CPU vcore missing in HP workstation Z2 Mini 4G
  • Francisco.s
    • 686
    • Spain
    Hi, have a HP workstation Z2 Mini 4G for repair with CPU vcore missing.
    The resistance at the output of CPU vcore coils, is less than one ohm so I think CPU could be damaged, but no mosfet are damaged.
    It mounts an i7 8th gen, and have only i5 7th gen for test, but I think it is not compatible.
    Without CPU in the socket there is no short, but there is no vcore voltag, and it emits a beep like no detecting ram.
    The controller chip for cpu vcore is a MP2949A, and has no enable voltage at pin 37.
    I wonder which circuit generates this enable voltage, but 1.2v for ddr4 is present.​
    Do you know if there is a schematic from other motherboard that can help to make a diagnosis for this board?
  • DynaxSC
    • Apr 2021
    • 476
    • Poland
    1. Check whether CPU VRM chip gets his power supply, VCC -> some serial usually 2.2 Ohms resistor may be burned.
    2. Check whether CPU VRM get his ENable signal.
    3. Does the board start w/o CPU at all?
    If not look for SIO pin with Socket Occupied (Socc_Occ or something similar) signal and short it to ground, cheating the board there is a CPU mounted. Then start the board and see if you get VCORE.
    4. Measure the PCH-CPU DMI bus in the CPU socket with diode setting on multimeter but reversed probes (plus probe to ground) - you should get on each pin some 0.2-0.3 V. If DMI bus is not OK, no VCORE will be established (Chipset negotiates with CPU and CPU VRM the power supply parameters by the Bios firmware).
      HP Z2 Mini G3 Workstation i7-7700 Specification for Upgrade or Repair
      This specification for the HP Z2 Mini G3 Workstation can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z2 Mini G3 Workstation boardview and Z2 Mini G3 Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
      09-12-2024, 02:15 PM
      HP Z2 Mini G3 Workstation E3-1225V5 Specification for Upgrade or Repair
      HP Z2 Mini G3 Workstation i7-6700 Specification for Upgrade or Repair
      09-12-2024, 02:00 PM
