third of the screen and appear for 2 seconds before disappear for another 2 seconds.
                                          This repeats the whole time. I have not opened the case yet cause I had no time, but will try to fix it on this weekend. For me, it looks like a problem on the TCon... Am I right?
                                          Does someone have seen this before?...
                                          05-23-2025, 06:06 AM
                                        • gaelican
                                          Odyssey G9 Neo backlight partial failure.
                                          by gaelican
                                          I have an Odyssey Neo G9 that I was working on for a separate issue. After removing the motherboard and putting it back a few times I noticed that the lights on the display have stopped turning on altogether. I was able to determine that when the middle section for the backlights is disconnected, then the left and right side turn on, indicating that the fault is obviously in that area.
                                          After closely inspecting the mainboard I noticed that on the back side of it a few capacitors have been partially moved, one fully knocked off. I replaced the missing one with a new cap with the same...
                                          02-27-2025, 02:39 PM
