I have recently run accross a problem with a KG7 board. The computer crashed and upon further investigation I notice the bursting caps. Has anyone else run accross a problem with this board. It has caps made by Nichicon. All of the caps around the processor have burst or are bulging. After seeing this I checked another computer I have that is running a KT7A board. It has the same problem. I called Abit about it and they said they would fix the KT7A board but not the KG7 board. What is amazing is the KG7 board is worse than the KT7A board. Anyone have any suggestions on the approach I should take with Abit if any? Thanks for any advice in advance.
Bad Caps on an Abit KG7 Mobo
Re: Bad Caps on an Abit KG7 Mobo
the kg7r is around 5 years old when you made this post so it would of been past its 1yr warranty. my kg7r is 8yr old but the caps are great. its one of those things -
Somehow I think the OP has probably moved on by now...Originally posted by krazykev64the kg7r is around 5 years old when you made this post so it would of been past its 1yr warranty. my kg7r is 8yr old but the caps are great. its one of those things
Nichicon HM and HN Series caps made from 2001 thru 2004 were defective.
DAMN! - This is old thread!Mann-Made Global Warming.
- Dr Seuss
It may be an old thread, but those HM are the gift that keeps on giving.
As I write this, I have yet another KG7 on the bench. Just finished recapping... yep... all the HM popped.
This board is one of my many KG7 installations from the early 00's.
The client is fine with the performance, but it was time to rotate out both drives. I found the popped caps during the disk rotation.
The PSU was replaced 12/2008, so the caps popped sometime in the last year.
Unfortunately, the KG7 board always fails Memtest86+ testing, so I never know if the RAM is good, or actually failing. I use PRIME95 to wring it out, as this will stumble over intermittent RAM errors.Comment
my KG7R mobo is knocking on for around 9 years old and is still on its original caps from when i brought it in 2001. it passes all tests with flying coloursOriginally posted by bgavinIt may be an old thread, but those HM are the gift that keeps on giving.
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by black6hostGood day!
I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
I'm going to replace the caps and I'll be the first...-
by NoodneekMy 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...-
- Loading...
