Why have almost all my failed motherboards been ECS brand?
  • lti
    • May 2011
    • 2547
    Re: Why have almost all my failed motherboards been ECS brand?
    A lot of cheap computers still used the defective 6100 chipset with AM3 and AM3+ CPUs. That chipset might still be used today unless the old stock finally ran out.
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      #42
      imagine my surprise when i get a ecs board for recap last week and think to myself that the build quality is too good for an ecs.even with leaking samxon gd on it.
      then i notice the fcc id is to nvidia!
      its a real nvidia board with an ecs sticker on it.
      btw this had not died yet and was in for a preemptive recap.belongs to a friend who does not wait for the failure when he knows it is coming.
      the samxons looked fine till i desoldered them.then they stunk and sizzled.
      • Home_Command_Center
        • Dec 2012
        • 46
        Originally posted by c_hegge
        They are fine. nVidia did fix the problem by then. Nowadays, though, no one really uses nVidia chipsets now that AMD make their own.
        yeah, since I always use AMD CPU's the next mobo will definitely be an ATI based gigabyte mobo.
        this AMD/nVidia frankenstein will keep the low end nvidia 3d ready GPU, creative sound card, and POS ram, but get re-cased with a cheapo 600w PSU I have laying around and a mid tower case I have in storage after a repaint, then it's becoming nothing more than a windows XP based HTPC for the living room to replace the roku thats out there now.
        my current case and fatal1ty 750 psu will get a full atx ATI mobo from gigabyte and a higher frequency dual core AMD cpu, as well as a mid range triple display 3d ready ATI GPU, 8gigs of ddr3 from g.skill, and a higher end, perhaps m-audio, PCIe audio card.
        then I just have to redistribute all these hard drives I have in a sensible fashion. these days I think it makes more sense to store your media on a few 1t WD my-passports than to fool with having massive drives in the machine itself. my 320 sata will probably become my OS drive for the new rig, and the 80g sata I have for my OS now will move with the old stuff into the HTPC only set up... from there I just have to pull a bunch of cat-5 and get them all talking to one another efficiently for media sharing.
        while everything is apart, I will go ahead and recap the 6100 mobo for good measure...
        where do you guys buy your through hole parts? I've been using Mouser, but I wasn't aware there was such a big difference in cap quality by brand. I mostly just repair car stereo amplifiers though...
        • Blargh523
          • Dec 2012
          • 46
          Originally posted by Kiriakos GR
          Next time get ASUS, it is simple as move and you get at the safe side.
          I have lost faith to all the others, few months back, an very expensive Gigabyte stopped booting with out reason.
          No more experiments, medium or high priced ASUS boards is all that I am touching those days.
          AS-Rock (which I think was a subdivision of Asus, but split off) seem to be okay. I'm not happy with Gigabyte, myself -- my current motherboard needed a *lot* of bios muckery to run 4G of ram, and 8G seems to be right out unless I want random blue-screens. Board itself is awesome, but the bios leaves a bit to be desired.
          ECS is on my list of ZOMGNO, along with First International, Jaton and a couple others. Re-capping won't fix poorly-soldered BGA's or under-spec'd on-board cache.
          Well, it might have been an nVidia design/board, but built by ECS. The off-brand companies buy outdated designs and surplus motherboards and use those to base their builds on.
            • Dec 2012
            • 46
            which is what I'm dealing with right now...
            I'm now glad most of the HTCP's I've set up for people are based around ready built deskbooks...
            [edit] BTW, ASUS GPU's are built by galaxy... just google image search ASUS nVidia GPU's and compare the PCB's to the same model Galaxy GPU's. the only difference is the heatsink, fans, and stickers...
            • tmiha71
              • Apr 2010
              • 130
              #46
              Was/am satisfied with ECS hardware, could always squeeze few more percentage of performance out of it. Still using (not regulary) K7S5A at 166 MHz, with ULTRA CPU settings (only CAPS modded, official BIOS - switching done in Windows)...
              • larrymoencurly
                • Oct 2004
                • 960
                ECS uses the bare minimum of components required,
                Here are 4 brands of nearly identical motherbaords based on the Intel G41 chipset. 3 of them have a heatsink over the NH82801GB chip, but the ECS one does not:
                • c_hegge
                  • Sep 2009
                  • 5219
                  Typical ECS junk
                  • Stanley1843
                    BEST 505 Vs Mechanic Brand Reballing Balls with Lead
                    by Stanley1843
                    has anyone use these Brands of solder balls? The brand BEST writes on the label of the jar the specs of the solder balls instead of the Mechanic brand. I beleive that BEST brand must be more professional (in labeling at least) but I have never try one of them so I would like your opinion. By the way I hardly can I find the Mechanic brand in aliexpress (the only where I found was lead free solder balls) and on ebay these that I found are approximately15USD per jar. If you know any other trusted brand of solder balls please tell me.
                    06-22-2024, 11:06 AM
                    HP Pavilion 15-cx0198tx Notebook 15 Specification for Upgrade or Repair
                    This specification for the HP Pavilion 15-cx0198tx Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15-cx0198tx boardview and 15-cx0198tx schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                    09-06-2024, 09:17 AM
                    HP Spectre x360 13-ae511tu Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                    This specification for the HP Spectre x360 13-ae511tu Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13-ae511tu boardview and 13-ae511tu schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-06-2024, 06:27 AM
                    HP Spectre x360 13-ae510tu Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                    This specification for the HP Spectre x360 13-ae510tu Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13-ae510tu boardview and 13-ae510tu schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                    09-06-2024, 06:17 AM
                    HP Spectre x360 13-aw0124tu Hybrid (2-in-1) 13 Specification for Upgrade or Repair
                    This specification for the HP Spectre x360 13-aw0124tu Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 13-aw0124tu boardview and 13-aw0124tu schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                    09-06-2024, 12:25 PM
