820-02020 a2338 - U0500 SEP EEPROM
  • Opunktvoll
    • Sep 2022
    • 22
    • Deutschland
    what´s the purpose of U0500 ROM located next to the M1 SOC? It seems to be somehow bound to the SN of the board. If I replace it with same IC from other a2338, it´s starting up in recovery mode and DFU fails (Error 9 most of the time, tried many times). If I put on the original U0500 I´m still in recovery, but can perform DFU and everything works fine again.
    Is there a way to replace this IC without having the original one available? Unfortunately I cannot find any information about this ROM and it´s function..
  • Testiez
    • Jul 2024
    • 3
    Mine looks like its shorting out. I'm glad I haven't replaced it yet. thanks for the heads up.
    • SidneyCanadas
      93C46 and 93C56 EEPROM
      by SidneyCanadas
      I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
      https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
      Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
      06-14-2023, 01:16 PM
    • volinakis
      Chromebook recovery failed - how to fix it
      by volinakis
      So I had a Asus C433T Chromebook enrolled and after I modified bios I had to reinstall Chromium. I made a USB recovery stick with Chromebook Recovery Utility but I got "an unexpected error has occurred ..." message. I did try with another USB stick, etc. etc. -all steps found on internet about this issue and nothing worked.
      Finally I found a site where they suggested to try with an older image and ... it worked!
      What I did:
      - when “Chrome OS is missing or damaged” message appeared I pressed Tab key and found: read only firmware id: Google_Rammus. xxxxx.xxx.x....
      09-18-2023, 03:26 PM
    • dmccul2698
      Pioneer DEX-P99rs "No EEProm " diagnostic code.
      by dmccul2698
      Hello, My head unit developed strange behaviors so I ran the built-in diagnostic package which returned "No EEProm". The service manual says there is no EEProm connected. I approached Pioneer and they said to swap out the DSP board. All said and good but the DSP board is $860 USD. I am hoping someone can help me
      1). Understand the schematic and check the connections between the EEProm and DSP
      2). Check the functionality of the EEProm
      I don't know if this is the unit's problem but it's a place to start.
      I have little to no electronic experience...
      04-08-2024, 05:32 PM
    • myth77
      macbook pro a2141 can not make recovery
      by myth77
      So, i dont know almost anything on macs..but this is my nephews so i had to try. Its 16 inch macbook pro from 2019...It all started when he left something on the keyboard when closing the mac and there it was the crack on screen. At first it was like working but later no. After that he told me that it wouldnt power on?...hear fans but nothing..tried like 100 of stuffs but nothing helped.
      So, he bring it to me...first i open it and figured he did also. there was lots of dust i cleaned everything...and started it...the broken screen showed only backlight but nothing on the screen. I...
      06-19-2022, 11:21 AM
    • ugamazing
      820-00850 & 820-01949, No WiFi *In Recovery*
      by ugamazing
      I've got two boards with the exact same issue, and it's confusing the hell out of me. In short:
      1. Both boards behave *exactly* the same; they will show WiFi networks to connect to, and will boot fully to Internet Recovery, but they each show zero available WiFi networks once booted to Internet Recovery. I also cannot switch WiFi "off", as in, the toggle will not move.
      2. Both boards will erase perfectly fine using the "erase mac" function; I can wipe them with disk utility, but if I try to install MacOS from Internet Recovery, it says to connect...
      01-25-2023, 05:39 PM
