Guys, first post so please be gentle
I need to replace the caps (and maybe the transformer) in my Samsung SM206BW PSU.
The 3 Capxon caps were replaced a couple of years ago by a neighbour, which fixed the flickering problems, however now it has developed what I believe to be 2 seconds to black.
Anyway, the caps in there now (ones that were replaced before) are the following...
1 - http://www.ebay.co.uk/itm/120524889933
2 - http://www.ebay.co.uk/itm/120544294829
I was going to replace these with Panasonic caps, and bought the following, before I realised they are a different physical size
1 - http://www.ebay.co.uk/itm/320882086299
2 - http://www.ebay.co.uk/itm/320801869585
Oh and I've bought these too to replace the cap near the transformer (so they are all done with good quality caps) and even they are a little (maybe 3mm or so) shorter...
http://www.ebay.co.uk/itm/220902689030
The ratings (uf and v) are the same and they will definately fit on the board, so that's not a problem, but my question is will the new caps be okay, or do I need to buy different ones that are closer in physical size?
I get the impression they will be fine as I think they are much higher quality caps, but this is merely a guess on my part and I would appreciate an educated answer from one of you guys.
Thanks a lot in advance for any advice.
Oh, I can take and post photo's of the board if required.
...1 - http://www.ebay.co.uk/itm/320882086299
last one I worked did ,but yes one pair for each lamp. So try one lead in each socket and see it flashes on both sockets.
