Mac Pro Late 2013 A1481 ISSUE
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    So the computer works minus a flaw with the HDMI port. LCDs get detected but they won't display. I plug the LCDS into the Thunderbolt port no issue. HDMI port doesn't seem to display. So I plugged in multiple monitors and used the HDMI port and it detects the display but won't give an image. One time it gave a grainy colorful distorted image which makes me wonder if it's a bad HDMI port or Gpu Board? Anyone have any ideas? I am leaning towards a Bad hdmi, or bad D300 GPU or maybe the top logic board? I have never seen this issue before and would like to fix it. Any suggestions would help. I believe I have to replace the board that's faulty but would like to not waste time pin pointing the issue
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Re: Mac Pro Late 2013 A1481 ISSUE
    Let me rephrase this. Using multiple Thunderbolt ports all LCDS will display with multiple connected but when I try the HDMI it never works. It detects the display but won’t display an image. So I have two Thunderbolt to hdmi plugged in and fine. When I try the HDMI port nothing.
    sigpic
    • Stephen
      Meow Meow MEOW!
      • Apr 2020
      • 674
      Any idea?
      sigpic
        • 21616
        Originally posted by Stephen
        Any idea?
        have you checked all the hdmi pins aren`t broken or loose on the pcb. have you taken any resistance measurements
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 674
          Checked the pins and they are all in tact but I can take a look under the microscope. You don’t think it’s one of the GPUS? Because these are dual AMD D300 GPUs.
          sigpic
            • 21616
            Checked the pins and they are all in tact but I can take a look under the microscope. You don't think it's one of the GPUS? Because these are dual AMD D300 GPUs.
            No idea sorry.
            • Stephen
              Meow Meow MEOW!
              • Apr 2020
              • 674
              Ordered two boards I’ll let you know so we can update the forum with this issue if it arises again.
              sigpic
              • Stephen
                Meow Meow MEOW!
                • Apr 2020
                • 674
                Swapped out HDMI IO board solved the issue. I believed it was this but hoped it wasn’t but it was. It has no bent pins yet sadly wasn’t working. Thanks ����
                sigpic
                • Stephen
                  Mac Pro Late 2013 Issue
                  by Stephen
                  Have a Mac Pro that boots fine with an SSD if it has the OS on it. However when you wipe the OS and go back to reinstall (with external OS installer) it installs and formats fine, does the install process then after it almost finishes it goes to a blinking folder. So I tried internet recovery and guess what popped up? MONTEREY came up as the Internet recovery OS. So I went ahead and installed that, same issue again. It kept going back to recovery to install the OS when it almost completes. I know if I install it externally from another MacBook or Mac Mini on the SSD it will boot into the OS, but...
                  03-16-2022, 07:03 PM
                • avneeshshrotria
                  Mac Pro 2013 a1481
                  by avneeshshrotria
                  Hey wonderful that you got the system booted .
                  I came across this thread in the hopes to find a schematic for the a1481 , I believe they don't exist . Please correct me if I'm wrong. Also if you'd post them i'd be greatful .
                  i have a Mac Pro 2013 a1481 with led 2 , 3, 5 remaining on and then the system tries to boot to s0 , with led 6, led 7 ie s0 and s4 turning on simultaneously and Turing off .
                  I don't have a doner board nor schematics … hence trying to figure out where to start to probe . I've checked all connectors and cables which a seated and working fine...
                  04-05-2024, 06:48 PM
                • Stephen
                  A1481 Late 2013 Mac Pro (Trash Can) Clean Bios needed
                  by Stephen
                  Can't seem to find it on here so sending a request. Did a search and nothing came up. We ordered 3 Bios chips for these Mac Pros (they have been installed with Monterey and we suspect it corrupted them firmware on the Machines) so we need to replace the bios with an older clean version to wipe it and update to Mojave.
                  These are not EFI locked. I believe the firmware is corrupted and needs to be cleaned up.
                  03-17-2022, 08:37 AM
                • Sergio Kub
                  iMAc 27 inch late 2013 EMC 2639 no boot
                  by Sergio Kub
                  Hello, I have an iMAc 27 inch late 2013 EMC 2639 at work that doesn't start, it has a prohibited symbol and/or when I connect the system via USB it stops on the apple.
                  Is this feature locked in the bios?
                  Thanks in advance​
                  01-22-2024, 01:33 PM
                • dqtech
                  macbook pro late 2012 A1425 boot issue
                  by dqtech
                  this is my first time having this issue...everytime turn on will have this kind of word before apple logo appear....and sometimes just stuck here and have to force shutdown and turn on again....anyone have solution for this?...
                  12-22-2024, 01:54 AM
