razer blade 14 2013 rz09 0102x
  • Silent18
    • Aug 2020
    • Philippines
    Guys do you have razer blade 14 2013 rz09 0102x bios....
    thanks in advance!!!
  • peste
    • 13728
    • ROMANIA
    read the rules...
    post the original bios of the laptop even if it is corrupted, S/N, etc...
    • Silent18
      • Aug 2020
      • Philippines
      laptop S/N: BY1348102400095
      here's my original bios
        SMDFlea commented
        Editing a comment
        Read all of the rules,post files directly to your post,and do not start another thread with the same request !
    • 0xx
      2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
      by 0xx
      Hi folks,
      My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
      What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
      I assumed that Windows Update was interrupted due to closing...
      09-14-2025, 03:46 PM
    • vinaypundith
      Razer RZ09-01682 Blade Stealth 13 2016 BIOS dump needed
      by vinaypundith
      I have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
      So, I'm looking for a BIOS dump for this machine - a 16MB one....
      08-03-2024, 12:32 PM
    • Awdev
      Razer Blade 15 (2019) RZ09-03006E92 need BIOS Image
      by Awdev
      S/N is BY2011A72401766
      Full name: RZ09-03006E92-R3U1 Razer Blade 15” (2019) | RZ09-03006
      MB Model is: DA530-MB
      Dump is below, Laptop can do EC Reset but cannot boot. Suspect its BIOS or EC....
      10-18-2025, 02:13 AM
    • shellybelly
      Razer Blade 2016 6700k 1060 RZ09-01952 suspected backlight power rail issue.
      by shellybelly
      Back Story
      I just recently purchased a RZ09-01652 Razer Blade 14 Touch v4(2016) as a project. I suspect the original motherboard had overheated and caused board damage to the vrm's for the CPU and GPU as now that motherboard works however will lockup on you often due to hardware clock issues.
      So after some research and looking at options for replacement motherboards I got a replacement RZ09-01952 razer blade 14 motherboard which has the 1060 vs the 970m that was in my original motherboard. I have contacted the seller about the motherboard being bad however I doubt they will be...
      08-27-2023, 10:40 PM
    • beatngu
      Razer Blade 15” Base 2020 (RZ09-0328x) Bricked due to BIOS upgrade
      by beatngu
      Hello Guys,
      I have a Razer Blade 15” Base 2020 (RZ09-0328x) and performed a BIOS update last week (used the factory 1.06). During installation Windows 10 BSODd and my computer didn't start anymore. I could manage to manually flash the BIOS with a CH341A Programmer (only to version 1.03 as 1.06 is still killing my machine) but after that my touchpad is not working anymore. When I check BIOS I could see proper main version but for EC FW and MCU FW versions I see version 1.0.x. (which seems to be incorrect for me). I extracted the BIOS image from official updater (it contained 2...
      06-01-2021, 01:24 AM
