ECS and OST
  • SonicSteve
    • Oct 2005
    • 54
    ECS and OST
    Hi folks,
    I have a quick question. I have a few ECS boards some S462 and other 478. They used OST caps on them, pretty much exclusively.
    My question is this. On some boards they have popped, on others they haven't. ARE OST BOUND TO FAIL?
    Should I just replace them without question? Even if the board works well?
    If you have experience with this I would love to hear from you!
    Steve
  • Spacedye69
    • Nov 2005
    • 698
    • US
    Re: ECS and OST
    My ECS s478 has survived the couple of months I've been using it, and the small OST on my Asus mobo have not bulged yet. If you experience any problems, I would change them whether they are bulging or not, just to be safe.
    • Shroomie
      • Apr 2006
      • 356
      Re: ECS and OST
      I've had two ECS made boards, both s462, SiS 730s chipset: an ECS branded K7SEM v3, and a PCChips M810LR. Both of them use OST for VRM and G-Luxon on the lower half of the board, and caps didn't kill the former and haven't killed the latter.
      In addition, my Biostar M7VIG 400 also has mostly OST caps, and they're all fine so far. I used it for about 10 months, and installed it again about three weeks ago, and it's stable - in fact, I'm posting this on it.
      You know there's something wrong when you open up a PSU and are glad to find Teapos.
      Why I don't buy cheap cases!
      • SonicSteve
        • Oct 2005
        • 54
        Re: ECS and OST
        It is possible that OST has changed their stripes? I want to sell these boards in systems but I don't like selling junk. I want to confident that what I'm selling will at least come close to outliving it's usefullness and be reliable.
        Is it possible that I leave the OST alone or... just replace them out.
        • gonzo0815
          • Feb 2006
          • 1600
          Re: ECS and OST
          I have sold a system with K7s5a pro too in a office box with a 700mhz Duron. I have not replaced the ost caps, as they usually are not that bad, if at least the psu does not have mediocre caps. So i used a recaped (Rubycon caps) FSP psu and have not got i back since them. Ok, if i would have sold it with a 3200+ cpu, i woud not have been that confident in leaving them. Any way, if you have caps and can compensate the effort, replace them if not, it should last several years (but not necesarily 24/7).
          • chazzo
            CH341 programmer advice, including jumpers seemingly reversed
            by chazzo
            I’d appreciate some very basic advice on CH341x programmers. I know this topic comes up from time to time, but stuff changes, so I hope a refresh is in order. In particular, I see some unexpected things happening with jumper positions.
            [My plan is to learn to read and write 24CO2 EEPROMs via I2C. The first target is the one in my Uni-T clamp meter, but before tackling that I have some brand-new EEPROMs to practice on.]
            I have two basic Chinese programmers. One is the blue board with a CH341A and two rows of pin headers. To my untrained eye it looks like all the others....
            10-12-2025, 08:15 AM
          • Opunktvoll
            820-02020 a2338 - U0500 SEP EEPROM
            by Opunktvoll
            what´s the purpose of U0500 ROM located next to the M1 SOC? It seems to be somehow bound to the SN of the board. If I replace it with same IC from other a2338, it´s starting up in recovery mode and DFU fails (Error 9 most of the time, tried many times). If I put on the original U0500 I´m still in recovery, but can perform DFU and everything works fine again.
            Is there a way to replace this IC without having the original one available? Unfortunately I cannot find any information about this ROM and it´s function..
            08-19-2024, 09:45 AM
          • eccerr0r
            220VAC locales... ever used DC to feed switch mode power supples...and how many volts is generally okay?
            by eccerr0r
            For those in 220V locales, anyone power their SMPS with DC, and how high of a voltage is okay?
            What kind of PSU?
            I suspect that 240V * sqrt(2) = 340V DC is probably fine because that would be about how much the the primary rectifier ends up with peak voltage. Just wondering, other than input capacitor voltages, can one go up above this 340V without damage? Will that input capacitor be the upper bound?
            Wondering if exactly that, can I feed near 400VDC into bona fide specced at 220V SMPS without damage?
            Currently have a 120/220V switchable SMPS I want to see if I...
            04-22-2024, 08:03 PM
          • Zonk666
            Wht´s the general issue (laptop won´t boot after bios update) with HP BS Series, HP Probook, HP Elitebook ?
            by Zonk666
            Hello everyone.
            In the last 8 months I have manually flashed about 150 HP laptops (BS series, Probook, Elitebook and Zbook). There are about 50 HP laptops, as I have already written before, they have been automatically flashed through windows updates.
            Approximately 15% did not start after flashing.
            I got the HP Pro, Elite and Zbook to work again with the exception of one using the familiar key combinations or the well known bios flash stick methode.
            An Elitebook 840 G6, like many HP notebooks from the BS series (exclusively those with dedicated graphics c...
            03-08-2024, 10:49 AM
          • Fenzon
            Samsung UE43NU7122 has Picture, but no Backlight
            by Fenzon
            Greetings fellow DYIers, the moment I discovered this community forum, nostalgia has hit me pretty hard, this early web 2.0 look and feel is close to home. I can't describe my happiness seeing active forums that survived today, and its not just yet another centralized propriety subreddit.
            Before I describe my issue with this particular TV, I would like to let you know that I do have basic electronic competence, and some electronic component knowledge. I also am an electrical installation technician student, although we exclusively study alternating currents and our primary...
            09-26-2023, 03:17 AM
