Foxconn M7PMX-S LGA775
  • Peanuckle
    Tinkerer
    • Nov 2012
    • 6
    3/5 of these NCC 680uf 4v TMV caps are bulging (circled in gold). The system is overclocked and has been running 24/7 for 3 years. No obvious issues but I'd like to replace them anyways.
    Is this the VRM and if yes would the OSCON 560uF 4v 8mm Polymer Capacitors from the badcaps shop be a good replacement?
    Taking any recommendations for replacements. Thank you for your time!
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: Foxconn M7PMX-S LGA775
    I can't find specs for the NCC TMV series, but in general mainboards do work better with polymer caps in the VRM, which you have correctly identified in your photo.
      master hoarder
      • May 2008
      • 12170
      • Bulgaria
      Looks like there's 3 more TMVs above the CPU socket. I would suggest to replace all of the TMV. IIRC, that's one of their problematic brands, along with KZG and KZJ.
      OSCON 560uF 4v 8mm Polymer will probably work fine. I would suggest to go with the 2.5V 820uF Fujitsu polys, though (also 8mm diameter). Don't worry about the lower voltage rating of the Fujitsus - they will all be on VRM low side where the voltage on them won't exceed the CPU VCORE voltage (1.2V? or whatever these newer LGA775 CPUs use).
      • c_hegge
        • Sep 2009
        • 5219
        Replace all of the TMVs with these (https://www.badcaps.net/store/produc...products_id=79). They are 560uF 4V OS-CON SEPC polies. I use them a lot on MSI boards with OST caps and it works fine every time. The Fujitsu caps are slightly taller and may not quite fit under the heat sink.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          the sepc 560 or the fujitsu 820 will both work fine.probably not a measureable difference in performance.you want black n yellow or silver/purple
          • Peanuckle
            Tinkerer
            • Nov 2012
            • 6
            Thank you all for the input. I've put an order in for some of Sanyo 560uf 4v polys and will report back after the recap.
            • Peanuckle
              Tinkerer
              • Nov 2012
              • 6
              I replaced all 8 of the NCC caps around the CPU, re-overclocked to my previous values (might try to push it further) and have run stress tests. So far so good!
              I used a 20/40W Radioshack soldering station @40W and tinned with their 62/36/2 silver bearing solder... the factory solder didn't want to melt. Retinned with some 60/40 and perhaps a little more patience, and all went well.
              Thanks again for the responses and thank you for having this forum.
                master hoarder
                • May 2008
                • 12170
                • Bulgaria
                Nice! Good to see you got it working again .
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Originally posted by c_hegge
                  OS-CON SEPC polies.
                  I just saw a picture of the same board at NewEgg with what looks like Sanyo/Suncon caps. Coincidence.
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • Peanuckle
                    Tinkerer
                    • Nov 2012
                    • 6
                    We're baaack. The VRM caps are still holding strong but now it's the 3 circled in purple that are a problem.
                    OST RLX 0748
                    1000uf 6.3v
                    OST RLX 0803
                    1000uf 6.3v
                    Any recommendations for replacements?
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      Rubycon MBZ is slightly better grade than that
                      Pick whatever you prefer, but don't wander too far off the originals spec:
                      0.034 ohm impedance & 1540mA ripple current
                      Replace all OST capacitors on the board.
                      This for example: https://www.badcaps.net/store/produc...roducts_id=164
                      • Peanuckle
                        Tinkerer
                        • Nov 2012
                        • 6
                        Thanks for the reply. I've got an order in for some caps and hopefully this is the last recap for this motherboard.
                        • Pentium4
                          CapXon Be Gone
                          • Sep 2011
                          • 3741
                          This is why we always recommend replacing all known bad cap brands at once Those probably got hot because of those nearby FETs
