Bad Caps on an Abit KG7 Mobo
  • dilwig79
    • Oct 2006
    I have recently run accross a problem with a KG7 board. The computer crashed and upon further investigation I notice the bursting caps. Has anyone else run accross a problem with this board. It has caps made by Nichicon. All of the caps around the processor have burst or are bulging. After seeing this I checked another computer I have that is running a KT7A board. It has the same problem. I called Abit about it and they said they would fix the KT7A board but not the KG7 board. What is amazing is the KG7 board is worse than the KT7A board. Anyone have any suggestions on the approach I should take with Abit if any? Thanks for any advice in advance.
  • krazykev64
    • Feb 2009
    • 49
    Re: Bad Caps on an Abit KG7 Mobo
    the kg7r is around 5 years old when you made this post so it would of been past its 1yr warranty. my kg7r is 8yr old but the caps are great. its one of those things
    • Player2
      • Aug 2009
      • 98
      Somehow I think the OP has probably moved on by now...
      • bgavin
        • Jan 2007
        • 1355
        I recapped about a dozen of these boards. All are still in service except one.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Nichicon HM and HN Series caps made from 2001 thru 2004 were defective.
          DAMN! - This is old thread!
          Mann-Made Global Warming.
          - Dr Seuss
          • bgavin
            • Jan 2007
            • 1355
            It may be an old thread, but those HM are the gift that keeps on giving.
            As I write this, I have yet another KG7 on the bench. Just finished recapping... yep... all the HM popped.
            This board is one of my many KG7 installations from the early 00's.
            The client is fine with the performance, but it was time to rotate out both drives. I found the popped caps during the disk rotation.
            The PSU was replaced 12/2008, so the caps popped sometime in the last year.
            Unfortunately, the KG7 board always fails Memtest86+ testing, so I never know if the RAM is good, or actually failing. I use PRIME95 to wring it out, as this will stumble over intermittent RAM errors.
            • krazykev64
              • Feb 2009
              • 49
              my KG7R mobo is knocking on for around 9 years old and is still on its original caps from when i brought it in 2001. it passes all tests with flying colours
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • Dani_2024
                by Dani_2024
                10-28-2024, 05:06 PM
              • black6host
                Replacement caps for Samson Resolv studio monitor 65A Amp board.
                by black6host
                Good day!
                I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                I'm going to replace the caps and I'll be the first...
                02-06-2024, 08:22 PM
              • Noodneek
                Replacing all the caps on the BenQ SW2700pt's power board didn't help...
                by Noodneek
                My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
                I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
                08-30-2024, 12:52 PM
