Mac Pro 2013 a1481
  • avneeshshrotria
    • Oct 2019
    • 25
    • India
    Mac Pro 2013 a1481
    Hey wonderful that you got the system booted .
    I came across this thread in the hopes to find a schematic for the a1481 , I believe they don't exist . Please correct me if I'm wrong. Also if you'd post them i'd be greatful .
    i have a Mac Pro 2013 a1481 with led 2 , 3, 5 remaining on and then the system tries to boot to s0 , with led 6, led 7 ie s0 and s4 turning on simultaneously and Turing off .
    I don't have a doner board nor schematics … hence trying to figure out where to start to probe . I've checked all connectors and cables which a seated and working fine .
    Also I don't have the WiFi and fan cable plugged in since the cable is currently broken and no SSD installed .Will it have an effect for the system boot ???
    I have only one 4gb Ram stick 1866mhz installed in slot 1.
    I can share images or video of the system if you'd like .
    thanks
  • avneeshshrotria
    • Oct 2019
    • 25
    • India
    I just found this glass IC cracked/ broken on the IO BOARD .can't find any info about what IC it is.
    Also I've attached the images of the led 2,3,5 ON
    • Stephen
      Mac Pro Late 2013 A1481 ISSUE
      by Stephen
      So the computer works minus a flaw with the HDMI port. LCDs get detected but they won't display. I plug the LCDS into the Thunderbolt port no issue. HDMI port doesn't seem to display. So I plugged in multiple monitors and used the HDMI port and it detects the display but won't give an image. One time it gave a grainy colorful distorted image which makes me wonder if it's a bad HDMI port or Gpu Board? Anyone have any ideas? I am leaning towards a Bad hdmi, or bad D300 GPU or maybe the top logic board? I have never seen this issue before and would like to fix it. Any suggestions would help. I believe...
      12-16-2022, 07:55 PM
    • Stephen
      A1481 Late 2013 Mac Pro (Trash Can) Clean Bios needed
      by Stephen
      Can't seem to find it on here so sending a request. Did a search and nothing came up. We ordered 3 Bios chips for these Mac Pros (they have been installed with Monterey and we suspect it corrupted them firmware on the Machines) so we need to replace the bios with an older clean version to wipe it and update to Mojave.
      These are not EFI locked. I believe the firmware is corrupted and needs to be cleaned up.
      03-17-2022, 08:37 AM
    • djty
      MBP 2013 15" 820-3787 no keyboard, no touchpad
      by djty
      Device: Laptop
      Brand: Apple
      Model: MacBook Pro
      Board number: 820-3787-06
      Problem:
      • no keyboard, no trackpad
      • Fans Spinning fast
      Hello everyone. The MacBook pro late 2013 keyboard is not responses even when trackpad is disconnected.
      no reaction on KB, only power button andd ctrl alt shift, which are on keyboard connectore are separately on the KB pinout KB backlight is present the PP3V3_S4 and PP3V42_G3H one keyboard connector J4813 are present on keyboard
      external USB keyboard works Should touchpad be connected to motherboard for KB to be working?
      03-17-2025, 11:03 AM
    • Silent18
      razer blade 14 2013 rz09 0102x
      by Silent18
      Guys do you have razer blade 14 2013 rz09 0102x bios....
      thanks in advance!!!
      07-01-2024, 11:48 PM
    • bogosort
      A1398 15” 2013 short when screen plugged in
      by bogosort
      I have a MacBook Pro 15” A1398 2013 that has no backlight, but I see an image when putting light through the logo. I noticed that when the screen is plugged in, I get a 300 ohms short (see image).
      When unplugged, the short is gone.
      Any idea?
      02-04-2024, 01:06 PM
