820-02098 M1 Pro 14" PPBUS partial short
  • iMuhtaseb
    • Jan 2017
    • 122
    • Palesine
    board came with no signs of life whatsoever, taking only 5V.. measured PPBUS and it was partially shorted (I kinda know this is not an easy one when it's a partial short) around 9 ohms in resistance and 0.012 in diode mode.
    Injected 2 volts since 1v was not enough and my initial suspicion was correct it was the haunted TPS62180.. and on board it looked little discolored to my on the visual inspection..
    Removed and replaced successfully now left ports take 20V for 2 seconds then switch to 5v and cycle.. on the right side it does not even power on the amp meter.. I replaced the CD3217B12 and it did not resolve the issue..
    I measured the diode mode on the LDOs of CD3127 and it seemed OK according to OBD. Where do I look next?
  • iMuhtaseb
    • Jan 2017
    • 122
    • Palesine
    Hi, I have put this forum in this board by mistake please admin move to laptop repair troubleshooting thanks since I cannot do it.
    • reparetech
      Lenovo NM-C421 partial RTCVCC short
      by reparetech
      Hi, I seem to have a partial short on the VCC3SW circuit coming from RTCVCC.
      • VCC3SW initially measures about 1.1V.
      • RTCVCC to ground measures approximately 9 ohms, but it does seem to fluctuate as I have measured it at 2 ohms.
      • There is no apparent water damage (or any other damage) on the board.
      • Removing PD0001 disconnects RTCVCC from VCC3SW and VCC3SW is back to 3.3V.
      • R1301 measures about 1M measured directly on board
      • C1608 and C1609 have been removed.
      • There is no CMOS battery connected.
      • C2001 is a no stuff.
      11-11-2022, 07:04 PM
    • DynaxSC
      Extreme High Current & Low Voltage Short Killer ??
      by DynaxSC
      Hi Folks
      I'm looking for a extreme high current short killer solution for a reasonable cost.
      I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
      After taking off the socket, the shorts dissappear again.
      The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
      10-15-2024, 10:13 AM
    • shlomim412
      Macbook Pro a2141 820-01700 - short on PPBUS
      by shlomim412
      Hello
      working on a dead a2141 logicboard - 820-01700
      no power, on usb c ampmeter it's on 5v drawing 0.01a
      visual inspection under the microscope - board look good, no liquid damage on any kind of damage.
      ppbus_g3h is 0.3v, and is shorted to ground showing around 50ohms (continuity beep) and climbing..
      i removed F7000 and F7001 and now getting 12v on PPBAT_G3H..
      also verified the short is on the system side (pin2 of F7000\1)..
      i tried to inject voltage, 1v to ppbus_g3h but it's only drawing...
      07-01-2023, 04:09 AM
    • Stephen
      MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
      by Stephen
      I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
      02-06-2025, 12:03 PM
    • Victor Moreira Silva
      Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
      by Victor Moreira Silva
      I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
      Well, my decice specs are the following:
      Model: Acer Nitro 5 AN517-54-55T5
      CPU: Intel Core i5-11400H
      GPU: NVIDIA GeForce GTX 1650
      Motherboard: GH51G LA-L181P Rev:1c
      The symptom:
      When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
      05-26-2025, 10:49 AM
