This videocard uses these fake polymers. The vent is a "K" suggesting Rubycon, but I doubt it. These are SMT but there are two holes on the back of the card for through-hole mounting as well. How do you get them off without tearing the foil traces? What is an appropriate replacement? Thanks for this.
Please identify these caps
Re: Please identify these caps
Happy Christmas
That is a poor picture - cant really see a card manufacturer using fake caps
anyway a decent close up of one or two of the caps will enable better identification.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740 -
I would say 1000uf 16v, better larger,sharper pic would be better.This videocard uses these fake polymers. The vent is a "K" suggesting Rubycon, but I doubt it. These are SMT but there are two holes on the back of the card for through-hole mounting as well. How do you get them off without tearing the foil traces? What is an appropriate replacement? Thanks for this.Comment
As far as removing them, just heat one side with a soldering iron, tilt the cap up a bit, then do the same on the other -- don't over do it, you may have to go back and forth a couple of times; then remove the excess solder carefully off the pads with flux and wick.
Retake the pic at an angle next time so the glare doesn't obscure the lettering.Comment
Those aren't fakes, those capacitors are made by Tecate Group. They're actually polymers, and although I can't tell you which series exactly, here are their polymer datasheets.Comment
Voltages are OK on the 3-pin regulators?Never stop learning
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by briztechHi can anyone identify missing caps/values on Matebook D15 DAH98NMB8C0 REV C HF - Thanks
1 Photo -
by eryjusHello,
Channel: General Capacitor Questions & Issues
by GalraediaI decided to take one of the Rubycon capacitors out of a phat Xbox 360 with a Zephyr motherboard and noticed that all the Rubycon capacitors near the CPU were fake. The capacitors in question are Rubycon MFZ 680uf 6.3V and they all have a bullseye bottom, something not found in genuine Rubycon capacitors. None of them were leaking, they all have the K top, and the system has never been opened before. It appears Microsoft was using fake capacitors in the Xbox 360, or the Chinese facility where the console was manufactured in was using them and passing them off a genuine. Just thought I'd share...
by captain150I'm trying to repair two old VCRs, they both have bad caps. One has leaky ones, the other would barely run until I subbed in some caps from another power supply I had laying around (though they are the wrong values). This vcr works for an hour or two, but then the power supply starts whining and the picture gets lines in it. I didn't replace all the secondary caps, so another voltage might still be problematic, or the values I used are too far off.
I've been on mouser and digikey but the options are a bit overwhelming. I just need some new ones that will work. They don't need to be top quality,...-
- Loading...
