intel d845gebv2/d845pesv motherboard regulator help indentify
  • heavymachines
    • Mar 2011
    • 1028
    hi all i am trying to find info on this fet er regulator its made by "on semiconductor" only markings it got is
    252
    80
    nd2
    cannot find a thing about it kinda need to know today so i can find replacement
  • selldoor
    Slow Learner
    • 7870
    Re: intel d845gebv2/d845pesv motherboard regulator help indentify
    Hi - a picture might help if possible one with the part number readable.
    Not that I dont trust you but we have spent cumulative hours on here looking for parts with 5 instead of S O instead of 0 8 instead of B Z instead of 2 and so on.,
    • heavymachines
      • Mar 2011
      • 1028
      don't have a camera atm but that's all the numbers on it and i wrote it out as it is on the regulator er fet however, i do know for sure it was made by "on semiconductor" again it read out exactly as shown
      252 "on" logo by it
      80
      n02
      and that's it very poor part number if you ask me can't find squat
      • heavymachines
        • Mar 2011
        • 1028
        i double checked the nd2 is actually a n02
        • selldoor
          Slow Learner
          • 7870
          Anything like this
          http://html.alldatasheet.net/html-pd...80N02-001.html
          • heavymachines
            • Mar 2011
            • 1028
            looks good same packaging anyhow only thing is i cannot see where the 252 comes into play and 24 volts seems awful high being a cpu voltage regulator not that its getting 24 volts to it there is a 12 volt rail and 5 volt rail in cpu regulator area
            • heavymachines
              • Mar 2011
              • 1028
              i found close replacements should work if you will confirm for me its on an xbox mobo anyhow here the part number
              on semiconductor
              540 "on" logo next to it
              85
              n02g
              https://cdn.badcaps-static.com/pdfs/...01d2894978.pdf
              • selldoor
                Slow Learner
                • 7870
                I dont know about the voltage but the 252 is shown on the marking diagram
                it relates to when it was made YWW so 52 week of 2002? or second year of production - can only guess.
                • heavymachines
                  • Mar 2011
                  • 1028
                  yeah very possible thanks alot dude i owe ya one
                  • glovecaps
                    Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                    by glovecaps
                    I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                    My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                    The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                    11-25-2024, 04:23 PM
                  • Docus
                    Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                    by Docus
                    Hi everyone 😀,
                    I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                    To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                    Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                    1. I already own the exact same model, but its plastic chassis is badly damaged.
                    06-10-2025, 04:24 PM
                  • Archimedes
                    HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
                    by Archimedes
                    Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
                    Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
                    Fans are spinning. Blindly could install windows11 and got the device manager...
                    07-30-2024, 05:14 PM
                  • dragon3x
                    After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                    by dragon3x
                    Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                    power on.
                    Here are some examples :
                    (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                    switching supply area).
                    (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                    than 6.3 V.)
                    1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                    I replaced capacitors with aluminum-polymer.
                    3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                    03-21-2025, 02:46 PM
                    ASUS P5GC-MX motherboard recap
                    by momaka
                    Here’s another motherboard that needed a full recap: an ASUS P5GC-MX.
                    This one was gifted to me some years ago by user Pentium 4, along with a few other goodies. It actually came in working order with no bulging or leaking caps. However, I noted there were United Chemicon KZG caps everywhere on the motherboard. The CPU VRM output (CPU V_core) was the only exception: it had only 2x KZG. The rest was 6x UCC TMV 4V 680 uF caps… which aren’t any good news either.
                    So here is what the motherboard looked like with its original caps:
                    CPU VRM area up close…...
                    01-27-2021, 11:59 PM
