102m ceramic cap
  • bilbofx
    • Mar 2013
    • 5
    • 81313471377
    102m ceramic cap
    Hi, I am new to this forum; so if i have posted in the wrong place i am sorry. Basically i have and lcd psu with this bad capacitor. I'm pretty sure its 1000pf +/- 20 . However i am only guessing its 1kv. Any help in identifying the right values for this would be much appreciated, or pointing me in the right direction for a replacement.
    go url
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: 102m ceramic cap
    1000 pF 20 % tolerance is correct. Looks like a Y-safety rated cap. Is this located by the mains plug or in that general area?
    What makes you think it's bad? The stuff below it is more than likely just glue used to hold the cap down while the PSU was assembled in the factory.
    • klkmalik
      seeking Tips
      • Nov 2011
      • 68
      • UAE
      I think this cap is good , Try resolder cap leg. or if u doubt you can measure by cap meter.
      • Hemingray
        KABOOM!
        • Jul 2010
        • 143
        That looks like an X/Y cap.
        • bilbofx
          • Mar 2013
          • 5
          • 81313471377
          Hi momaka, Actually i have posted the wrong cap, although very similar. This is the one i meant to post. There are 2 of these in paralell right next to the main 5amp fuse, are these just to smooth out the current. I think this is a 470pf again, not sure if i can replace with 250v,400v or 1kv or does this not matter as the ac voltage is 240v and these are rated higher and the proof voltage is way higher. Hope that makes some sort of sense. Thanks for all your suggestions. By the way the fuse popped and blew the legs off. Opps!!
          go url
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            Technically any of those will work but that's not all there is to this. These have to be X/Y safety rated, too. The difference is that X/Y safety caps fail open-circuit rather than short-circuit if something was to go wrong with them (say, from a lightning surge, for example). Regular ceramic caps on the other hand may become short-circuited in such a situation and this can be a fire hazard.
            Most standard X/Y class caps come with 250V rating.
            If the fuse has popped, the problem is very likely somewhere else. Prime suspects are the switching transistor on the primary side and the bridge rectifier so you should start by checking those.
            • chth96
              Is it possible to test small ceramic disc capacitor with analogue meter?
              by chth96
              I read EBOOK of Testing Electronic Component and found that
              "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
              Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
              It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
              Is it really possible to test small ceramic disc capacitor with analogue...
              03-09-2024, 10:03 PM
            • paceuser
              Need help identifying Ceramic Capacitor
              by paceuser
              I have the following ceramic capacitor that I would like to identify. I need to purchase another one like it or an equivalent. Here is the text on the capacitor:
              Capacitor is Yellow in color. It has three lines of writing:
              VF05
              0221
              TK RU (RU = Underwriter's Laboratories Logo)
              If anyone knows an equivalent on fleabay please let me know. Thank you I appreciate your help.
              05-14-2020, 07:04 AM
            • RetroComputingGrotto
              Need Help Identifying A Diode
              by RetroComputingGrotto
              I have an MSI 3PA1 monitor on my bench that wont power on. I have tested the 2 (what I believe to be Schottky Diodes) and both are shorted in both directions (a common faulty from what I can see on Google) but I'm not certain what the markings on the Diodes mean so I need some help in identifying which ones to order from Mouser please?
              I've done a search for 101C 5100C and all I can find are datasheets for 5100C which say they are 20-100V 5A Schottky Diodes but I'm not 100% sure if this is correct or not and what significance the 101C is.
              We...
              09-22-2025, 06:47 AM
            • Khoja
              Lenovo Ideapad Flex 5 14IAU7 (LC57-IAU MB 213062-1M) identifying elements
              by Khoja
              Hello friends, I have a Lenovo Ideapad Flex 5 14IAU7 laptop that doesn’t turn on. When I opened it, I found a burnt resistor on the motherboard. Since I couldn’t find a schematic for this model, I need help identifying the parameters of this resistor.
              • Model: Lenovo Ideapad Flex 5 14IAU7
              • SN: PW0AZK3W
              • Motherboard: LC57-IAU MB 213062-1M 448.0RH09.001M
              Any assistance would be greatly appreciated!...
              09-19-2025, 09:56 AM
            • SendyCatKiller
              KOORUI 24E4 monitor with HKC HKM238Fj01 panel I need help with identifying TCON ic.
              by SendyCatKiller
              Hello! I am looking for help with identifying this tcon chip on KOORUI 24E4 monitor.
              Driver board number: pn238ct01-3-xc-2
              Other IC on the driver board: NT71265MFG-001
              08-22-2025, 01:01 PM
