FIC VA-503+ best replacement for Vcore caps
  • Majestyk
    • Nov 2013
    • 96
    I still have some old Socket 7 systems running for fun.
    One of them has a FIC VA-503+ Rev. 1.2 Baby ATX board working, which was quite popular back in the days (ca. 1998).
    The Vcore section has 6 "Canicon" 1500uF 6.3V which I don´t trust at all.
    So I´m going to replace them soon.
    The diameter of the Canicons is 8mm and the height is 16mm. I could use 10mm diameter but the hight is strictly limited since the CPU heatsink covers that area.
    What I found so far:
    1. Nichicon LG polymer 1200uF 6.3V 8mm x 12mm (would fit perfectly but only 1200uF)
    2. Panasonic OS-CON polymer 1500uF 6.3V 10mm x 13mm (are slightly too fat, height is perfectly o.k.)
    3. Rubycon ZLH 1500uF 10V 10mm x 17mm (slightly too fat, height at the upper limit, but would probably fit)
    Which capacitor is the best choice? Can someone suggest a better alternative?
    And please don´t mock me for using such an old legacy shit - it´s pure nostalgia...
    • 31015
    Re: FIC VA-503+ best replacement for Vcore caps
    very good board - i still have one in a backup box.
    • Majestyk
      • Nov 2013
      • 96
      Sure is!
      The FIC VA-503+ and the EPOX MVP3G5 used to be my favourite boards back then since they were faster than the competitors´.
      And here´s a Picture of the CPU-area:
        • 31015
        damn i always wanted that cpu,
        i had to make do with a k6-2 500
        too bad the usb 1.0 was a broken standard
        it was the first board with usb, and got stung because of it.
        • Majestyk
          • Nov 2013
          • 96
          The Intel HX chipset also had USB at a very early stage, I think even before VIA MVP3 but only some manufacturers assembled the headers to connect USB devices due to serious problems.
          The AMD mobile CPUs (II+, III+) were available for a short time only and most distributors didn´t sell them. First everybody waited for these CPUs to be finally released and a couple of months later everybody was told they were no longer available.
          You can still use these systems today as Long as you stay away from browsing flash-crammed websites. I use them for Office Outlook etc.
          I even installed Windows 7 on one of These rigs last year. It was not fast but usable but Windows 2K and XP are best.
          • lti
            • May 2011
            • 2548
            There are lots of 8mm diameter 1500uF caps, but they are 20mm tall. I don't know where to find 16mm tall caps, but they were common in that time period. My old Compaq socket 7 motherboard also has 1500uF 6.3V caps in that size. It looks like your board was made for 10mm diameter caps in the three positions closest to the ISA slots.
            I was thinking of getting one of those mobile CPUs, but I didn't want to modify the BIOS on the weird Compaq motherboard. It only officially supports up to 400MHz K6-2s, but a 500MHz CPU will work. The Windows-based diagnostic tool fails the CPU test because of the higher clock speed.
            I also have a dead socket 7 motherboard with an Intel chipset and USB ports. It is an ATX board and only supports SDRAM.
            • Dan81
              SNES-powered
              • Oct 2013
              • 1865
              • Romania
              What motherboard does it use?If it's Soyo or Gigabyte then you can try using their BIOS instead of the Compaq BIOS.
              Main rig:
              Gigabyte B75M-D3H
              Core i5-3470 3.60GHz
              16GB DDR3-1600
              Samsung SH-224AB DVD-RW
              Delux MG760 case
              • lti
                • May 2011
                • 2548
                I don't know who made it. It is one of those boards that has all of its expansion slots on a separate riser card. It was only used by the Presario 2200 and 2400 series computers.
                • Majestyk
                  • Nov 2013
                  • 96
                  So, what I did is replace the 5 x 1000µ at the 5V rails with Rubycon ZLH 1000µ 16V, replace the two 1500µ 6.3V at the step-down converter for 3.3V (RAM / AGP) with Panasonic OS-CON Polymer caps and replace the Vcore caps (for stabilizing Vcore) with 1500uF OS-CON Polymer, where there is enough space (10mm) and 1200uF Nichicon LG Polymer whrere there´s only room for 8mm.
                  I think this is a workable compromise. It´s no use to force a 10mm in there when you cannot open the lever of the ZIF-Socket anymore...
                  Now there are about 20+ 10uF left that are spread over the board. I´m probably going to swap them as well.
                  • lti
                    • May 2011
                    • 2548
                    That might be the only socket 7 motherboard with polymer caps. It should work pretty well.
                    My Compaq uses the same CPU voltage regulator circuit, but it only has four 1500uF caps on the output and it might have a larger output voltage range (2.0V to 3.5V).
                      • 31015
                      damn, if i tried to do that it would cost more than the board!
                      where are you getting cheap poly's?
                      • Majestyk
                        • Nov 2013
                        • 96
                        Well I wouldn´t say cheap, but if you order a couple of hundreds as i do from time to time they are about 80 or 90 Eurocent each.
                        Here I "spoilt" 8 polymers, the rest is all ZLH Rubycons.
                        I also replaced the 20 10uF today so it´s "total recap" for this board...
                        Next week will show if it´s running stable.
                        • Majestyk
                          • Nov 2013
                          • 96
                          And here´s the finished FIC VA-503+
                          • c_hegge
                            • Sep 2009
                            • 5219
                            Nice. That board won't know itself.
                              • 31015
                              your still using the AT keyboard connector!
                              i desoldered mine and the mouse header.
                              there are holes in the board under them to fit standard PS2 sockets.
                              • Majestyk
                                • Nov 2013
                                • 96
                                Yep - still using it.
                                The old AT-cases in my inventory all have fixed cutouts for the DIN connector only. So I use a DIN-PS2 adaptor. Otherwise I would have to dremel the cases...
                                It´s a pain to find the right PS2 slot brackets for the mouseconnector sometimes since the pinouts on the mainboards are proprietary and vary between manufacturers.
                                  • 31015
                                  pci-usb2 card and usb mouse would be my option.
                                  • Majestyk
                                    • Nov 2013
                                    • 96
                                    This can be an option if the PCI-Card and the controller chip is supported by the BIOS. I made good experiences with VIA USB controllers and encountered severe problems with ALI.
                                    If you have to fiddle with the BIOS settings you´re back to PS2 since the USB keyboard isn´t ready before the OS has been loaded.
                                    Those old Socket 7 (and older) boards are true Divas...
                                    • lti
                                      • May 2011
                                      • 2548
                                      I tried putting a really cheap Rosewill USB 2.0 card with a VIA controller in the Compaq. The CPU usage wouldn't go below 20% with the card installed and was stuck at 100% while transferring files to a flash drive. The onboard USB ports (controlled by the SiS 5598 chipset) were faster.
                                        master hoarder
                                        • May 2008
                                        • 12170
                                        • Bulgaria
                                        Polymers on a Socket 7 board? -That is one epic recap job!
                                        If you need a keyboard with a DIN connector, let me know. Last time I checked, we had one in the "free" pile in one of our electronics classrooms at the university. I think it also had true mechanical keys with springs. Oh, and a flip-over type plastic dust cover, too .
                                        • jm942
                                          Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                                          by jm942
                                          My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                                          I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                                          I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                                          I did voltage injection on the cpu with 0.7V and i have a current...
                                          07-11-2024, 05:11 AM
                                        • barry101
                                          Apple 820-3662 VCore shorted to ground.
                                          by barry101
                                          Hi, Would appreciate some help.
                                          I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
                                          Get charger light but no fan spin or chime. No liquid damage.
                                          Found PPBUS and VCORE both shorted to ground. Other rails were ok.
                                          Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
                                          With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
                                          Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
                                          06-24-2025, 07:34 AM
                                        • ssl6
                                          MSI K7T266 Pro (Ver. 1.0)
                                          by ssl6
                                          Hey Everyone,
                                          Long time lurker, but I think this is my first time posting.
                                          Just looking for some assistance on identifying some suitable replacement capacitors for an MSI K7T266 Pro (Ver. 1.0). I just got my hands on two of them actually, both working but one has some visibly bulging capacitors and the other has a few that I can't tell for sure if they're bulging because it's faint at best if they are.
                                          I'll be honest I don't fully understand much on capacitor spec sheets beyond voltage and capacitance but I can solder like nobodies business so I've...
                                          11-09-2023, 01:00 PM
                                        • Francisco.s
                                          CPU vcore missing in HP workstation Z2 Mini 4G
                                          by Francisco.s
                                          Hi, have a HP workstation Z2 Mini 4G for repair with CPU vcore missing.
                                          The resistance at the output of CPU vcore coils, is less than one ohm so I think CPU could be damaged, but no mosfet are damaged.
                                          It mounts an i7 8th gen, and have only i5 7th gen for test, but I think it is not compatible.
                                          Without CPU in the socket there is no short, but there is no vcore voltag, and it emits a beep like no detecting ram.
                                          The controller chip for cpu vcore is a MP2949A, and has no enable voltage at pin 37.
                                          I wonder which circuit generates this enable...
                                          04-22-2024, 12:35 PM
                                        • the_rem
                                          Unknown transformer : how to find a good replacement part ?
                                          by the_rem
                                          Hello guys,
                                          I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                                          I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                                          04-23-2025, 01:48 AM
