MSI Master2-FAR7 (MS9617) multiple problems
  • RJARRRPCGP
    • Jul 2004
    • 6301
    Re: MSI K8T Master2-FAR7 (MS9617) multiple problems
    Originally posted by Hadakajime
    It shows up as blank or as unrecognisable chars in the BIOS device list (possible BIOS bug?)
    Sounds like a bad ATA cable.
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
    • tmiha71
      • Apr 2010
      • 130
      Re: MSI Master2-FAR7 (MS9617) multiple problems
      Is this a single VRM for both CPU-s (all FPCAP in parallel) ?
      No anwswer ?
      • RJARRRPCGP
        • Jul 2004
        • 6301
        Your "hard crash" for board #2 sounds like a power cut, because of PSU going into protection mode or just a shitty PSU. Or a core overheat.
        Arc A770 16 GB
        • Hadakajime
          • Jul 2013
          • 13
          Originally posted by tmiha71
          No anwswer ?
          Sorry, i dont know how to test for this. I thought the photos may help.
          If it was just the psu going into protection mode then why would I have to clear the bios before it can turn on again. Power cycling did not help.
          Also i have replaced this board with a second hand AM3 board and will be selling my 940/AGP parts next month.
          Thanks for the help. Happy new year.
          • RJARRRPCGP
            • Jul 2004
            • 6301
            It sounds like multiple symptoms, where the CMOS is also corrupted.
            Arc A770 16 GB
            • tmiha71
              • Apr 2010
              • 130
              #26
              If you decide to experiment with board, one suggestion (what would I do if board is mine, and if I do not need money from sell)...
              I would choose to pull out 4 to 6 yellow caps (FPCAP) behind (closest, and in the middle of group) to inductors of CPU-vrm out, and put something like Nichicon L8 820uF in dimensions 8x8 mm... (Only if it's single CPU-vrm... all yellow caps in parallel = single CPU-vrm)...
              To do this successfully good soldering skill is needed, and if it does not work at first, would try again - pull (newly installed) caps out, and solder them again...
              If problems are still present (after three or more repeats), would go one (or two) size up with capacitance...
              Thanks for New Year, best wishes to You too...
              If you decide to go experimental way, search through forum, there's some nice posts how to solder...
              • cappernicus
                Satellite r945-p440 - Hard crash coming out of sleep
                by cappernicus
                Toshiba Satellite r945-p440
                Motherboard: FAM2SY2 A3256A
                I do not have a schematic or board file
                I usually let it go to sleep every time I use it because it is nearly always plugged in, with occasional shutdowns to reset things. Then it started to hard crash every time it tried to come out of sleep. The lights would come on for half a second but before anything shows on the screen they would all shut off and it would boot up as if I had shut it down completely (except that windows knows it didn't), and when it comes back on the fan ramps up to full and stays there perpetually...
                04-16-2025, 05:31 PM
              • federalhouse
                **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
                by federalhouse
                I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
                **Background:**
                I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
                **What I've Tried So Far:**
                1. I accessed
                08-01-2024, 07:03 PM
              • ash91
                Hp pavilion 15 not detect hard drive
                by ash91
                Hello gentelmen .... this is my first post and sorry for my bad english,
                so my proplem is my laptop keep losing hard drive even if i but the
                hard disk in the cady (the box that can replace the dvd rom with hard disk)
                when i turn the laptop on the massage that said no boot media found pop on
                the hard disk is fine and to be sure i try another hard
                i also update my bios to the last update
                the 5 volt is present on the hard connector on the motherboard
                the dvd rom work fine when i but a windows dvd in it
                also when i boot from flash...
                06-07-2023, 01:45 PM
              • madura2010
                DAY11AM6E0 hard disk drive and optical disk drive not detected
                by madura2010
                Today recieved hp model 17-f100nx laptop with no power.(motherboard=DAY11AMB6E0) after that repaired +1.05v section due to faulty buck converter.after that power issue fixed and laptop turns on.But "no bootable 3f0 error displayed".so then
                i checked the connectivity of ribbon=good communication with hard and motherboard
                changed hard disk and checked=3f0 error persist
                sata power=+5v available
                Then checked data capacitors=all good
                Then checked data lines path connectivity to pch=all good
                reflashed...
                03-12-2023, 09:09 AM
              • jean luc ferre
                laptop hp g72 b52sf screen problems
                by jean luc ferre
                on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                06-07-2025, 03:27 PM
