MBP 2013 15" 820-3787 no keyboard, no touchpad
  • djty
    • Apr 2021
    • Euro
    Device: Laptop
    Brand: Apple
    Model: MacBook Pro
    Board number: 820-3787-06
    Problem:
    • no keyboard, no trackpad
    • Fans Spinning fast
    Hello everyone. The MacBook pro late 2013 keyboard is not responses even when trackpad is disconnected.
    no reaction on KB, only power button andd ctrl alt shift, which are on keyboard connectore are separately on the KB pinout KB backlight is present the PP3V3_S4 and PP3V42_G3H one keyboard connector J4813 are present on keyboard
    external USB keyboard works Should touchpad be connected to motherboard for KB to be working?
    as 2EA side wide traces on the trackpad flex cable were broken which are restored, but anyways even connected or disconnected trackpad the KB is not working Could you please help me with the issue of no working TP and the keyboard?
    Thanks a lot!!​
  • reformatt
    • Feb 2020
    • 1476
    Keyboard does not work on these models without trackpad connected. There is a sensor on the trackpad, so CPU is throttled/fan speed max in it's abscence. Connect another trackpad and cable first to confirm, as from memory you need to remove the battery to gain access to it for replacement. No point doing that to find out it's not the trackpad after all.
    • djty
      • Apr 2021
      • Euro
      Thank you for your help!
      Basically the new trackpad flex cable is replaced and keyboard started to work, but trackpad is not. Ordered new trackpad and it did not worked, the old and new trackpads still dont works. So user said will use it with the external usb or wireless bouse, so laptop assembled back with new battery, and works well, no fans spinning fast. because I could not find schematics and boardview on 820-3787-06 but only 820-3787-A I could not be able to measure resistos on the way, but only voltages, which were present.
      • iMuhtaseb
        A2681 Keyboard, trackpad and sleep?!
        by iMuhtaseb
        Wow it's been a while since I posted!
        This is a weird case, it has a history of liquid spill a year ago but customer did not want to replace neither trackpad or keyboard.. fast forward for today:
        A2681 turns on but not trackpad or keyboard feedback (or external keyboard and mouse) and then after a minute or so the Mac sleeps..
        It's a NOT a sleep sensor or trackpad or keyboard or daughterboard or anything else (I replaced all those); it's the logic board..
        Tested another locked logic board on customer's top case and it posted with keyboard and...
        05-22-2025, 09:59 AM
      • guzq
        MBA13 M3 2024 A3113 EMC8611 820-03285 No Trackpad No Keyboard (water damaged)
        by guzq
        Hi Guys,
        This Mac come with dead issues (severe water damage), now it’s turning ON except Trackpad and Keyboard not working.
        Already check and write down DM for JT400 and JT201 don’t find any abnormal value (I don’t have unit for compare).
        Already try,
        • Replacing Trackpad Flex Cable
        • Replacing New Trackpad
        • Replacing Little Board (Daughter Board)
        • Try using New Keyboard
        Still no change at all, Trackpad and Keyboard not working.
        So I check “Power Load Switches” and this is all the numbers,
        UC830 > 1 = 3.297V ; 3 =1.757V ; 4 = 3.798V...
        07-08-2025, 05:19 AM
      • Vliegenier04
        Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
        by Vliegenier04
        Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
        I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
        Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
        06-16-2025, 12:03 PM
      • playit
        ps/2 port keyboard dead ? p5ql pro / ethernet cable light
        by playit
        my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
        my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
        few years back ps2 mouse stopped working, but ps2...
        12-23-2024, 06:05 AM
      • nicocorradini
        820-00426 (A1398 2015) no trackpad, no keyboard.
        by nicocorradini
        Hi! I have this 2015 A1398 with 820-00426 board that's driving me crazy. It originally came because of charging problems (MagSafe Board roasted, also MagSafe cable, etc. After disassembly, clean and assembly, my assistant (literally) broke FL803 and other componentes. Obviously, no screen or backlight. After replacing them, and also the LVDS connector, and LVDS flex on the screen, the board started fine, charges, chimes, shows Apple Logo, but surprise: no more trackpad or keyboard.
        Important notes:
        -Click works, so, trackpad is alive.
        -Already tried with another trackpad,...
        03-04-2025, 07:01 PM
