Aopen AK73 Pro(A)
  • dood
    Deputy dood
    • Mar 2004
    • 2462
    Aopen AK73 Pro(A)
    This is an older socket 462 motherboard, fairly basic in features. Every cap on the board was bad. Two 10v 3300uf, Twenty 6.3v 1500uf, and four 6.3v 1000uf. All Lelon caps. Replaced with two Samxon GD 6.3v 3300uf (only measured 5v), twenty Panasonic FM 6.3v 1500uf, and four Panasonic FM 6.3v 1200uf (1000uf not available)
    Pics of the board prior to, and after recap are forthcoming.
    Ludicrous gibs!
  • Chris1992
    • Apr 2005
    • 561
    Re: Asus AK73 Pro(A)
    It'd be Aopen AK73, I can't find anything on the Asus AK73.
    The great capacitor showdown!
    • Lance Thornton
      • Jan 2005
      • 84
      I believe that the AK73's were AOpen boards. Pictures will be helpful.
      • Lance Thornton
        • Jan 2005
        • 84
        I should also learn to read more carefully before posting!!!
        • dood
          Deputy dood
          • Mar 2004
          • 2462
          My bad, it is an Aopen. Just a mistake on my part! Pictures are coming, just taking longer than I thought. Here's the before pics:
          Ludicrous gibs!
          • Newbie2
            • Sep 2005
            • 885
            I know AOpen could do better, I have an old AOpen AX6BC (slot 1) board that is loaded with United-ChemiCon caps and those good caps came with the board!
            My neighbour also has that board and his board was loaded with Rubycon caps, and those came with his board too!
            My gaming PC:
            AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
            ASUS M4A77TD AMD 770 AM3 Motherboard
            PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
            G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
            TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
            WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
            ASUS Xonar DG 5.1 Channel PCI sound card
            Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
            Antec Three Hundred Mid-Tower Case
            Microsoft Windows 10 Pro 64-bit
            Microsoft Windows 7 Ultimate SP1 64-bit
            • dood
              Deputy dood
              • Mar 2004
              • 2462
              Re: Aopen AK73 Pro(A)
              Here are the pics of the recap. Yes, I know the one cap is crooked. I couldn't get the one leg in all the way. Oh well!
              On the test bed:
              Ludicrous gibs!
              • Oklahoma Wolf
                • Dec 2005
                • 353
                Looking good
                I've been finding a lot of these on eBay lately... almost bid on one until I realized I'd probably be looking at doing a recap right away considering the age of them. Had a feeling I wouldn't get as lucky with the caps as I did with the AK79G-Max's default Chemicons.
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  ok we are deducting points accordingly........hehe...actually i would have been happy to get only one crooked cap on my board. looks great, especially with those caps and the black pcb.
                  watch it though when you cant get a leg in, there is danger to get pissed off and force it or overheat etc thereby possibly wrecking the board.
                  • Chris1992
                    • Apr 2005
                    • 561
                    Looks good! BTW: Welcome back, dood.
                    • Oldschool297
                      RELAND SUN 6.3v 3300uf Low or High ESR?
                      by Oldschool297
                      I found these, i would only like to try them on a board to see if it post. It don't post at the moment, i guess there are 9 6.3v 3300uf that can be broken. Is these low or high esr? I did not find info on the web.
                      https://www.amazon.de/-/en/10-Capaci...s%2C469&sr=8-1
                      08-14-2023, 04:32 AM
                    • Satdude
                      2700uF instead of 3300uF
                      by Satdude
                      Hey guys, I have a question. I need to replace the caps on my og Xbox motherboard, but I can't buy quality capacitors in my country with this specification (everything is either out of stock, with a minimum order of 1000 or just plain too big to fit in the Xbox). Can I replace the 5 3300uF caps with 5 Panasonic 2700uF caps? Thanks
                      02-12-2023, 06:23 PM
                    • EFritz20
                      Available replacements Rubycon MBZ 3300uf 6.3v low ESR?
                      by EFritz20
                      I have a few busted Rubycons MBZ 3300uf 6.3v that are used for VRM purposes on a socket A motherboard. According to spec 12 mOhm with 2800 ripple.
                      I have used the search engine and it appears the Panasonics are the ones to get, but those are topics already years old and these electronic ultra low ESR caps aren't availably anymore .
                      I can't seem to find any available caps on the known sites that are in spec of these Rubycons. Also i can't find Polymers with 3300uf or even close to that. Closest ones i found where 2000/2200uf ones but...
                      05-20-2021, 10:22 AM
                    • EFritz20
                      Xbox classic/original 10v 3300uf Polymer replacement?
                      by EFritz20
                      For polymodding an original Xbox i'm looking for polymer replacements of the following capacitor:
                      2x 10v 3300uf Nichicon PW
                      One is on the left side of the board, the other one on the right as you can see the picture i linked below (the two big brown caps).
                      Could i just use 2200uf polymers to replace them or do i really need the capacitance?
                      I have searched the forum already but could not find an answer for it.
                      Thanks....
                      03-25-2022, 04:47 AM
                    • xnRS
                      3300uf 6.3V Poly recpaing
                      by xnRS
                      I got an old AM2 board with 3300uf 6.3v badcaps(all). So I want to change them with poly ones. Can you give me advice which capacity should I use ? I saw on one russian forum(rom.by) that capacity of poly should be around third of current leaky caps, but I'm not sure.
                      07-09-2021, 03:45 PM
