Identify component
  • Denise
    • May 2012
    • 7
    • Ireland
    Identify component
    I Have a ITOX g4v620-b motherboard that got damaged in the post. I seem to be missing the below component from my board but I cant identify it. Would anybody know. Sorry for poor picture it was all I could find on the net.
  • selldoor
    Slow Learner
    • Dec 2010
    • 7870
    Re: Identify component
    If it was damaged in the post would the component not be inside the packaging? - Can you claim off anyone for the damage?
    Do you know the board description for the part
    Can you post a very clear close up of that section of your board.
    • Denise
      • May 2012
      • 7
      • Ireland
      It was done on purpose, someone got a screw driver to it. Its a long story because it was signed for they wont take responsibility for it. I have already replaced all caps on the board and a diode that was damaged. Here is a picture of the whole board I found on the net. I will post a picture of my board in a few minutes. The application that is running on this is an old Dos app for a bowling alley. I tried booting the hard drive from another old pc I had but it wont work. this board has the old Eisa slot that a special card for controling the lanes connects to.
      • Denise
        • May 2012
        • 7
        • Ireland
        This is my board with componenet gone.
        • selldoor
          Slow Learner
          • Dec 2010
          • 7870
          Ok - for future ( and if you can change now it is better if you post pics using manage attachments which is found by clicking Go Advanced. In line pic put some members off.
          at least these are not too big.
          According to the board it is a voltage regulator that might be missing- what about the two resistors below it? Are you sure they need to be there? do the pads look to have had components soldered to them.
          EDIT - looking at the first picture it doesnt look like anything I recognise as a VR - I suspect if one was there it would have a
          metal backplate that would go on the Big pad and two legs that would go on the two small pads at each side. possibly with a stub between them.
          EDIT2 can you find VR1 or VR3 and see what they look like.
          • Denise
            • May 2012
            • 7
            • Ireland
            I cant find VR1 or VR3. I found VR4 and VR5 over beside the ram but looks nothing like what I am missing. It just looks like a normal Voltage Regulator. The component I am missing does not have solder points on the opposite side of board. Its like a diode soldered straight to the board.
            • mariushm
              • May 2011
              • 3799
              are you sure there's something missing there?
              I found a large picture on Google which shows just some solder remains there.
              http://savedonthe.net/image/1708/mb.jpg
              • selldoor
                Slow Learner
                • Dec 2010
                • 7870
                Yes Mariushm Thats the one I saw also
                Denise this is what I meant
                http://i00.i.aliimg.com/photo/v0/551...pg_140x140.jpg
                But suspect it never had one in that position - they are difficult to remove with a soldering iron
                never mind a screwdriver
                • Denise
                  • May 2012
                  • 7
                  • Ireland
                  That pictures looks like there is nothing there all right. Only difference is that is the REV B1 of the board. This Board is REV A1 and it does look like there is something there. I have power and no display. Replaced CPU, Ram, Caps that were swollen, power supply all the usual. There was a sk12 diode broke off too and with this gone the pc would auto turn on as soon as power plug was put in. I replaced this and now I have to press the power button like it always did but still no display. I am only guessing that it was SK12 as that is what the other diodes are. It was D31 right over beside the IDE slots next to the green 1000uf cap.
                  • Denise
                    • May 2012
                    • 7
                    • Ireland
                    Just got a good picture of Rev A1 board and there is nothing there. It was worth a shot. Thanks for the help.
                    • selldoor
                      Slow Learner
                      • Dec 2010
                      • 7870
                      OK if you need more help with this I suggest you start a new thread with the heading to include the full name of the motherboard and very brief detail of problem.
                      If it is a selfbuild detail the other components ram/OS/PSU etc
                      Detail the work you have done on it already and include pictures posted
                      using manage attachments.
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
                      • m1ch43lzm
                        by m1ch43lzm
                        05-12-2025, 08:37 PM
                      • thesame
                        DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                        by thesame
                        Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                        The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                        02-27-2024, 04:31 AM
                      • k-krzych
                        Identify board to board connector
                        by k-krzych
                        Hello, can you help me with an id of this board to board connector, or the the tiny silicon flat wires for replacement? It is found on GPS unit and connects main board with pushbotton small board....
                        07-08-2025, 12:32 PM
                      • karto95
                        Repairing a Seagate hard drive with damaged logic board
                        by karto95
                        I'm currently facing an issue with my Seagate hard drive that has a damaged logic board. I've obtained a replacement logic board from a donor hard drive, but unfortunately, I'm unable to recover the BIOS of the original board due to damaged firmware. I'm wondering if it's possible to make the hard drive work with this donor logic board.
                        I have a CH341A programmer, so I'm hoping that it can be useful in this situation. I've attached the BIOS file .bin of the donor board for reference.
                        If anyone has any suggestions or experience with this...
                        03-21-2023, 04:05 AM
